Dragonfall
- 1,030
- 4
Can someone give me a list of problems which at first sight require the axiom of choice, but do not?
Dragonfall said:Can someone give me a list of problems which at first sight require the axiom of choice, but do not?
Vitali's and Hausdorff's constructions depend on Zermelo's axiom of choice ("AC"), which is also crucial to the Banach–Tarski paper, both for proving their paradox and for the proof of another result:
Two Euclidean polygons, one of which strictly contains the other, are not equidecomposable.
They remark:
Le rôle que joue cet axiome dans nos raisonnements nous semble mériter l'attention
(The role this axiom plays in our reasoning seems, to us, to deserve attention)
and point out that while the second result fully agrees with our geometric intuition, its proof uses AC in even more substantial way than the proof of the paradox. Thus Banach and Tarski imply that AC should not be rejected simply because it produces a paradoxical decomposition. Indeed, such an argument would also reject some geometrically intuitive statements!
Ironically, in 1949 A.P.Morse showed that the statement about Euclidean polygons can be proved in ZF set theory and thus does not require the axiom of choice.
n_bourbaki said:Now change the word surjection to injection. Does the proof require AC, now?
Dragonfall said:Well for 2, since continuous functions map compact sets to compact sets, and the intervals where f is constant are compact, g(x) can be defined as the minimal element of f inverse of x.
1 is not possible without AC.
n_bourbaki said:Here's one where 'experience' may tell you to use the axiom of choice.
Suppose that S and T are infinite sets. Let f:S-->T be a surjection, and let g:T-->S be another surjection. Write down a bijection between S and T.
That requires the axiom of choice. Now change the word surjection to injection. Does the proof require AC, now?
fopc said:If I understand you correctly, we now have injections, and you ask for a bijection?
Schroder-Bernstein.
The classical proof of this theorem is a constructive-existence proof (no AC).
morphism said:There exists a subset of [itex]\mathbb{R}[/itex] which is not Lebesgue measurable.
fopc said:Schroder-Bernstein
n_bourbaki said:I always thought that did require the axiom of choice, something to do with viewing R as a vector space over Q? What's the non AC method?
No, I meant Lebesgue measurable. Apparently all you need to construct such a set is the Hahn-Banach theorem (which is strictly weaker than choice); see this paper by Foreman and Wehrung.gel said:Actually, that does require the Axiom of Choice (or something similar). Maybe he meant that there exists a subset of R which is not Borel measurable. That doesn't require AC.
morphism said:No, I meant Lebesgue measurable. Apparently all you need to construct such a set is the Hahn-Banach theorem (which is strictly weaker than choice); see this paper by Foreman and Wehrung.
n_bourbaki said:Here is the Conway paper I was thinking of.
http://citeseer.ist.psu.edu/cache/papers/cs/26688/http:zSzzSzmath.dartmouth.eduzSz~doylezSzdocszSzthreezSzthree.pdf/division-by-three.pdf
The Axiom of Choice is a mathematical principle that states that given any collection of non-empty sets, it is possible to choose one element from each set. This seemingly simple concept has far-reaching implications in the field of mathematics, particularly in set theory and topology.
The Axiom of Choice is important because it allows mathematicians to prove the existence of mathematical objects that may seem counterintuitive or impossible to construct without this principle. Many unsolvable problems in mathematics can only be solved by assuming the Axiom of Choice is true.
One of the most famous examples is the Banach-Tarski paradox, which states that a solid ball can be divided into a finite number of pieces and then reassembled to create two identical copies of the original ball. Other examples include the existence of a non-measurable set and the existence of a well-ordering of the real numbers.
No, the Axiom of Choice is a highly debated topic in mathematics. While some mathematicians accept it as a fundamental principle, others reject it or modify it to create alternative axioms. The debate around the Axiom of Choice has been ongoing since its introduction in the late 19th century.
The Axiom of Choice has implications in various fields outside of mathematics, such as computer science, philosophy, and economics. In computer science, the Axiom of Choice is used in algorithms and data structures. In philosophy, it has been used to argue for the existence of free will. In economics, it has been used to model decision-making processes.
