Kilo prototype mysteriously loses weight
  • Thread starter Thread starter ZapperZ
    Prototype Weight
The discussion revolves around the phenomenon of a kilogram prototype reportedly losing weight, specifically about 50 micrograms, and the implications of this observation. Participants explore various theories and hypotheses regarding the potential causes of this weight loss, including measurement uncertainties, material properties, and environmental factors.
  • Some participants suggest that the weight loss could be due to very slow radioactive decay.
  • Others propose vacuum fluctuations as a possible explanation for the observed mass change.
  • There is a hypothesis that local effects of Hubble flow might be influencing the measurements.
  • Some participants consider the possibility of unstable isotopes affecting the kilogram prototype's mass.
  • Concerns are raised about the accuracy of historical measurements and whether they could account for discrepancies.
  • Participants discuss the potential for contamination from fingerprints or dust affecting the weight of the replicas.
  • One participant mentions the idea that all particles in the universe are constantly losing mass, which could explain the differences in weight over time.
  • There is speculation about the effects of vapour pressure on the mass measurements.
  • Some participants express uncertainty about how to determine whether the original prototype has lost weight or if the copies have gained weight.
  • Discussion includes the need for periodic calibration of the standards and how that might affect the observed discrepancies.
Participants do not reach a consensus on the cause of the weight loss, with multiple competing theories and viewpoints presented throughout the discussion.
Participants note limitations in the measurement system and the potential for contamination affecting results. There is also uncertainty regarding the historical accuracy of the original measurements and how that impacts current interpretations.
ZapperZ
Staff Emeritus
Insights Author
The http://news.yahoo.com/s/ap/20070912/ap_on_re_eu/shrinking_kilogram, but about 50 micrograms!
Look out everyone. We are all heavier! So much for me trying to lose weight!
Zz.
Zz.
..."The mystery is that they were all made of the same material, and many were made at the same time and kept under the same conditions, and yet the masses among them are slowly drifting apart," he said. "We don't really have a good hypothesis for it."
Wow! That is odd. Very slow radioactive decay?
I would vote on vacuum fluctuation!
Zz.
Local effects of Hubble flow.
Iridium has two stable (?) isotopes 191Ir and 193Ir. Suppose that there was a small admixture of unstable isotopes in the kilo prototype?
How about innacurate measurements 118 years ago?
Thats really cool. Although I don't understand half of the theories you guys put up, its still cool.
The prototype is losing mass with respect to later copies (and they are compared periodically), so perhaps 193Ir can very slowly decay to 191Ir at a rate that must be measured in decades or centuries.
I second this!
50 micrograms is roughly equivalent to the weight of a fingerprint.
So, out of curiousity, how do they know the standard is the one losing weight, and that the problem isn't that the ones kept under less stringent conditions aren't gaining weight from things like fingerprints and dust?
I agree with Moonbear, but kind of find it hard to believe that carelessness like that would be overlooked. I think it could be some sort of extremely slow radioactive decay.
Maybe not a radioactive decay, but a spallation process in which the heavier isotope is hit by high-energy particles, and goes to 192Ir, which IS radioactively unstable and decays to 191Ir.
I say a prankster went around touching all the replicas. This is a case for Gil Grissom. :biggrin:
Zz.
You forgot to mention which diet plan was followed?
That's because the article didn't mention any. But I bet it wasn't Atkins.
Zz.
It's not clear whether the original has become lighter, or the national prototypes have become heavier...
It is kept in a triple-locked safe at a chateau and rarely sees the light of day — mostly for comparison with other cylinders shipped in periodically from around the world.
I suspect the copies have all simply picked up varying amounts of mass by contact with other things during transportation to and from the Institute.
So, just picking one up would increase the weight?
Isn't it possible that during transport, the bumpy bumping bumps might have transferred something from/to the base it sits on?
Zz.
5 parts per 100 million? I have to wonder about the uncertainty in the measuring system. Maybe someone cleaned it.
What to they do when they find such a discrepency. Do they lop off 50 micrograms of the material from the heavy ones? Do they just add a fudge factor when they use the heavy ones? To what use do you put a lump of metal that is a whopping 50 million picograms more than a kilogram?
Actually, 50 micrograms is HUGE because we can actually detect a change in mass when just one monolayer of atoms have been formed. Quartz crystal thickness monitor that is commonly used in monitoring thin film deposition can measure such change.
Zz.
Several years ago, the guy who used to be responsible for cleaning it retired. He apparently had just the right touch, and there was some concern about whether his replacement would be as good. Maybe now we know! :rolleyes:
(what a coincidence... I was talking about the standard kilogram and the guy who cleaned it, just a half hour ago in my General Physics class.)
Zz.
I recently received a whopping 30 micrograms of a protein...had to go a bit on faith that it was really in the vial it was shipped in...there was a tiny speck at the bottom, barely visible by eye. Just a bit of residue from dust or handling, or even from the cleaning solutions used to remove dust and fingerprints could quickly account for that much of a difference. I'm just not sure how you determine the direction of change when you're talking about THE standard. If that is THE standard, then by definition, the other replicates have gained weight, have they not? How could you determine otherwise if there is no back-up, untouched standard to compare it with?
How often are the standards checked and compared? If it was something like slow radioactive decay, you would see a very gradual divergence in the weights of the standards produced at different times, not a sudden divergence.
Here is an idea from Tim Sverduk, my friend and colleague. All particles in the universe are constantly losing mass. By traveling, the particles in the copies have 'lived' for a shorter time and thus have not lost as much mass. I doubt it is true, but I think it should be an interesting exercise to disprove it.
What about vapour pressure?
Well, according to one of the guys the article quoted says
the reference kilo appears to have lost 50 micrograms compared with the average of dozens of copies."
Well, the guy who's the "senior researcher" says
"It's not clear whether the original has become lighter, or the national prototypes have become heavier," said Michael Borys, a senior researcher with Germany's national measures institute in Braunschweig. "But by definition, only the original represents exactly a kilogram."
According to the "Journal of Research of the National Institute of Standards and Technolog"[1]
[T]he prototypes serving as national standards of mass must be returned periodically to the BIPM for calibration either on an individual basis, which could be done anytime, or as part of a simultaneous recalibration of all the prototypes known as "periodic verification." Since the existence of the prototypes there has been only three such periodic verifications. The latest one, the third periodic verification, took place between 1988 and 1992.
So, 3 verifications since 1879 (when the prototype was made) would be less than once every 40 years?
Picture of the international kilogram prototype
[1] Journal of Research of the National Institute of Standards and Technology, January-Febuary, 2001 by Z.J. Jabbour, S.L.Yaniv
That's a cool link, RB. It's quite a bit more complicated than I'd figured.
Any chance that the copies, being kept under less stringent quarantine, are slowly absorbing things like beta particles and neutrinos that the original isn't exposed to?
The copies, being more recently manufactured, do NOT contain as many pits, fissures, slag and flux inclusions, and other flaws as the prototype. The fact that the mass of the prototype varies up and down has been recognized as a "weakness" of SI for some time; for at least the past thirty years (could be longer) there has been interest in retiring the prototype to museum status and redefining the kilogram as the average of the copy masses.
The Earth burped.
I think the original and really the original process in making the 'original' is the culprit. Who knows that micro-components were included in the original at the time it was created. There could have been small amounts of 'something' that could have evaporated or sublimated away, even if it could have been ever so slowly over the last 50 or 100 years to do.
Thanks, thought so myself :)
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 95 ·
11K
