Exploring the Connection Between the Mind and Time Travel
In summary, the speaker went through a stage of wanting to disprove theories and in the process, discovered a potential method of time travel using the mind. This theory is based on the belief in a spiritual dimension and the connection between the physical and spiritual worlds. The speaker also introduces the concept of "inol energy" which has no time or particle intervention and is the force that holds dimensions together. They believe that dimensions are connected and lay inside each other, similar to how the spirit is connected to the physical body. The speaker also suggests that hyperspace and inol energy are the same thing.
is time travel with the mind possible?
  • yes
    Votes: 4 26.7%
  • no
    Votes: 7 46.7%
  • maybe
    Votes: 4 26.7%
  • Total voters
christian_dude_27
89
Recently, I went through a sort of "stage" where i wanted to disprove everything worth disproving, and we all know, if you move one card at the bottom of a stack, you change quite a bit. What i did was try to figure out the atomic theory structure.
I wanted to see if it was right. I came up with the conclusion that it has to be missing something, to have as many flaws as it does. And in the process of doing that, i ran across an amazing discovery, it is yet to be tested, to even be true or not, i have absolutely no mathematics to it, i myself am no mathematician, but i have a good understanding in physics.
I believe i have figured out how to time travel with the mind inside you. Now, if you don't believe in the spiritual dimension, turn away now, because this theory revolves around the belief that there is one. And i don't want anyone getting "angry" because i believe something they do not, that is pure ignorance. Ok, i was trying to figure out where the connection of the physical and spiritual worlds were.
It is obviously there, somewhere, because our spirit is able to control our physical body and yet be a "spirit" at the same time. This means that is connected to the physical world through a hole structure and not a solid structure. Put it this way, if you take a crochet blanket: the holes will represent inol energy (i will explain inol energy in a minute) and the solid lines represent the physical and spiritual worlds. the inol energy, in the crochet blanket, works in small groups and not as one whole, so if you were to try and control them in this state, you could only control one at a time.
While on the other hand, if they were like a comforter blanket, it acts as a whole and you could control them all as one large group of inol energy. Now, let me explain what inol energy is exactly. I was trying to understand the atomic structure, but it just didn't fit right with me. Negative and positive charges, attraction and repulsion, they just didnt mix together.
I discovered that without some force to push the electrons away from the protons it would cause a catostrophic end of the atomic structure, and i didn't want to see that. Some people tell me that it is the force of the electron's high speeds that holds it away from the proton. That is false, electrons can not move that quickly without causing a constant electrical disturbance, and from what i can see, i don't get electricuted constantly, do you? I didn't think so. I aggree, the electrons move relatively fast, but not fast enough to overcome the laws of electrical forces.
Yea, it's a simple idea, but if they were even able to move fast enough to keep from falling into the atom, well they would end up colliding with each other and we would see little electrical "pops" in mid air all the time, but we dont. So i thought id try and fix the problem. My solution said that electrons have negative charges (which we already know) and that all negative electrical charges ONLY repel, never attract. Well that goes completely against what i was taught in high school.
So i had to fix that as well; i believe i have. I included the inol force, from inol energy. Inol energy has no time or particle intervention. Basically the element of time travel. In ANY electrical charge or force, which ever direction the inol energy is flowing is also where the electrical forces flow. Now this force is powerful enough to overcome electrical forces. Even though electrons always repel, they can be held together by a much stronger force, like the inol energy. And da da da etc.
And you have electricity, ionic bonds, and all of that fun stuff. But it does go further. Electrons are everywhere, they make up the basics of our universe. I have reason to believe that the spirit is connected throught he brain. Here is one reason why i say that: during the medievil ages, when they cut people's head off, the head was still "alive and active" for at least ten seconds. So, without the rest of the bodily organs, what do you have left? the brain. And they brain is always giving off electrical charges isn't it? Inol energy is also what holds dimensions together.
But before you can understand that, you must realize that dimensions are not parallel. Instead they lay inside one another, connected and yet disconnected in various places. Here's an almost exact analogy: your body, and your spirit. If the electrical pulses in your brain stop, you spirit is no longer connected to the physical body, and you "die". But then there is the idea that a ghost/spirit usually has most of it's body parts (personally i think it is all a mind thing, most evcerything is.
The mind has quite a bit of power. If you can't picture yourself or "cant remember" having a head when it is cut off in the physical world, then you wonr have one. But if you can't picture it not being there, then you will have it. It is also controlled by what other peopel belive, the ghost/spirit itself may actually have a head, but if yor thoughts won't allow you to see that, it will make up a new picture using the signitures sent off from the spirit.) So, anyways, all dimensions lay inside each other just like the spirit lays inside our body. Well, that completley leaves out hyperspace..or does it? Hyperspace is just as much an object as space itself is (the aether).
And i believe the hyperspace is actually inol energy. They are one-in-the-same. So, with that in mind, we have slready said in past documents that hyperspace itself has no particle or time intervention, because it is "empty" of both, but it is an energy, simple energy with a force. And this hyperspace is connected and disconnected to all dimensions in various places. Which allows for multiple spirits, like ourselves. Now, to realize the facts: inol energy/hyperspace has no time or particle intervention but does have a force. our spirit is connected thrught he brain.
The brain sends out electrical pulses CONSTANTLY until it is dead. Thus inol energy exists in the brain, and also all other parts of the body. So, if you can astral project, and take your entire body with you, that means use the inol energy within your entire body, and surround yourself in inol energy, then you will be time traveling. The only tough part is geting back to where you want to go. Our mind is very powerful, and one thought can send you back to the ice age, literally.
So, NEVER TRY THIS UNLESS YOU HAVE A COMPLETE UNDERSTANDING OF IT (how to leave and how to come back). Imagine the possabilities. That is my idea of time travel with the mind, feel free to send comments and questions. I do have one correction to make on this theory. I have "murged" my theory with a friend of mine's theory, called jellotivity. (before you read mine, please read his, it should be on the forums here somewhere). Anyways, the idea of inol energy being an energy at all, is irrelevant. Instead, it is "jello" as explained in kama's theory of jellotivity.
Paragraphs are your friend.
win the lottery and i'll believe you :D
An argument that abounds with spelling mistakes and syntax errors is, more often than not, devoid of logical coherence and consistency as well.
Alternatively, if don't bother to show your readers the common courtesy of delivering your argument in a readable form, why should they bother to read it?
because you want to time travel
oh yes you know you do...
christian_dude_27 said:
i am new at this, posting forums, this is my first in fct, and feel free to make any comments that you wish, just do not be closed minded or i will ignore you..please be sure to read the entire forum, many times it answers most questions you ask, so don't be stupid and not read it and then ask me a question.
recently, i went through a sort of "stage" where i wanted to disprove everything worth disproving, and we all know, if you move one card at the bottom of a stack, you change quite a bit. what i did was try to figure out the atomic theory structure. i wanted to see if it was right. i came up with the conclusion that it has to be missing something, to have as many flaws as it does. and in the process of doing that, i ran across an amazing discovery, it is yet to be tested, to even be true or not, i have absolutely no mathematics to it, i myself am no mathematician, but i have a good understanding in physics. i believe i have figured out how to time travel with the mind inside you. now, if you don't believe in the spiritual dimension, turn away now, because this theory revolves around the belief that there is one. and i don't want anyone getting "angry" because i believe something they do not, that is pure ignorance. ok, i was trying to figure out where the connection of the physical and spiritual worlds were. it is obviously there, somewhere, because our spirit is able to control our physical body and yet be a "spirit" at the same time. this means that is connected to the physical worl through a hole structure and not a solid structure. put it this way, if you take a crochet blanket: the holes will represent inol energy (i will explain inol energy is a minute) and the solid lines represent the physical and spiritual worlds. the inol energy, in the crochet blanket, works in small groups and not as one whole, so if you were to try and control them in this state, you could only control one at a time. while on the otehr hand, if they were like a comforter blanket, it acts as a whole and you could control them all as one large group of inol energy. now, let me explain what inol energy is exactly. i was trying to understand the atomic structure, but it just didnt fit riht with me. negative and positive charges, attraction and repulsion, they just didnt mix together. i discovered that without some for to push the electrons away from teh protons it would cause a catostrophic end of the atomic structure, and i didnt want to see that. some people tell me that it is the force of the electron's high speeds that holds it away from the proton. that is false, electrons can not move that quickly without causing a constant electrical disturbance, and from what i can see, i don't get electricuted constantly, do you? i didnt think so. i aggree, the electrons move relatively fast, but not fast enough to overcome the laws of electrical forces. yea, its a simple idea, but if they were even able to move fast enough to keep from falling into the atom, well they would end up colliding with each toher and we would see little electrical "pops" in mid air all the time, but we dont. so i thought id try and fix the problem. my solution said that electrons have negative charges (which we already know) and that all negative electrical charges ONLY repel, ever attract. well that goes completely against what i was taught in high school. so i had to fix that as well; i believe i have. i included the inol force, from inol energy. inol energy has no time or particle intervention. basically the element of time travel. in ANY electrical charge or force, which ever direction the inol energy is flowing is also where the electrical forces flow. now this force is powerful enough to overcome electrical forces. even though electrons always repel, they can be held together by a much stronger force, like the inol energy. and da da da etc. and you have electricity, ionic bonds, and all of that fun stuff. but it oes further. electrons are everywhere, they make up the basics of our universe. i have reason to believe that the spirit is connected throught he brain. here is one reason why i say that: during the medievil ages, when they cut people's head off, the head was still "alive and active" for at least ten seconds. so, without the rest of the bodily organs, what do you have left? the brain. and they brain is always giving off electrical charges isn't it? inol energy is also what holds dimensions together. but before you can understand that, you must realize that dimensions are not parallel. instead they lay inside one another, connected and yet disconnected in various places. here's an almost exact analogy: your body, and your spirit. if the electrical pulses in your brain stop, you spirit is no longer connected to the physical body, and you "die". but then there is the idea that a ghost/spirit usually has most of it's body parts (personally i think it is all a mind thing, most evcerything is. the mind has quite a bit of power. if you can't picture yourself or "cant remember" having a head when it is cut off in the physical world, then you wonr have one. but if you can't picture it not being there, then you will have it. it is also controlled by what other peopel belive, the ghost/spirit itself may actually have a head, but if yor thoughts won't allow you to see that, it will make up a new picture using the signitures sent off from the spirit.) so, anyways, all dimensions lay inside each other just like the spirit lays inside our body. well, that completley leaves out hyperspace..or does it? hyperspace is just as much an object as space itself is (the aether). and i believe the hyperspace is actually inol energy. they are one-in-the-same. so, with that in mind, we have slready said in past documents that hyperspace itself ahs no particle or time intervention, because it is "empty" of both, but it is an energy, simple energy with a force. and this hyperspace is connected and disconnected to al dimensions in various places. which allows for multiple spirits, like ourselves. now, to realize the facts: inol energy/hyperspace has no time or particle intervention but does have a force. our spirit is connected thrught he brain. the brain sends out electrical pulses CONSTANTLY until it is dead. thus inol energy exists in the brain, and also al other parts of the body. so, if you can astral project, and take your entire body with you, that means use the inol energy within your entire body, and surround yourself in inol energy, then you will be time traveling. the only tought part is geting back to where you want to go. our mind is very powerful, and one thought can send you back to the ice age, literally. so, NEVER TRY THIS UNLESS YOU AHVE A COMPLETE UNDERSTANDING OF IT (how to leave and how to come back). imagine the possabilities. (please pardon my cronic typo errors, i type fast and really don't like to edit my work, so just bear with me) that is my idea of time travel with the mind, feel free to send comments and questions.
I saw at least one glaring error: "i type fast and really don't like to edit my work"
I really don't like to read materials where the writer is insensitive, impervious and totally ignorant of subjects such as the projected basic reading ease of her audience. This equated to comedians who don't like telling funny jokes.
Who the heck do you think you are, hey? It sounds like you are going to claim next that you've done a "pretty good job in making the rest of us in your images". I want my money back.
I stopped reading at
i thank you all for your comments, they mean a lot even though a lot of them were actually insulting, but yet still helped. i will work more on editing my work, and making it more formitable for others to read. i would however like to know what you thought of the actuall idea of time travel with the mind concept. just, ignore the typo's for now, i can fix them later, I am working on it right now as a matter a fact; i really would like to know what you think of the idea of time travel with the mind exactly. thank you all again.
i think you'd have to smoke some pretty potent crack to time travel with your mind :O
good luck in your endeavors
"they mean a lot even though a lot of them were actually insulting"
No one here has insulted you; however, you have insulted many by breaking basic rules of courtesy.
Hi christian_dude_27,
Please answer to a simple question:
What, in your opinion, is the difference between beanig alive and being dead?
well, erm try to be a bit neat with your messages please. anyway, your theory, to me, is very hard to imagine.
"i thank you all for your comments, they mean a lot even though a lot of them were actually insulting"
you have to except that you didn't make reading your theory any easier for members.
WWW- the difference of being dead and alive: dead=the electrical pulses in your brain has stopped, thus the spirit is no longer connected to your physical body. the spirit can exist in the physical world without being connected to the body, but with consequences of course. the consequenses no one knows, and I'm not about to pressure anyone with my religion, so i'll leave it at that. alive=the elctrical pulses in your brain are still in tact, and thus the spirit is still connected to your body.
12345- i am actually working on making my theory better for others to read and understand. it takes time, because i have to figure out certain analogies to explain this, it is quite hard to explain.
ok, i edited my work, it is up at the top. if you still see typo problems, could you please tell me where they are. my computer doesn't have MSWORD at the moment, so i don't have any type of word check.
Good editorial work cd27, but is it really necessary to start sentences with lower-case letters?
lol, well, i never have bothered capitolizing my beginning sentences. It seems as a complete nusence (how ever you spell that word), because everyone still knows what you're saying wether you capitolize or not, but I'm going to go back over it again and fix those mistakes as well, because obviously someone cares.
crack has absolutely nothing to do with it, in fact, crack destroys your brain cells and causes you to hallucinate, on some occasions. when hallucinations occur, it is because of the malfunctions of the electrical pulses in your brain. you are imagining images and so on, that are really not there. on the other hand, if you time travel with your mind, you bring your physical body along with you, so if anything were to happen to your body in another time or even in the projection from one dimensions to hyperspace to another dimension. remember, it is not tested yet, so the things that could happen to your body, or your mind, are endless as of now. you can time travel without taking your body with you. that is called astral projection and remote viewing. but the is a highly sceptical thing, because it is usually a one person thing, you have to have everyone around you know how to do this in order to get a group of people to go with you. the idea of bringing your body with you mean that you would have physical proof that you really traveled through time. and this way you won't need everyone to "pitch in" their mind to travel with you, you could carry them with you. and this way all of you would see how it works, or just see it.
christian dude 27,
When you astral projected yourself, can you see what you yourself will be doing an hour from now, a day from now, a year from now, or thousand years from now? If it's a thousand-year then you could be projecting yourself beyond your human life-span.
When you can astral project into the past and then you have forgotten something you did on a certain day, 10 years ago, your astral essence can go back to that date and recall or recover this lost memory in vivid details. You can practically see and determine and record all the simultaneous events at the time of your birth.
While in a state of astral projection can it be possible to be aware of other astral beings in the same state? or are you really all alone by yourself?
In physical reality, no two objects can occupy the same space but can all astral beings occupy the same space?
probably, i don't know that part, never tried it, lol. you may be able to see yourself in the future, or you might "be" yourself in the future. and someone once told me that once you astral project all of your lost memories should come back. i really want that, because i can't remember anything before the age 11 and I'm 17 right now. so yea, i kinda want to astral project. i think you would ahve to be specifically searching for otehr intities that are also astral projecting to be able to see them. but i think there are a lot of possibilities with astral projection. but what they usually do with that is only taking the spirit out of the physical body and then moving it to toerh places...what i was talkign about was moving the physical body and the spirit to hyperspace, which is the inol jello (i need to make one more corection about the inol jello as well. it is a sticky-like jello. because it also holds dimensions toegether. you put one glass plate on another, they'll slide off, but you put two glass plates together and put some sticky substance they'll kinda stay together. but you also need to realize, for inol jello to be "acsessable through the mind or any other part of the uiverse at all, there would ahve to be holes. so, here is an analogy: take your hands and cross your fingers together like you're about to pray. now hold them out strait but the fingers still inbetween each other. that's exactly how dimensions act. and you notice, they are not quite one whole yet, there are cracks. inbetween the cracks is inol jello. anywhere there is an electrical force there is inol jello. because for some reason electricity is able to jump between dimensions, like your brain having those electrical pulses and that is why your spirit and body are able to connect. also, if any two things ever occupy the same space, if they are n the same dimension, they will become one, and basically do as if you melted two metals together, they would exist in each others pores.
You should try to define "spirit" before developping theories concerning it.
...ok, who the heck does not know what a spirit is? ok, put it this way, take a dead carcas, it has no personality, it doesn't move, it does nothing but rot...when a spirit is in it, it does al the things you are doing now; living, thinking, breathing, acting stupid, giving stupid replies, things in that nature.
So animals have spirits? Does a spirit require a body?
Does the bacteria causing the corpse to rot have spirits?
What is the difference between spirit and physical matter and how they are related to each other?
Electrical pulses inside atoms do not stop when we are dead, so please explain us why being alive is not just higher organized complexity of the same pulses, which collapses to lower organized complexity level when we are dead?
What I want to say is: What you call a living thing is actually a cybernetic complex system that can transfer its complexity (mental and physical) through time before it is collapses to a lower complexity level.
all living things have spirits, insects, bacteria, plants, all of it. you may not notice it because of how much more intelligent you are to them, but have you ever actually sat down and looked at them? ants, they defend their homes at any cost when a preditor atempts to attack them, they scavage for food, and they strive to survive, all of those are characteristics of intelligence. plants, they grow towards the sunlight so they can get their food, they grow towards water so they can get that as well. they protect themselves with thorns and other things like that. those are also characteristics of intelligence. it doesn't mean it's very high intelligence, but it is. plants can't even communicate, well, some of them can, but most can't, that jst means their intellgence isn't high enough to obtain that knowledge. heck, it even took us a good long while to learn to communicate. lok at a small baby, those little kids learn like lightning. very fast, that is pretty high intelligence. once you see that, you wil learn the value of other living things and their intelligence.
ok, the relation between the physical and spiritual matter. for one, spirit is not matter, not even close. electrical pulses open the door for other dimensions, not the spiritual one alone. but what holds those dimensions open is inol jello. let's just say it's kind of like the "matter" of the spiritual dimension. only electrical charges are able to hold it together as an active substance though. without that, there is not spirit. it then only exist in the spiritual dimension. alo, the part of the spirit that connects teh brain is where the personallity and commands come from, even if the rest of your body is giving off electrical pulses, the high energy pulses in your brain must be intact for it to connect the spirit. even if you had just the regular jumps from the electrons, it isn't high enough to work, so you're then considered "dead".
falinte badabits arwi?
Look christian_dude_27,
In my opinion, you need to learn more about basic scientific concepts
For example:
1) The internal forces that govern the sub-particles inside an atom.
2) Complexity theory.
3) Evolution.
4) Chaos theory.
5) Quantum mechanics.
6) Logic.
7) Information theory.
If you do not have any general knowledge in some of those examples,
Then you cannot use scientific concepts with your beliefs, because your
Beliefs mixed with your lack of knowledge in basic scientific concepts
Looks like a very poor cocktail.
for one, i am a christian, so evolution is screwed in my eyes, two, i have a pretty good understanding of quantum mechanics and general relativity, i have more logic than a lot of people on this piece of crap planet (by which they are still destroying without cause), and i have very extensive study on the stomic structure theory..yea, that's right, it is still a theory, just as much proof on it as thre is my theory. why can't anyone see the facts around them? how else do you think all of these phenomenas happen? they aren't just made-up stories, because if they were, they would not come from such small places where no one gives a flying cow turd about physics. i have actually seen someone levetate a house, not a very big one, but a house indeed, three feet above the ground. say what you want to say, but it wasn't a magic "trick". if someone can be closed minded enough to not realize that everything being taught to them in all schools have just the same possibility of being absolutely wrong as they do being absolutely right. i don't trust any "theories" any more than i do my own, I'm just trying to find the truth just like everyone else. i know that no one will ever find it until god takes the world back, but i still have that thrive. one more thing, the weak and strong forces, that's a crock of crap. i really don't even think "atoms" exist, but i still go right on along with it because everyone else does. and if you stick out like a bad sore, you end up going to the luny bin, and that aint about to happen. time travel with the mind is very possible. you always have to look at the possibilities. you see, i know there is a great possibility of my theory being completely wrong and completely stupid, but you know what? i can also see that everything we have "thouht" we knew could also be completely wrong and i could be completely right. there is always that possibility. it is your choice to believe me or not, if you don't believe me, don't bother sending a reply to this message, because i could care less. if you have questions about it, yea, i'll answer those the best i can. but I'm only human, i make mistakes, just as many as you and everyone else around you does, so just live with it, that's all you can do anyways.
what the heck does that mean?
Hmm, interesting. If I take the battery out of my watch it just sits there and rots (well, rusts). However, when I put the battery in it ticks and tocks and does all the things it is doing now.
Does that make my watch battery a spirit?
Matt
  • #31
no, you see, for a spirit to exist, something has to want it to exist, perhaps like a god, if you believe in one. but an alternative for that would be: if your watch had enough artificial intelligence, it may possibly cause a jump in the spiritual dimension to "create" a spirit. remember, for something to ahve a spirit, it msut have "some" level of intelligence. a watch only has a program, no natural intelligence, it can not produce another of its kind through birth and let it grow and develope with a spirit, can it? no, it has to be "remade" and "copied" over and over again to make another one, so no, it has not got a spirit. clones, they are the one thing that are "remade" and "copied" that do have spirits. because, even thought hey wwere remade and copied, they can still go on by themselves and continue creating newborns naturally.
  • #32
levitate a house?
you sure you weren't stoned watching TV that day?
not saying you do drugs just sayin maybe someone snuck something into your drink or something
  • #33
..ok, you are officially an idiot. i don't drink, i don't smoke, i don't do anything like that crap. and I'm pretty sure i would know if i was ever "stoned" or anything. and yes, I've seen someone levetate a house. i don't see why it's so freaking hard to believe the possibility that things CAN be done. for crying out loud, you got people out there who believe we all came from monkeys, why is levetating a house any different? i know it's not something you see everyday, but that doesn't mean it can not happen. EVERYTHING has the possibility of being possible. remember that, because as long as you study physics at all, you have to BELIEVE that what you are being told is real. for crying out loud, the atom that everyone is so consumed with is still yet a theory, simply a theory. even to this day, my school's physics textbook says, first thing on atomic struction, is that it is a theory, nothing else. nothing is impossible, but many things are impobable, including us. think about that for a good long while. you could learn alot.
  • #34
What is "enough artificial intelligence" ? What is this level of intelligence required?
so that means that mules don't have spirits? Isn't it an animal ?
  • #35
ok, mules can reproduce, can they not? if a mule were to have sex with another mule, there would be a baby mule right? supposedly, unless there is something seriously wrong with your mule, like, if a rabbit pops out, you might want to get that checked. the amount of artificial intelligence needed would be the amount needed so that the machine could reproduce itself as a natural animal does. that means through the cells and growth and learned knowledge over year spans.
  • Other Physics Topics
  • Poll
  • STEM Academic Advising
