- 4,219
- 68
Ian? What happens if you leave E. coli's out to grow on a AMP/LB plate overweekend? I left my plate in the stove and they are REALLY important clones and I don't have the key to the lab! They'll live right?
Good question, what is the molecular basis on which ampiciline works? From Ian's statement I understand it is biostatic and not biocidal.Jikx said:Anyway, a question on my part - Can AMP kill bacteria or will it only stop growth? Or is it only able to kill cells that are actively dividing?
Monique said:No, it is a non-pathogenic strain of E. coli which normally is not able to grow in the presence of ampiciline. What I made is a certain contruct in a viral vector, a piece of dna, which the bacteria have taken up. In this contruct there is a piece of DNA that contains the restistance gene against amp. So only the bacteria with the construct will be able to grow. I can later isolate this vector with the insert, a plasmid, from these bacteria.
So the construct that is made can either contain a gene or portions of DNA that regulate genes. The bacteria just serve to amplify it, so that it can be isolated and put back into another celltype to evaluate its effect.
Close, cloning with DH5 alpha and pGEM(-T) (among others: pGL3, pcDNA3.1) :)iansmith said:In other words you are doing cloning with probably DH5 alpha with a pUC derivative
Yes, it is possible for E. coli to grow on an AMP/LB plate over a weekend. The growth rate of E. coli can vary, but given optimal conditions, it can double in population every 20 minutes.
An AMP/LB plate is a type of growth medium specifically designed for E. coli bacteria. It contains two main components: LB (Lysogeny Broth) and AMP (Ampicillin). LB provides essential nutrients for the bacteria to grow, while AMP is an antibiotic that only allows for the growth of bacteria containing a specific gene that makes them resistant to the antibiotic.
AMP works by targeting the cell walls of bacteria and inhibiting their ability to reproduce. Bacteria that contain the specific gene for AMP resistance are able to produce an enzyme that breaks down the antibiotic, allowing them to continue growing and reproducing.
The time it takes for E. coli to grow on an AMP/LB plate can vary, but under ideal conditions, it can take anywhere from 12-24 hours. Factors such as temperature, humidity, and the amount of bacteria initially added to the plate can also affect the growth rate.
Yes, E. coli can still grow on an AMP/LB plate if it is left out at room temperature. However, it may grow at a slower rate compared to being incubated at a warmer temperature, and there is also a higher risk of contamination from other bacteria or fungi present in the environment.
