couldabin
- 10
I've used a 5-gallon bucket, filled with water, with two clear plastic hoses plumbed to the bottom to establish level over a distance of about 5 meters. It worked well enough for the circumstances.
Now I'm interested in establishing level over a distance that is closer to 30 meters, and would like to know if the two points are level within 3 cm or so.
Will this simple water level be that accurate? What are the factors that limit/enhance the accuracy? Does the diameter of the hoses affect it? What about the amount of water head (if, for instance, instead of a 5-gallon bucket I were to use a piece of large diameter PVC, 2 meters long)? What about the diameter at the end of each hose -- if the diameter of the last foot of the hose were made much larger, would it improve the accuracy?
TIA
TIA
