Object Falling into a Black Hole: What Happens?
In summary, an external observer will never see an object fall into a black hole. However, the black hole will lose mass by Hawking radiation and will eventually evaporate.
michael879
698
I have a question about someone falling into a black hole. General relativity predicts that the reference frame of an object falling into a black hole will reach the singularity in a finite amount of time. However it also predicts that the reference frame of an observer outside the event horizon will never observe the object crossing the event horizon.
From what I understand, in the outside reference frame the object ACTUALLY never falls into the black hole (the fact that the time light takes to reach the observer approaches infinity as the location of the object at emission approaches the event horizon although a good explanation of this phenomenon is not the one general relativity predicts).
However, taking Hawking radiation into account makes the black hole decay and evaporate in some finite amount of time. My question is what happens in the observers reference frame when the black hole evaporates? Does the object just disappear (as would be the case if the above explanation were true)? Or does the object remain intact?
anyone?
Ha, that would be nice. Jump into a black hole with you radiation proof suit on. The journey will only take ten minutes by your watch but by the time you get to where the singularity was it has evaporated and you find yourself a billion years in the future because that is how long it takes a typical black hole to evaporate according to an external observer. (Only kidding ;)
If you trawl through the forum threads you will see this subject has been discussed several times.
Here are two recent ones:
https://www.physicsforums.com/showthread.php?t=203383
https://www.physicsforums.com/showthread.php?t=223464
Although a black hole will loose mass by Hawking radiation it will most likely gain mass at a higher rate by absorbing radiation from the cosmic microwave background radiation and thus not decay at all. This may not apply for micro black holes mut I'm not exactly sure. Its been a very long time since I've worked with those equations.
Pete
At the relevant timescales, the universe will be colder than any black hole.
Pete
ok well assume for the sake of argument that there is nothing for the black hole to suck in. I mean, eventually this will be true for all black holes (since there is a finite amount of energy in the universe).
I checked out these topics and I didnt see my question either asked or answered. If somehow I missed it, could you please show me the answer given?
Also, your hypothetical "joke" seems perfectly plausible to me. From how I currently understand the physics of black holes that must be what happens in order to keep all the reference frames in agreement as to what is happening. If this were not the case, it would imply that the only reason you never see someone fall into a black hole is because of the red shift of emitted photons. However this is not the case since GR predicts that the time of the object falling in approaches 0 and that the object ACTUALLY never falls in from the infinite rest frame.
FAQ: Object Falling into a Black Hole: What Happens?
What happens to an object when it falls into a black hole?
When an object falls into a black hole, it will experience extreme gravitational forces that will cause it to be stretched and compressed. Eventually, the object will reach the singularity at the center of the black hole where it will be crushed to an infinitely small point.
Can an object survive falling into a black hole?
In most cases, no. The immense gravitational forces of a black hole are strong enough to destroy any object that falls into it. However, there are some theories that suggest smaller objects, such as particles, may be able to pass through a black hole without being destroyed.
Can we see an object falling into a black hole?
No, we cannot see an object falling into a black hole. This is because the intense gravitational pull of a black hole causes it to have a strong gravitational lensing effect, which bends and distorts the light around it. This makes it impossible for us to see anything that is falling into the black hole.
What happens to time near a black hole?
Time near a black hole is affected by its strong gravitational pull. As an object gets closer to a black hole, time will appear to slow down for an outside observer. This is due to the phenomenon known as time dilation, which is caused by the strong gravitational field of the black hole.
Can a black hole destroy the entire universe?
No, a black hole cannot destroy the entire universe. While black holes are incredibly powerful, they are still bound by the laws of physics. They are not capable of destroying the entire universe, but they can have a significant impact on the surrounding space and objects.
