Bicycle physics - Flying over the handlebars
In summary, skilled cyclists use the front brake alone most of the time, but improper modulation of the force can result in the rider being thrown over the handlebars. The generated force in this scenario is actually momentum, not a specific force. To calculate the force, one can use the Schrodinger equation and consider factors such as speed, bike and rider mass, and height.
SysResearch
It is known that maximum braking occurs when the front brake is applied so hard that the rear wheel is just about to lift off. Skilled cyclists use the front brake alone probably 95% of the time.
However, improperly modulating the force applied on the front brake will bring the bike to a sudden stop, rider and bicycle's weight shifts to the front thus generating a momentum (force) that will send the rider "sailing" forward over the handlebars and eventually the bike will flip.
The second case scenario a bicycle hits a end parking concrete barriere at 15km/h.
Chances are the bicycle and rider will flip over.
Q1): Does anyone know what is the name of the generated force ( that throws you over the handlebars).
Q2): Based on speed, bike/rider mass-height how can this force be calculated.
Any links?
Thank you anticipated
S.R.
q1) There doesn't need to be a shift in weight. The rider has momentum. Newton's first law tells you that an object wants to keep going in a straight line until acted on by an external force. When you stop normally, your arms and legs exert a force to help keep you upright on the bike and to slow you down with the bike. The rider's momentum is what carries them over the handlebars. There is no force, that is the problem. The rider needs a force to stop with the bike. So your statement that "...rider and bicycle's weight shifts to the front thus generating a momentum (force)..." is not really what is happening. If you are wondering about the flip part, that is simply a pivot point being introduced and the rider's arms or whatever providing the centripetal force required to introduce circular motion. Think of a situation where the rider let's go completely when they hit a stationary object. The rider will, most likely, just keep going in a straight line and not flip over.
q2) Essentially, worst case, the rider will keep moving at the same rate they were before they hit the brake. There will be a slight deceleration because their arms should exert some force to try to keep themselves on the bike.
This is the same exact scenario as a person riding in a car without their seat belt. If the car is moving 50 mph and suddenly stops, the person without the seatbelt to exert a force to decelerate, will keep moving at 50 mph.
The difference between a car and a bike is that a bike has the centre of mass compared to the base higher than that of a car (a man is much heavier than the bike itself). So if you brake the front wheel of a bike, the braking force is much stronger than the back wheel.
High centre of mass also explains for the fact that one can easily fly over the handlebar when he/she used the front brake. It creates a torque with the point that the front wheel contacts with the road as the pivot.
Q1.) Not exactly a force. Angular momentum, a quantity that likes to be conserved and will take any opportunity that arises to lob you off the front. And I only have a back brake... Well, the force would be centripetal force.
Q2.) Use the Schrodinger equation: Fast speed + wheel lock = Faceplant. Let's assume that the wheel locks up and does not slide whatsoever, or very little (as is the case in real life). Then, all your momentum is transferred into a rotational movement about the wheel, the center of the virtual circle would be the point where the wheel contacts the ground. If the cyclist is only thrown off and the bike is stationary and remains so, then mass (of combined bike & human) * velocity = mass of human * new velocity.
So a cyclist of mass 70kg at say, 15m/s, with a bike of mass 10kg, will have a momentum of [(70kg+10kg)*15ms], which means he'll be moving at 17m/s, and will have some 10kJ of energy to dissipate, which I imagine is not going to be pretty.
Super nice! Thank you!
That was nice! Thanks a lot
FAQ: Bicycle physics - Flying over the handlebars
What causes a person to fly over the handlebars while riding a bicycle?
There are several factors that can cause a person to fly over the handlebars while riding a bicycle. These include sudden braking, hitting an obstacle or bump in the road, and improper weight distribution.
How does the center of mass affect the likelihood of flying over the handlebars?
The center of mass, or the point where the rider's weight is centered on the bicycle, plays a crucial role in preventing or causing a person to fly over the handlebars. If the center of mass is too far forward, it can cause the front wheel to lift off the ground and result in a loss of balance.
What role does the angle of the bicycle play in flying over the handlebars?
The angle of the bicycle, specifically the angle between the front wheel and the ground, can greatly impact the likelihood of flying over the handlebars. If this angle becomes too acute, it can cause the front wheel to stop abruptly and send the rider over the handlebars.
What are some ways to prevent flying over the handlebars?
To prevent flying over the handlebars, it is important to maintain proper weight distribution and adjust the center of mass accordingly. Additionally, being aware of potential obstacles or bumps in the road and practicing proper braking techniques can also help prevent this from happening.
How can understanding bicycle physics help prevent accidents like flying over the handlebars?
Understanding bicycle physics, including concepts like weight distribution and center of mass, can help riders make informed decisions while riding to prevent accidents. It can also aid in properly adjusting and maintaining a bicycle to ensure it is safe and stable for riding.
