AcidRainLiTE
- 90
- 2
I recently disassembled my Big Screen CRT projection tv. I have been well aware of the danger of the capacitors in CRT TV's and I managed to take the TV apart and remove the capacitors all without killing myself. However, I was doing some more reading online and it seems there is another danger: the phosphors on the screen and the lead in the CRT glass. I assume the lead is not a problem unless the tube implodes and pieces get embedded in your skin, correct? My main question is about the phosphors. It is only a problem if you actually touch the phosphors right? I did not touch them, but I tried to remove the glass that was covering them, and was thus working around them. What I did was the following: First I removed the 3 lenses (there are 3 separate CRT's [one for each color--red,blue,green] and there is a lens on top of each of them), then I was curious about what was behind the lenses. I saw that there was a piece of curved glass in front of the phosphor screen and so I proceeded to take it off (i.e. remove the screws that were sealing it on), I wiggled it around a little trying to get it off and managed to pull the thing up a little but I couldn't get it entirely off. I got a very strong feeling that I should not be trying to remove it and so I gave up. I never actually touched the screen, though I am a little worried since I pulled back the piece of glass that covers it. So, I am just double checking, is there anything to be worried about (other than the fact that the three CRT tubes sitting on my bed are essentially bombs waiting to implode)?
Thanks.
Thanks.
