Calculating the redshift at which radiation energy density equaled mass density
The discussion revolves around calculating the redshift at which the universe transitioned from radiation dominance to mass dominance, specifically in the context of a flat universe with a given Hubble constant. Participants explore various approaches and formulas related to energy density and temperature.
  • One participant seeks help with the calculation, mentioning the formula for radiation density and the proportional relationships between density and scale factor.
  • Another participant suggests a redshift value of approximately z = 3200, indicating that this value is derived from equating the energy density of the cosmic microwave background (CMB) with that of matter density.
  • A later reply references a source that provides a different estimate of z = 3600, noting that this estimate includes neutrinos as part of the radiation density, which could affect the calculation.
  • One participant defends the initial estimate of z = 3200, arguing that it is well-reasoned and within acceptable error margins, while also critiquing the inclusion of neutrinos as speculative.
Participants express differing estimates for the redshift at which radiation density equals mass density, with values of z = 3200 and z = 3600 being discussed. There is no consensus on which estimate is correct, and the discussion remains unresolved.
The discussion highlights the dependence on assumptions regarding the inclusion of neutrinos in the radiation density calculations, which may lead to different estimates for redshift. The mathematical steps and relationships between variables are not fully resolved.
yijiao
how do you calculate the redshift at which the universe shifted from radiation dominated to mass dominated
i was told to assume a flat universe with H0 = 70
also the temperature, to which i was given the formula density rad = aT^4
for the first part, i tried using density is propotional to scale factor ^3 and ^4
but it's not working too hot :(
help please, i need it done by tonight :(
Space news on Phys.org
Gee you have to get it done by tonight. There are some other guys who are really good, but they are not around right now. I will try to help a little in case they don't show up before you have to finish.
I think the answer is z= 3200, or so.
You know that for the CMB the redshift is z = 1100, so this is longer ago than the recombination.
I guess you take the energy density of the CMB, and multiply by 32004
and you take the energy-equivalent of matter density and multiply by 32003
and the two energy densities are supposed to be equal at the transition
I think there is a lot of cancelation, and that what it comes down to is this equation
3200 x CMB energy density = matter energy density
And what that boils down to is an equation for z (which I suspect is around 3200). Here is the equation
z = (CMB energy density)/(equivalent energy density of matter)
if 3200 is the right z, then the temperature at the time would have been
3200 x 2.725 kelvin.
Im answering quick without really remembering the material but if you need quick help you can try to get some good out of this. Dont rely on it or trust it too much tho. Good luck
Chronos said:
If it's of any use, the gruesome details can be found here:
http://www.astro.uu.se/~nisse/courses/kos2006/lnotes/ln6.pdf
that does indeed have it
equations 134 thru 137 on page 3 (so you won't have to hunt thru the whole thing), and the answer they get is approximately z = 3600
this is the redshift for "matter-radiation equality"
the redshift for "recombination" (origin of CMB) is about z = 1100 and they also derive an estimate of that.
good find! some Swedish professor's course material apparently. could be useful for other things as well.
(there is a subtlety---this guy includes NEUTRINOS as radiation because back in those days they would be so hot they would be relativistic. so he treats the neutrino background as radiation, and that is what leads him to say 3600. If he didnt he'd get a higher estimate for z---so that was a flaw in my quick sloppy response a few days ago)
Your post was not flawed, it was rigorously correct. Using the neutrino correction is speculative. Your z~3200 result is within the error bars and well reasoned. Your cold, logical explanations are simply amazing.
  • · Replies 20 ·
  • · Replies 19 ·
