A Rather Simple Freefall Question
  • Thread starter Thread starter Arepo
    Freefall
The discussion centers on calculating the time it takes for a person to fall 4000 feet, given a terminal velocity of 120 mph (176 ft/s). The initial calculations suggest it takes approximately 5.42 seconds to reach terminal velocity, followed by 21.72 seconds to cover the remaining distance at that speed, totaling around 27.14 seconds. Corrections indicate that the distance covered while accelerating should be subtracted from the total height, leading to a revised total fall time of about 22.72 seconds. However, it's noted that this estimate does not account for air resistance, which would likely increase the fall time by a few seconds. The discussion highlights the complexities of freefall calculations and the need for further study on air resistance in physics.
Arepo
Alright, well I haven't taken physics yet, so I set out to try and figure this problem out on myself. And the problem was, how long does it take for a person to fall 4000 feet if their terminal velocity is 120?
Here is my process of thought to get the answer... Please correct me when I'm wrong (I know I am)
Height = 4000 feet
Increase rate per second = 32.15 feet
Terminal Velocity = 120 mph = 176 feet per second
So to determine how long it takes to get to terminal velocity...
176 / 32.15 = 5.42 seconds to reach TV
(Or is it 176 / 9.8 squared?)
4000 - 176 = 3824 feet left
3824 / 176 = 21.72 seconds to travel that distance at TV
So 21.72 + 5.42 = 27.14 seconds to fall that distance.
I doubt I am right, but it all seems logical and if I messed up, please correct me, thanks a ton!
Edit: Extremely sorry for not posting it in the homework section...
Height = 4000 feet
You're good up to here.
Now look at your units here... 176 is ft/s. You can't subtract a velocity from a distance. You need to do 176 * 5.42, and you end up with ft., which is ~954. Then you can do 4000 - 954 = 3046 ft left.
So just correcting that distance, you get...
3046 / 176 = 17.3 seconds falling @ TV
17.3 + 5.42 = 22.72 seconds total
However... this probably wouldn't be very close to the real answer (assuming that the terminal velocity of a human IS 120 ft/s, and they stay perfectly still and rigid) because as you go faster, you experience more air resistance. As you near terminal velocity, your acceleration gradually diminishes. I'm not sure of an exact formula, air resistance isn't until next chapter!
Hope this helps :)
You can also look at the section of the thread https://www.physicsforums.com/showthread.php?t=110015 "Basic Equations of 1-D kinematics" for equations useful in solving this problem.
"Increase rate per second = 32.15 feet"
Note: this is acceleration, and it expressed in the units of ft/s/s.
Excellent! Thanks man!
But just curious, if you did factor in air resistance roughly what would it be? If you don't feel like doing it, that's fine, the help you provided was adequate.
I wish I could tell you, but I haven't learned how to yet. I won't know how to for another week or so. Air resistance starts next chapter. In order to calculate air resistance, we'd need a lot more information (drag coefficient, cross-sectional area, etc). My guess is that it would probably take about 2-3 seconds longer than our theoretical value, but that's just a guess.
K, but thanks anyways. I guess I'll just have to wait until I take Physics next year! ^_^
