How Do You Invert a Small Hermitian Matrix with Limited Memory?
In summary, there are various methods and algorithms available for inverting a small Hermitian matrix (6x6) with bounded program memory. The optimal method will depend on factors such as the memory constraints, any additional structure of the matrix, and the specific application. Some recommended algorithms include ZHETRF, ZHETRI, CHPTRF, CHPTRI, ZPOTRF, ZPOTRI, SPPTRF, SPPTRI, among others. These algorithms can be found in libraries such as LAPACK and LINPACK. It is important to consider the trade-offs between storage and code when choosing an algorithm. Additionally, there are various factors to consider when implementing the algorithm, such as the
nworm
31
Dear experts!
I have a small Hermitian matrix (6*6). I need to inverse this matrix. The program memory is bounded.
What method is optimal in this case?
Can you give any e-links?
Thanks In Advance.
Inversion codes and algorithm options.
You aren't clear on how memory bounded your program is,
so it's hard to say what algorithms are best.
That is a tiny matrix and, being 6x6 it is composed of
only 2x2 size 3x3 sub-blocks, or alternatively 3x3 size 2x2
sub-blocks. Thus you could use optimized 2x2 or 3x3 block
algorithms to help with your memory constraint.
Certainly such a target 6x6 complex
double precision COMPLEX*8 matrix takes only 576 bytes
of storage, though since it's Hermitian you can store its
lower or upper triangle in 288 bytes of memory.
Given that a few hundred bytes of code memory or data
memory is easy to expend whether you use a
code-intensive storage-reduced algorithm, or a
storage-intensive code-reduced algorithm, it's perhaps
application dependent as to what trade-off is best for you.
Furthermore, the optimum algorithm will depend on
whether you know of any additional structure of the
matrix besides it being Hermitian (e.g. sparseness,
is it positive definite, et. al.).
I'll provide some links and source codes for algorithms
to factor and invert either an indefinite or positive
definite Hermitian matrix using either packed or normal
storage and given either the upper or lower triangular
portion of the input Hermitian matrix as input to the
algorithm.
If you're going to port or rewrite the algorithms in some
memory conserving language like DSP code, C, assembler,
you'll probably find the LINPACK codes to be more explicit
since they make less use of subroutines, and the LAPACK
codes more algorithmically modular. Obviously one
would tend to just reimplement the code for one's
particular language and use case given your memory
constraints and for such a small and fixed problem size.
In general most of the work involves factoring the
input matrix, then simple algorithms can use the factored
matrix representations to calculate the inverse.
Generally the algorithms iterate over portions / blocks
of the input matrix, so, again, expanding the code for
the blocks / structure of your particular input will
yield some simplicity since it's a small and obviously
nicely blocked Hermitian matrix.
Of course if you're just trying to solve linear equations,
eigenproblems, get eigenvalues/eigenvectors, there
are other and usually better algorithms (e.g. in LAPACK/LINPACK) for such problem areas that don't
generally involve calculating the specific matrix inverse.
http://www.netlib.org/lapack/
LAPACK routines.
hermitian indefinite
http://www.netlib.org/lapack/explore-html/zhetrf.f.html
Code:
	*  ZHETRF computes the factorization of a complex Hermitian matrix A
	*  using the Bunch-Kaufman diagonal pivoting method.  The form of the
	*  factorization is
	*     A = U*D*U**H  or  A = L*D*L**H
	*  where U (or L) is a product of permutation and unit upper (lower)
	*  triangular matrices, and D is Hermitian and block diagonal with
	*  1-by-1 and 2-by-2 diagonal blocks.
	*  This is the blocked version of the algorithm, calling Level 3 BLAS.
     *   CHETRF, ZHETRF:  Computes the factorization of a complex Hermitian
         indefinite matrix, using the diagonal pivoting method.
     *   CHETRI, ZHETRI:  Computes the inverse of a complex Hermitian
         indefinite matrix, using the factorization computed by CHETRF.
hermitian indefinite packed storage
     *   CHPTRF, ZHPTRF:  Computes the factorization of a complex Hermitian
         indefinite matrix in packed storage, using the diagonal pivoting
         method.
     *   CHPTRI, ZHPTRI:  Computes the inverse of a complex Hermitian
         indefinite matrix in packed storage, using the factorization computed
         by CHPTRF.
hermitian positive definite
http://www.netlib.org/lapack/explore-html/zpotrf.f.html
Code:
	*  ZPOTRF computes the Cholesky factorization of a complex Hermitian
	*  positive definite matrix A.
	*  The factorization has the form
	*     A = U**H * U,  if UPLO = 'U', or
	*     A = L  * L**H,  if UPLO = 'L',
	*  where U is an upper triangular matrix and L is lower triangular.
	*  This is the block version of the algorithm, calling Level 3 BLAS.
     *   SPOTRF, DPOTRF, CPOTRF, ZPOTRF:  Computes the Cholesky factorization
         of a symmetric or Hermitian positive definite matrix.
     *   SPOTRI, DPOTRI, CPOTRI, ZPOTRI:  Computes the inverse of a symmetric
         or Hermitian positive definite matrix, using the Cholesky
         factorization computed by SPOTRF or CPOTRF.
hermitian positive definite packed storage
     *   SPPTRF, DPPTRF, CPPTRF, ZPPTRF:  Computes the Cholesky factorization
         of a symmetric or Hermitian positive definite matrix in packed
         storage.
     *   SPPTRI, DPPTRI, CPPTRI, ZPPTRI:  Computes the inverse of a symmetric
         or Hermitian positive definite matrix in packed storage, using the
         Cholesky factorization computed by SPPTRF or CPPTRF.
http://www.netlib.org/linpack/
LINPACK routines
Code:
single precision
	file	chifa.f  chifa.f plus dependencies
	gams	D2d1a
	for	factors a complex Hermitian matrix
	,	by elimination with symmetric pivoting
	prec	complex
	file	chidi.f  chidi.f plus dependencies
	gams	D2d1a, D3d1a
	for	computes the determinant, inertia and inverse of a complex
	,	Hermitian matrix using the factors from linpack/chifa
	prec	complex
double precision
	file	zhifa.f  zhifa.f plus dependencies
	gams	D2d1a
	prec	doublecomplex
	file	zhidi.f  zhidi.f plus dependencies
	gams	D2d1a, D3d1a
	,	Hermitian matrix using the factors from linpack/zhifa)
	prec	doublecomplex
single precision packed storage
	file	chpfa.f  chpfa.f plus dependencies
	gams	D2d1a
	,	stored in packed form by elimination with symmetric pivoting
	prec	complex
	file	chpdi.f  chpdi.f plus dependencies
	gams	D2d1a, D3d1a
	,	complex Hermitian matrix using the factors from linpack/chpfa,
	,	where the matrix is stored in packed form
	prec	complex
double precision packed storage
	file	zhpfa.f  zhpfa.f plus dependencies
	gams	D2d1a
	prec	doublecomplex
	file	zhpdi.f  zhpdi.f plus dependencies
	gams	D2d1a, D3d1a
	,	complex Hermitian matrix using the factors from linpack/zhpfa,
	prec	doublecomplex
Thank you for your question. In order to inverse a Hermitian matrix, you can use the Cholesky decomposition method which is optimal for this case. This method is efficient and can be used for both large and small matrices. The Cholesky decomposition involves finding the lower triangular matrix L such that A = LL*, where L* is the conjugate transpose of L. The inverse of a Hermitian matrix can then be calculated as (L^-1)(L*^-1). This method is also memory efficient as it only requires storing the lower triangular matrix L.
As for e-links, I would recommend checking out the following resources for more information on the Cholesky decomposition method and its implementation in different programming languages:
1. "Cholesky Decomposition for Inverse of Hermitian Matrix" by MathWorks: https://www.mathworks.com/help/matlab/ref/chol.html
2. "Cholesky Decomposition" by GeeksforGeeks: https://www.geeksforgeeks.org/cholesky-decomposition-matrix-decomposition/
3. "Inverse of a Hermitian Matrix using Cholesky Decomposition" by Code Cogs: https://www.codecogs.com/library/ma...trix_decomposition/cholesky-decomposition.php
I hope this helps. Good luck with your project!
FAQ: How Do You Invert a Small Hermitian Matrix with Limited Memory?
What is an inverse Hermitian matrix?
An inverse Hermitian matrix is a square matrix that is equal to its own conjugate transpose. In other words, the matrix is equal to its complex conjugate, with the rows and columns flipped. This property makes the matrix useful in various applications, such as solving systems of equations.
How is an inverse Hermitian matrix calculated?
To calculate the inverse Hermitian matrix of a given matrix, you need to first find the complex conjugate of the matrix. Then, take the transpose of the complex conjugate matrix. Finally, multiply the original matrix with the conjugate transpose matrix, and divide the result by the determinant of the original matrix.
What are the properties of an inverse Hermitian matrix?
Some of the key properties of an inverse Hermitian matrix include: it is its own inverse, its determinant is always real, and its eigenvalues are either positive or negative. Additionally, the product of an inverse Hermitian matrix and its conjugate transpose is always an identity matrix.
What are the applications of an inverse Hermitian matrix?
Inverse Hermitian matrices have various applications in mathematics, physics, and engineering. Some common applications include solving systems of linear equations, computing the inverse of a matrix, and performing transformations in quantum mechanics.
How is an inverse Hermitian matrix different from a regular inverse matrix?
An inverse Hermitian matrix is different from a regular inverse matrix in that it is equal to its own conjugate transpose, while a regular inverse matrix is simply the reciprocal of the original matrix. Additionally, an inverse Hermitian matrix has special properties, such as being its own inverse and having real determinants and positive or negative eigenvalues.
