Understanding Transistor Models
In summary, the conversation discusses the "little r-e" model and how it is similar to the hybrid model. The main focus is on understanding equations used in common emitter and common collector circuits, specifically the use of Re and Beta. The concept of input and output impedance is also mentioned. The conversation ends with someone asking for help with transistor topics and providing their email for further assistance.
Number2Pencil
208
This is more of a "help me understand" than "help me find the answer" problem. forgive me for not using the template.
this is the "little r-e" model, similar to the hybrid model
I'm having a bit of trouble understanding how my professor got the equations for these two examples.
Common Emitter:
Zin: why does Re get multiplied by Beta?
Why does he not consider ro, Rc, or Rload?
Zout: Why does he not consider Bre, R1, R2, or Rs?
Common Collector:
Zin: once again, Beta being multiplied by what is connected to the emitter?
Zout: now he DOES consider all the resistors on the left, AND divides it by Beta.
attempt
I think I can see why Re is being multiplied by Beta in the common emitter. The current going through Bre is ib and the current going through Re is Bib, so apparently there needs to be a multiplying factor of Beta to make up for it...for what reason, I have no clue.
Common Emitter:
-Why does Re get multiplied by beta:
The answer is simple, what current goes through Re ? Ic, right? So Ic can be expressed as [tex]Ic = \beta\cdot I_{b}[/tex]
So you'll get something like this:
[tex]V_{b} = I_{b}\cdot \beta r{e} + I_{c}\cdot R_{e}[/tex]
substituting [tex]I_{c} = \beta I_{b}[/tex] gives:
[tex]V_{b} = I_{b}\cdot \beta r{e} + \beta \cdot I_{b}\cdot R_{e}[/tex]
If you go a little be further, you can easily show that the gain of the amplifier doesn't depend on [tex]\beta[/tex]
it only depends on [tex]\frac{R_{c}||R_{load}}{r_{e}+R_{e}}[/tex], since [tex]\beta I_{b}[/tex] gets canceled out.
Including [tex]r_{o}[/tex] into your calculation does not affect gain formula, since you'll get [tex]R_{c}||R_{load}||r_{o}[/tex] and as you know, combining very large impedance with small impedance, will result in small impedance, [tex]r_{o}||R_{c}||R_{load}[/tex] will be approximated to [tex]R_{c}||R_{load}[/tex]
-Why does he not consider ro, Rc, Rload
ro is VERY large, hence it does not affect the circuit(open circuit), hence no point of using it.
Rc, Rload has nothing to do with the input impedance. Rc, Rload only affects output impedance.
Common collector:
Zin: same answer as before, rewrite Ic as combination of [tex]\beta[/tex] and Ib, you'll get the same answer.
Zout: Now there is no current source in front of the output resistors, hence all of the resistors have to be considered.
Tips: Read up on circuit theory, deriving equations for those circuits is essential!
hmm...so there is just an invisible dividing line that says "input impedance ends here"?
other than that, thanks I got it
For a 4-terminal network, Zin is defined as the input impedance when the output current is 0.
Zout is defined as the output impedance when the input current is 0.
That's where the "invisible divding line" comes from.
http://en.wikipedia.org/wiki/Two-port_network
"Invisible dividing line" - I like it ;) AlephZero is correct.
Thank you, this definently helped. I'm glad I asked
No problem ;)
new
hello! i am new in here. anyone who can help me in the transistor topics? i am nathan and i would be very glad if you could help me out in this thing. thanks!
email me here:
deejay_nathan08@yahoo.com
FAQ: Understanding Transistor Models
What is a transistor and what is its role in AC models?
A transistor is a semiconductor device that can amplify or switch electronic signals. In AC models, transistors are used to control the flow of alternating current (AC) by amplifying and regulating the voltage and current.
How does the transistor contribute to the overall performance of an AC model?
The transistor plays a crucial role in the performance of AC models by allowing for efficient and precise control of the AC current. It also helps to reduce power consumption and increase the accuracy and stability of the model.
Are there different types of transistors used in AC models?
Yes, there are different types of transistors used in AC models, such as bipolar junction transistors (BJTs) and metal-oxide-semiconductor field-effect transistors (MOSFETs). The type of transistor used depends on the specific requirements and design of the AC model.
Can transistors be replaced with other components in an AC model?
Yes, in some cases, transistors can be replaced with other components such as diodes or resistors. However, these components may not provide the same level of control and efficiency as transistors, so it is important to carefully consider the design and requirements of the AC model before making any replacements.
What are the potential drawbacks of using transistors in AC models?
Some potential drawbacks of using transistors in AC models include heat dissipation, voltage drops, and the need for proper biasing and thermal management. It is important to carefully consider these factors and choose the appropriate transistors for the AC model to ensure optimal performance.
