Chopper Transistor: Significance & Pulse Generation Explained
  • Thread starter TheAnalogKid83
  • Tags
    Transistor
In summary: Semantics, semantics... For as often as it's employed here (guilty as charged!), a hand-wavy smilie would sure come in handy! :tongue2:
TheAnalogKid83
174
Can anyone explain to me what is the significance of a chopper transistor as opposed to a normal BJT? I read online that its used for square wave pulse generation, but I don't really understand what the mechanism is.
Thanks
Thanks
A BJT, MOSFET, JFET, etc. is a device.
A chopper transistor is an application of the above. If it's the chopper transistor I'm thinking of, it just means a transistor used to generate a square wave from a DC supply. The mechanism for doing this is some kind of back-end circuitry (there's lots of ways of doing this, with a 555 timer, for instance) which controls the transistor, turning it on and off as necessary to generate the square wave.
Ok, so what distinguishes it as a transistor to be used for chopping applications? As in, why are there parts sold specifically labeled as chopper transistors? What spec or mechanism makes it characterized for this application? Or else you should be able to use any general purpose transistor that meets your applications requirements. But these are specifically sold as chopper transistors.
Example: http://www.centralsemi.com/PDFs/products/CMPT404A_R1.PDF
"designed for chopper
applications."
A chopper transistor doesn't need to be highly linear for low distortion. Instead the most important parameters are probably the Vce(sat), Ic(max), Pd(max), rise time (tr) and fall time (tf).
Probably just properties that are good in chopper applications. You probably *can* use regulator transistors (provided they meet your minimum requirements). Off the top of my head, I'd guess fast transition times (less slew) and high breakdown voltage (to handle inductor transients--since choppers are frequently used to drive motors or in switch mode power supplies, which would rely on the transient response of an inductor to generate high or negative voltages).
EDIT: Beaten by the skeptic
Ah thank you very much. So its a switching transistor that can handle spikes that you might normally use a snubber diode for protecting. And you aren't going to try to use it as a small signal amplifier in the active region, so the linear characteristics are not designed for with priority. A high voltage switching BJT that isn't necessarily a high power device.
So this would make sense, as in my application it is in use with an antenna device that may create inductor voltage spikes.
Um, are you saying that you want to drive an antenna with a square wave? Why?
Its being used as part of a switch to power an active antenna. So basically this chopper will turn on and off the DC voltage path to the antenna dependent on a few conditions (open antenna or short antenna fault detection, enable/disable antenna).
By "active antenna", do you mean a receive-only antenna with a preamp, or do you mean an active array antenna that is electronically steerable?
Receive only, low-noise amplifer antenna with a fixed frequency range
Shouldn't that be, "(provided they meet your maximum requirements)"?
Semantics, semantics... For as often as it's employed here (guilty as charged!), a hand-wavy smilie would sure come in handy! :-p
i'm a nerd
FAQ: Chopper Transistor: Significance & Pulse Generation Explained
What is a chopper transistor?
A chopper transistor is a type of transistor that is used to switch an electrical signal on and off in a pulsating manner. It is typically used in electronic circuits to convert a continuous signal into a pulsed one.
What is the significance of a chopper transistor?
A chopper transistor is significant because it allows for the control and manipulation of electrical signals in a precise and efficient manner. It can be used in a variety of applications, such as pulse generation, power conversion, and signal modulation.
How does a chopper transistor generate pulses?
A chopper transistor generates pulses by rapidly switching the electrical signal on and off at a specific frequency. This is achieved by varying the bias voltage applied to the transistor, which controls the flow of current through it.
What are the advantages of using a chopper transistor for pulse generation?
One of the main advantages of using a chopper transistor for pulse generation is its ability to produce precise and stable pulse widths and amplitudes. It also has a fast response time and can handle high power levels, making it suitable for a wide range of applications.
How is a chopper transistor different from a regular transistor?
A chopper transistor is different from a regular transistor in that it is specifically designed for pulse generation and signal modulation. It has a more complex structure and can handle higher voltages and power levels. Additionally, a chopper transistor has a faster switching speed and lower losses compared to a regular transistor.
