Defining the Product of Linear Functionals: Is It Possible?
In summary, the conversation discusses the possibility of defining a product between two linear functionals, which would result in an algebra of functionals. However, since a functional maps functions to numbers, the composition of two functionals does not exist. One suggestion is to define an outer product, but it would not be a linear functional. Another suggestion is to define a bilinear functional, but it would not be a linear functional either.
Klaus_Hoffmann
86
Let be a set of LInear functionals [tex] U_{n}[f] [/tex] n=1,2,3,4,...
so for every n [tex] U_{n}[\lambda f+ \mu g]=\lambda U_{n}[f]+\mu U[g] [/tex] (linearity)
the question is if we can define the product of 2 linear functionals so
[tex] U_{i}U_{j}[f] [/tex] makes sense.
You can define the product of linear functionals as composition, so you have an algebra of functionals.
Defining an "ordinary" product, that is as the product of the results of the functionals would destroy linearity.
Unfortunately, since a "functional" maps functions to numbers, the composition of two functionals does not exist.
Of course, I didn't think about that. :rolleyes:
One could procede as in multilinear algebra/tensor calculus and define an outer product.
Thus let u,v be functionals
u,v:V->F
(uv)f=(vf)u
One might say the product between two linear functionals is a bilinear functional.
You can trivially define the product (as in multiplication) of two linear functionals. It just isn't a linear functional. A linear function is in particular a C/R/F valued function, so it lies in the algebra of functions, as radou sort of said.
FAQ: Defining the Product of Linear Functionals: Is It Possible?
What is a product of linear functional?
A product of linear functional is a mathematical operation that combines two or more linear functions to create a new linear function. It is denoted by the symbol * and is similar to multiplication of numbers.
What are the properties of a product of linear functional?
The product of linear functional has the following properties:
  • Commutativity: The order in which the linear functions are multiplied does not affect the result.
  • Associativity: The grouping of linear functions does not affect the result.
  • Distributivity: The product of a linear function with a sum of two other linear functions is equal to the sum of the products of the linear function with each individual function.
  • Identity: The identity function, which returns the input value, acts as the identity element for the product of linear functional.
How is a product of linear functional calculated?
The product of two linear functions, f(x) and g(x), is calculated by multiplying the two functions together. This can be represented as (f*g)(x) = f(x) * g(x).
What is the significance of the product of linear functional in mathematics?
The product of linear functional is significant in mathematics as it allows for the combination of linear functions to create new functions. This is useful in many areas of mathematics, such as differential equations and linear algebra.
Can the product of linear functional be applied to non-linear functions?
No, the product of linear functional is only applicable to linear functions. This is because the properties of linearity, such as the preservation of proportionality and the superposition principle, are necessary for the product to be well-defined and have useful properties.
