What is the role of Dedekind cuts in defining the real numbers?
  • Thread starter ice109
  • Tags
    Cut
In summary, the Dedekind cut is a way of defining real numbers by partitioning the rational numbers into two sets, L and R, where L contains all negative rationals, zero, and all numbers whose square is less than 2, and R contains all positive rationals whose square is greater than 2, and the irrational number \sqrt{2} is the least upper bound of L. This allows for the inclusion of irrational numbers in the set of real numbers and fills the "holes" in the set of rational numbers.
ice109
1,714
this isn't homework this is from a book I am reading for fun
L is the set of all negative rationals and zero and all numbers whose square is less than 2. R is the set of all numbers whose squares are greater than 2. this defines[itex]\sqrt{2}[/itex]
so that's cool i understand that, the irrational number is the interstitial region between the two sets.
what i don't understand is how applying the dedekind to the reals you get reals. maybe by analogy in that if you apply it to the rationals and the cut is inside one of the sets then the cut defines a rational number?
x is real and has a square less than 2. this defines an L class with no largest member and an R class with smallest member [itex]\sqrt{2}[/itex]
when we cut the rationals we say that if L is everything with a square less than 2 then that set has no greatest number and conversely or w/e R is the set of all numbers with squares greater than 2 but this set has no bottom.
what is different in the definition of the cut in the reals that makes it include the square root of 2 in R?
edit
ahh i understand wow I'm dumb it makes sense that if we are now including irrationals in field(right word?) then sqrt(2) is included in one of the real sets. and since its square 2 it should be in the set that does not contain the numbers whose squares are less than 2
Mathematics news on Phys.org
I would consider that poorly phrased. Using the Dedekind cut definition, the irrational number [itex]\sqrt{2}[/itex] is the union of the set of all negative rational numbers and the set of all rational numbers, the set L. As long as you are talking about rationals only, there is no "interstitial" region. And, by the way, part of the set R you define is in set L.\
But basically, you are right- the set of all rational numbers is not "complete"- there are holes in it. The Dedekind cut is a way of "filling" those holes.
[/quote]what i don't understand is how applying the dedekind to the reals you get reals. maybe by analogy in that if you apply it to the rationals and the cut is inside one of the sets then the cut defines a rational number?[/quote]
The Dedekind cut is a real number. You then prove that the set of all Dedekind cuts has all properties you associate with real numbers. In particular, if r is rational number, then the set {x| x is rational, x< r} is the "real number" representing the rational number r.
[/quote]x is real and has a square less than 2. this defines an L class with no largest member and an R class with smallest member [itex]\sqrt{2}[/itex][/quote]
No, it doesn't. Remember that the purpose of this is to DEFINE the real numbers. Until you have done that there is NO [itex]\sqrt{2}[/itex]. Defining L as you have above and R as the set of positive rational numbers whose square is larger than 2, you have partition the rational numbers into a set, L, that has no largest member and a set, R, that hs no smallest member. In particular, L is a set having an upper bound but no least upper bound and R is a set having a lower bound but no greatest lower bound.
Oh, wait, you are talking about sets of real numbers, not just sets of rational numbers. Sorry.
You are being just a bit sloppy. L is "everything with a square less than 2" and all negative rationals. R is "all positive rational numbers with square larger than 2"
The "least upper bound property". If we think of L (still a set of rationals) as a subset of R, then, since it has an upper bound, 2, it must have a least upper bound so that either L contains a largest member or R contains a smallest. In this particular case, [itex]\sqrt{2}[/itex] is the least upper bound and is in R.
edit
Pretty much. The point of the Dedekind cut is that the set, L, above is the irrational number [itex]\sqrt{2}[/itex]. The rational numbers themselves are a subset of the real numbers in the way I described above: the rational number r corresponds to the set {x| x is rational, x< r}. By the way, that is the definition Dedekind used- it is only the set you call "L" and doesn't mention "R" except for the requirement that L not be all rational numbers:
A "Dedekind cut" is a set or rational numbers satisfying
a) The set is not empty; there exist a least one rational number in it
b) The set is not all rationals; there exist at least one rational not in it
c) If a< b and b is in the set then so is a
d) The set has no largest member
If A and B are Dedekind cuts, then A< B if and only if A is a proper subset of B.
The real point of the Dedekind cut definition it that it makes it easy to prove one of the "defining" properties of the real numbers- the Least Upper Bound property that I mentioned before.
Let A be a non-empty set of real numbers, having upper bound b. Since a "real number" is a Dedekind cut, a set, A is a collection of sets. Let X be the union of all cuts in A.
Now show that X is itself a cut:
a) Since A is non-empty, it contains at least one cut. Since cuts are non-empty, the union contains at least one rational number.
b) Since A has b as upper bound, a< b for every member of A so all rational number a in some member of A are contained in b. But there exist some rational number that is not in b and so not in the union of A= x.
c) Suppose b is in x, a< b. Since x= union of A, b is in some member of A. Since a< b, a is also in that cut and so in the union: in A.
d) Suppose x were the largest member of x. Since it is in x, it must be a rational number in some member of A, say y. Since x is the largest member of y, it must be larger than any other member of y (since they are also in X) and so is the largest member of y, contradicting the fact that y is a cut.
It's easy to show that X is an upper bound on A: X is the union of all members of A so every member of A is a subset.
Finally show that there cannot exist a cut that contains every member of A and is properly contained in X.
The Dedekind cut is a mathematical concept that is used to define the real numbers. It is essentially a partition of the rational numbers into two sets, L and R, where L contains all the numbers that are less than a certain real number, and R contains all the numbers that are greater than or equal to that real number. The real number being defined is called the "cut", and it is the boundary between the two sets.
In the case of defining the real number \sqrt{2}, the cut is made between the sets L and R, where L contains all the negative rationals and zero, and R contains all the numbers whose squares are greater than 2. This means that the real number \sqrt{2} is the smallest number in the set R, and it is not present in the set L.
The role of Dedekind cuts in defining the real numbers is to provide a rigorous and precise way of defining irrational numbers, such as \sqrt{2}. By using Dedekind cuts, we can define the real numbers as a complete and ordered field, which means that they have all the properties of a number system that we expect, such as the ability to add, subtract, multiply, and divide.
In the case of \sqrt{2}, the Dedekind cut allows us to include this irrational number in the set of real numbers, which is not possible in the set of rational numbers. This is because the set of rational numbers is not complete, meaning that there are gaps or "holes" in the number line that cannot be filled with rational numbers. The Dedekind cut fills in these gaps and allows us to define the real numbers as a complete and ordered field.
In summary, the role of Dedekind cuts in defining the real numbers is to provide a rigorous and precise way of including irrational numbers in the number system, and to define the real numbers as a complete and ordered field. This allows us to perform mathematical operations with real numbers and to have a complete understanding of the number line.
FAQ: What is the role of Dedekind cuts in defining the real numbers?
What are Dedekind cuts?
Dedekind cuts are a mathematical concept introduced by German mathematician Richard Dedekind in the late 19th century. They are a way of defining the real numbers using sets of rational numbers.
How do Dedekind cuts define the real numbers?
Dedekind cuts define the real numbers by partitioning the set of rational numbers into two subsets, typically referred to as the "left" and "right" sets. The left set contains all the rational numbers less than the real number being defined, while the right set contains all the rational numbers greater than the real number being defined.
Why are Dedekind cuts important in defining the real numbers?
Dedekind cuts are important because they provide a rigorous and precise way of defining the real numbers. This is necessary because the real numbers are infinitely dense and cannot be fully described by using rational numbers alone.
How do Dedekind cuts relate to other methods of defining the real numbers?
Dedekind cuts are one of several methods used to define the real numbers. Other methods include Cauchy sequences and decimal expansions. However, Dedekind cuts are often preferred because they are more intuitive and easier to understand.
What are some applications of Dedekind cuts?
Dedekind cuts have various applications in mathematics, including in the study of real analysis, topology, and measure theory. They are also used in practical applications, such as in computer science and engineering, to model and solve problems involving real numbers.
