Is Silicon Transparent to Infrared Light?
Silicon is not 100% transparent to infrared (IR) light; it exhibits high transmission rates but also experiences some absorption, refraction, and reflection. The transparency of silicon to IR light can vary based on factors such as temperature and the specific wavelength of the IR light. References provided include a paper from Virginia Semiconductor and links to additional resources for further understanding of silicon's optical properties. The discussion highlights that while visible light transmission through silicon is high, IR transmission is lower, with maximum values noted to be just below 60%. Overall, silicon's interaction with IR light is complex and not entirely transparent.
rr00053
hi everyone...
i have got a general doubt...I have heard that silicon is transparent to
infrared...so does that mean that any IR wave entering silicon comes out of it without any change? Is silicon 100% transparent to IR? does the transparency depend on temperature or any other parametre?
Can anyone give me some reference material, suggest some books or some links where i can get data about silicon transparency?
please hep me...
thanks in advance...
Well, it's about the same as, for instance, glass for optical wavelengths. It looks more or less transparent, and the transmission is in the high 90s, but there is some (small) absorption and some refraction and a small bit of reflection. There's a mask aligner in the place I work at that uses backside IR illumination so you can align masks to features already present on the silicon. Haven't used it myself, however.
Here's a paper from Virginia Semiconductor (they make custom silicon)--this is targeted mostly to researchers, and it may be difficult to understand without some optics background:
http://www.virginiasemi.com/pdf/Optical%20Properties%20of%20Silicon71502.pdf
Hi matlabdude,
thanku very much for the response and the reference u gave...taking a quick look at the data u gave and the data andy resnick gave...the maximum transmission seems jus below 60%. however u pointed out tat transmission is at high 90's ...
anyway thanyou for the data you gave...
HI andy resnick,
thanku for the valuable links...
rr00053 said:
Hi matlabdude,
High 90s is visible light through a thin piece of glass (I was laying down the groundwork in case you didn't have any background)
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 22 ·
  • · Replies 16 ·
