How Do You Calculate the Slit Spacing in a Double-Slit Experiment?
  • Thread starter Thread starter BuBbLeS01
The discussion focuses on calculating the slit spacing in a double-slit experiment using a helium-neon laser with a wavelength of 590 nm. The setup involves a screen positioned 3.42 m from the slits, where twelve bright fringes are observed over a distance of 47 mm. The calculated spacing between the slits is determined to be approximately 4.73 x 10^-4 m, or 0.473 mm. Participants emphasize the importance of clearly labeling variables and understanding the behavior of light in this context.
  • Understanding of wave interference principles
  • Familiarity with the double-slit experiment
  • Knowledge of basic optics and light behavior
  • Ability to perform unit conversions (e.g., nm to mm)
  • Study the principles of wave interference in detail
  • Learn about the mathematical derivation of the double-slit formula
  • Explore the impact of slit width and distance on interference patterns
  • Investigate the behavior of coherent light sources in experimental setups
Students in physics, educators teaching optics, and anyone interested in experimental physics and wave phenomena.
BuBbLeS01
Light from a helium-neon laser (λ=590 nm) is used to illuminate two narrow slits. The interference pattern is observed on a screen 3.42 m behind the slits. Twelve bright fringes are seen, spanning a distance of 47 mm. What is the spacing (in mm) between the slits?
t = wavelength
t= 590 nm
L = 3.42 m
y = 47 mm
12 fringes
so the space between 2 fringes would be 47mm/11 = 4.27 mm
d = tL/y = 4.73 x 10^-4 m
I don't have the answer to this problem so is this the right way to do this?
Does anyone know if this is right?
your variables are a bit confusin. try labeling them. also, are you saying that the light is coming straight out? (because light doesn't usually stay in a straight beam, does it)
11K
11K
