Calculate Max & Min Speed for Car Banking an Angle
  • Thread starter Thread starter jgens
    Angle Car
The discussion revolves around calculating the maximum and minimum speeds for a car navigating a banked curve with a specified radius and coefficient of friction. The problem involves concepts from dynamics and circular motion.
  • Mixed
  • Participants explore the use of free body diagrams to analyze forces acting on the car, including friction, normal force, and weight. There are attempts to derive equations relating these forces to centripetal acceleration.
  • Some participants express confusion over the correctness of their calculations and the relationships between angles in the free body diagrams.
  • There are discussions about the implications of using numerical values early in the problem-solving process versus keeping variables symbolic for clarity.
  • One participant mentions a specific formula for calculating speed, while others question the assumptions and derivations leading to that formula.
The conversation is ongoing, with participants sharing their calculations and seeking clarification on their approaches. Some guidance has been offered regarding the use of free body diagrams and the importance of maintaining clarity in equations. There is no explicit consensus on the correct approach or final answers yet.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There are indications of differing interpretations of the problem setup and the equations involved.
jgens
A curve of radius 45 m is banked for a design speed of 90 km/hr. If the coefficient of static friction is .3 what is the maximum speed that the car can go around the curve safely. What is the minimum speed?
n/a
θ = tan^-1((25 m/s)^2/(45m * 9.8 m/s^2) = 54.8 degrees
Fn(sinθ) + Ff = (m)(v^2)/r
Fn(cosθ) = mg
Fn= (mg)/(cosθ)
mg(tanθ) + μ(Fn) = (m)(v^2)/r
mg(tanθ) + μ(mg/cosθ) = (m)(v^2)/r
g(tanθ) + μ(g/cosθ) = (v^2)/r
45m((9.8m/s^s(tan(54.8)) + .3(9.8m/s^s/cos(54.8)) = (v^2)
v = 29.23 m/s or 105.25 km/hr.
The key that I'm checking this with says that the above answer is not correct. I haven't tried to find the minimum speed yet because my maximum is incorrect. Could someone please let me know where I'm making a mistake or if I'm going about this the wrong way? Thanks.
Draw a freebody diagram. The forces acting on the car on the inclined road at a point are the force of friction inward, the normal reaction and the weight. The sum of the horizontal component of these is equal to the centripetal force.
I’m quite sure that you have done just these, but if you plug in numbers right at the beginning, it makes things look messy and hard to check. Use symbols.
I tried this problem again without putting numbers in at the beginning.
(m)(v^2)/r = Fn(sinθ) + Ff
(m)(v^2)/r = mg(tanθ) + Ff
(m)(v^2)/r = (m)(v1^2)/r + Ff
(m)(v^2)/r = (m)(v1^2)/r + μ(m)(v1^2)/(r(sinθ))
v^2 = (v1^2) + μ(v1^2)/(sinθ)
v^2 = (25 m/s)^2 + 0.3(25 m/s)^2/(sin(54.8))
v = 29.23 m/s or 105.23 km
No matter how I go about this I always get the same answer. Could someone point out what I'm doing wrong or at least steer me in the right direction? Thanks.
My freebody diagram looks like that. But aren't the two angles equal? (alpha and beta)
I get 36.286 m/s. What is the actual answer?
My final equation was ...
[tex]v=\sqrt{\frac{-Rg(\mu_s\cos \beta+\sin \alpha)}{\mu_s\sin \beta-\cos \alpha}}}[/tex]
And yes, alpha and beta are the same b/c I used trig identities and I think you did too ...
That is the correct answer. I found out how you got that formula and I've also solved for the lowest speed which is about 18.6 m/s or 66.96 km/hr. Thank you for all of your help.
Alternatively, if you would have chosen your reference axis differently, the only force with an angle would have been gravity.
You forgot about the acceleration towards the center.
Fn(cosθ) = mg
Thanks.
both these equations are wrong they should read
Fn(sinθ) + Ff(cosθ) = (m)(v^2)/r
and
Fn(cosθ) = mg + Ff(sinθ)
  • · Replies 20 ·
  • · Replies 28 ·
24K
