Comet's Velocity Homework: Answer What Speed at Perihelion?
  • Thread starter Jtappan
  • Tags
    Velocity
In summary, the orbit of Halley's Comet around the Sun is a long thin ellipse. At its perihelion, the comet has a distance of 8.4 * 10^10 m from the Sun and a speed of 11.0 km/s. Using Kepler's second law and the relation v1.d1 = v2.d2, we can find the comet's speed at its perihelion to be approximately 746428.571428 m/s.
Jtappan
96
The orbit of Halley's Comet around the Sun is a long thin ellipse. At its aphelion (point farthest from the Sun), the comet is 5.7 * 10^12 m from the Sun and moves with a speed of 11.0 km/s. What is the comet's speed at its perihelion (closest approach to the Sun) where its distance from the Sun is 8.4 * 10^10 m?
_____km/s
PEi+KEi=PEf+KEf
do the m and g values cancel out when doing this because they are not given? I am totally lost...
Weak, they gave you the perihelion. Since they gave perihelion distance, a lot of trouble is saved. Now this begs the question of what is the difference between the aphelion and the perihelion? Is there any kind of easily attainable relation you can use? To give you a hint, you might want to consider more than energy conservation. (Hint hint: one of them types of momentum, and one is better than the other.)
Did you know that you can solve for the perihelion with the information they have given you? If you feel ambitious, give it a try.
using kepler's second law,that areal velocity is constant for anybody in gravitational revolution in elliptical orbit,and applying it for positions at perigee and apogee,taking infifitesimally small orbital motion,we get the areas for the respective triangles at these positions...dividing the obtained relation with infitesimally small time duration 'dt',we get a ratio of velocities at these two positions with relation to the distances...the relation obtained is... v1.d1 = v2.d2
thus,simply using this inverse ratio,we can find the answer...
the velocity at the nearmost point of comet from sun is '746428.571428...m/s'
in short,i applied kepler's law at small intervals of distances and differentiated it wrt time to obtain velocity...
FAQ: Comet's Velocity Homework: Answer What Speed at Perihelion?
1. What is the definition of "perihelion"?
Perihelion refers to the point in an object's orbit around the sun where it is closest to the sun.
2. How is the speed at perihelion calculated for a comet?
The speed at perihelion for a comet is calculated using the formula v = √(GM(2/r - 1/a)), where G is the gravitational constant, M is the mass of the sun, r is the distance from the sun at perihelion, and a is the semi-major axis of the comet's orbit.
3. What units are typically used to express the speed at perihelion?
The speed at perihelion is typically expressed in kilometers per second (km/s).
4. How does the speed at perihelion affect a comet's orbit?
The speed at perihelion affects a comet's orbit by determining how close the comet will come to the sun and how quickly it will travel through its orbit. A higher speed at perihelion means the comet will move faster and have a shorter period, while a lower speed at perihelion means the comet will move slower and have a longer period.
5. Can the speed at perihelion change over time for a comet?
Yes, the speed at perihelion can change over time for a comet due to factors such as the comet's interaction with other objects in the solar system and the release of gases from the comet's surface. However, these changes are typically small and do not significantly alter the comet's orbit.
