Why Is the Fine Structure Constant Still a Mystery?
The discussion centers around the fine structure constant (α), its significance, and why it is considered a mystery in the context of physics. Participants explore its properties as a dimensionless constant, its relationship to fundamental forces, and its implications in various physical theories.
  • Some participants note that the fine structure constant is unique among dimensionless constants due to its lack of a simple mathematical explanation, unlike constants such as π or e.
  • One participant suggests that understanding the value of α (approximately 1/137) could be a significant achievement in modern physics.
  • Another participant discusses α in the context of Planck units, proposing that it represents the strength of electromagnetic interactions relative to other forces, raising questions about why its value is approximately 10^-2.
  • There is a suggestion that the fine structure constant could be explained through anthropic principles, but this remains speculative.
  • Some participants discuss the relationship between α and the velocity of electrons, questioning whether the value of α changes based on the medium through which light travels.
  • One participant asserts that the fine structure constant is defined for the velocity of an electron in the first circular Bohr orbit, while others challenge the implications of this definition for electron velocities in different contexts.
  • There is a debate about whether the equations relating α to electron velocity and the speed of light apply universally or only in specific cases, with some participants emphasizing the need for careful interpretation of these relationships.
Participants express a variety of views on the significance and implications of the fine structure constant, with no consensus reached on its mystery or the conditions under which its value applies. Disagreements arise regarding the interpretation of its relationship to electron velocity and the conditions under which it is defined.
Some discussions reference specific cases, such as the electron's velocity in the Bohr model, which may not generalize to other scenarios. The conversation also highlights the complexity of defining constants in different physical contexts.
spidey
A lot of scientists say that fine structure constant is still a mystery..one of them was Richard Feynmann...i know fine structure constant is a dimensionless constant and there are many dimensionless constant but why this fine structure constant takes special place?can anyone tell me why this constant is still a mystery and what mystery it has?
There are not so many dimensionless constants that have no simple math explanation like pi or e. The fsc alpha is the strength of the electromagnetic and weak forces, and is related to the strength of the strong force.
"Still a mystery" is a bit of hyperbole that RF enjoyed, but explaining or understanding its
value 1/137.036... could be the crowning accomplishment of this new century.
the NIST site and Wikipedia page answer some of this. the way i like to think of it, from the POV of Planck units, is that [itex]\sqrt{\alpha}[/itex] is the quantitative amount of the Elementary charge as measured in units of the Planck charge. as such, if you consider all charged objects as the same integer multiple of Elementary charges, [itex]\alpha[/itex] represents the relative strength of the E&M interaction, relative to the other forces (like gravity which is normalized to 1 in Planck units). the fact that [itex]\alpha \approx 10^{-2}[/itex] instead of [itex]\approx 10^{-19}[/itex] (which is about the masses of particles in Planck units; the fact that this number is so small is why "gravity is extremely weak") is a matter of curiousity. why is it that, measured in natural units of charge, that the Elementary charge is in the same ballpark? but the masses of particles are not anywhere close to a natural unit of mass?
because we can't, without hand-waving some kinda anthropic principle based argument, have it explained from more fundamental principles. even if you were doing everything in Planck units, [itex]\alpha[/itex] would still be a value that you would have to #define in your C program where you are emulating physical reality from the diff eqs. that are used to describe it.
one guy said that it should be
[tex]\alpha = \frac{\cos \left(\pi/137 \right)}{137} \ \frac{\tan \left(\pi/(137 \cdot 29) \right)}{\pi/(137 \cdot 29)}[/tex]
but i think his reasoning was only numerological. i don't think that whenever the physics behind the value of the Fine-structure constant are understood, the resulting theoretical value will be the one above. but i dunno, it's worth pondering and speculating about, which is essentially what Feynman was saying.
it also says that alpha is the ratio between the velocity of electron and velocity of light...velocity of light is different in different mediums so will this change the value of alpha...Or velocity of light means the velocity of light in vaccuum...
from this shall we say that there exists an upper limit for the velocity of electron...
There is an upper limit for the velocity of an electron (the speed of light, presumably?). When things are compared to "the velocity of light", usually what is meant is the constant labelled C which is the speed of light in a vacuum.
Don't know where you get this stuff from, an electron can move at any velocity (of course that wouldn't make sense unless you were considering a group/beam of electrons).
"is the quantitative amount of the Elementary charge as measured in units of the Planck charge."
Since alpha is dimensionless, it equals 1/137 in units of anything.
it's from the NIST reference i made. it says
... The quantity [itex]\alpha[/itex], which is equal to the ratio v1/c where v1 is the velocity of the electron in the first circular Bohr orbit and c is the speed of light in vacuum, appeared naturally in Sommerfeld's analysis and determined the size of the splitting or fine-structure of the hydrogenic spectral lines...
no contradiction here.
[tex]\alpha = \frac{e^2}{4 \pi \epsilon_0 \hbar c}[/tex]
[tex]\sqrt{\alpha} = \frac{e}{\sqrt{4 \pi \epsilon_0 \hbar c}}[/tex]
the denominator is the Planck charge. the ratio [itex]\sqrt{\alpha}[/itex] is of two identically dimensioned quantities, so it's dimensionless and about one 11th.
since alpha is also ratio between velocity of electron and light
alpha = v/c=1/137
v/c=1/137
v=c/137
so this should be the upper limit of velocity of electron...am i right...
alpha = v/c=1/137
v/c=1/137
v=c/137
No. Your first equation is only for a special case.
if it is for special case then wouldn't alpha value change for velocity of electron greater than c/137...
no, read what the NIST site says. for the special case of the Bohr hydrogen atom and the electron is in the lowest energy orbit, the fine-structure constant is the ratio of that electron velocity to the speed of light. so, in the Bohr hydrogen atom, the electron's speed is 137 times slower than light.
Thanks rbj...
alpha is calculated for velocity of electron in the first orbit of hydrogen atom...so wat is special in this...we can also give so many ratios like this..velocity of electron in second orbit/c and so on and we will get many constants...velocity of anything/ velocity will anything will be dimensionless,so wat is special with this alpha..sorry,i really couldn't understand the mystery here...
  • · Replies 80 ·
  • · Replies 20 ·
  • · Replies 32 ·
