gimini75
- 52
Hello
Thanks for you help, I have to design a gearbox which will be connected to an electrical motor with a 11 Kw, 960 rpm, 42 mm shaft diameter, I want the gearbox to rotate a sprocket with a diameter of 337 mm in a speed of 40 rpm, I don't know how the gearbox is to be designed for the pinion and the gear diameter and ratio, and also I don't know what's the output shaft diameters, it's length it should be and which materials I should choose for the gears and for the shaft,if anyone can help please tell how can I do that gearbox calculations.
Thanks for your help
