Gaining Orbital Energy from Sun's Gravity-Assist Flyby
  • Thread starter Jorrie
  • Tags
    Sun
In summary: If a spacecraft from Earth is "directly" boosted towards Jupiter for a gravity-assist that boosts its energy further relative to the Sun and takes it to Saturn (Cassini-like), at Saturn its orbit is arranged for a flyby that does two things: slingshot it to back to near the Sun at somewhat above solar escape velocity, having robbed some of Saturn's orbital energy. (If it had the means of propulsion, an advanced technology could just as well have shot the spacecraft 'directly' from Earth to the vicinity of the Sun, ensuring that it exceeds escape speed of the Sun).The spacecraft passes as close as possible "behind" the Sun (relative to the Sun's galactic orbit) and
Jorrie
Insights Author
141
The use of gravity-assist flybys of planets are well known for interplanetary missions. My question: can a Sun flyby be used to gain orbital energy relative to the Galactic center for interstellar missions?
I assume one must first attain solar escape velocity by other means, since bound orbits around the Sun cannot gain flyby energy. I also assume one can arrange the open orbit such that the spacecraft passes just behind the Sun in its galactic orbit.
If this has already been discussed, my apologies - just point me to the thread.
-J
Astronomy news on Phys.org
No, for two reasons. (1) The trajectory needs to take the vehicle fairly close to the planet to make the gravity assist effective. (2) The Sun's orbital velocity around the Sun-Jupiter center of mass is about 74 meters/second. There's not much velocity to steal.
But the Sun's orbital velocity around the Galactic center is some 220 km/s, which is more relevant to the question.
We already have that velocity... The Sun might be useful to a traveler coming in from another galaxy. But I presume that was not what you had in mind.
Isn't arriving at the Sun at or above solar escape velocity (as per OP) equivalent to coming in from another star? With planetary gravity assist, all that is required is coming in correctly at or above the planet's escape velocity.
Hi there,
Not at all. When leaving, heading toward the Sun, you already have that 220km/s velocity. We are on Earth, which is following the Sun (hopefully for us), therefore, we live in roughly the same reference as the sun, therefore having the same velocity.
fatra2 said:
Hi there,
In the same way, the craft doing a flyby at Earth already has Earth's 30 km/s relative to the Sun. Yet, it can get a delta-V in heliocentric coordinates if it comes in at a relative speed above Earth's escape velocity and at the right angle, passing 'behind' Earth. Why can't this principle work in Galactic coordinates with the Sun as well?
Hi All. OK, it looks like since I've asked a 'half-baked' question, I've got a few 'half-baked' answers! :smile: Let me try and state the question more clearly.
I think it is accepted that if a spacecraft were to come from in another star's vicinity, naturally arriving in the vicinity of the Sun at a speed exceeding solar escape speed, it could get a gravity-assist energy boost from the Sun. With this is understood that the spacecraft gained some mechanical orbital energy in Galactic coordinates.
Now let a spacecraft from Earth be 'directly' boosted towards Jupiter for a gravity-assist that boosts its energy further relative to the Sun and takes it to Saturn (Cassini-like). At Saturn its orbit is arranged for a flyby that does two things: slingshot it to back to near the Sun at somewhat above solar escape velocity, having robbed some of Saturn's orbital energy. (If it had the means of propulsion, an advanced technology could just as well have shot the spacecraft 'directly' from Earth to the vicinity of the Sun, ensuring that it exceeds escape speed of the Sun).
The spacecraft passes as close as possible 'behind' the Sun (relative to the Sun's galactic orbit) and naturally exceeds local solar escape velocity. Is there any reason why this spacecraft cannot receive a gravity-assist delta-V from the Sun? In other words, why would this scenario not be equivalent to a spacecraft coming in from another star?
A gravity assist is basically a transfer of momentum from one object (in this case the Sun) to another(the spacecraft ), where gravity provides the mechanism of the momentum transfer. It is essentially an elastic collision without the physical contact.
So let's use an elastic collision to explain what's going on.
Let's say you have a massive truck moving down the road at 100 kph. We are standing at the side of the road holding a small ball. We toss the ball forward at 10 kph, so that passes in front of the truck and the truck hits it. At the moment of impact, the ball is moving forward at 10 kph and the truck 90 kph, so the relative velocity velocity of the two is 90 kph.
Upon impact, the ball rebounds from the truck with the same 90 kph relative speed, but its relative velocity is in the opposite direction, so that relative to you it is moving 90 kph + 100 Kph = 190 kph. It has picked up 180 kph relative to the road in the collision.
This is more or less how a standard gravity assist works.
Now imagine that you are traveling along the road just ahead of the truck at 100 kph. You want to duplicate the impact of the above experiment. This means that you have to throw the ball backwards at the truck at 90 kph. The ball hits the truck, rebounds and then passes you with a relative velocity of 90 kph in the forward direction (again moving 190 kph relative to the road.) But that is just as fast as you threw it; you would have done just as well if you had just thrown the ball 90 kph forward in the first place. You gained nothing by bouncing the ball off of the truck.
This is what you are trying to do by using the Sun in a gravity assist for a spacecraft launched from within the Solar system. You wouldn't gain anything by matching the velocity of an incoming object in order to cause it to whip around the Sun over just launching your spaceship in the direction of the Sun's galactic motion to begin with.
(Besides, it is a lot easier to use an outer planet to give a probe a gravity boost that takes it directly out of the Solar system than it is to try give it velocity boost while at the same time kicking it in toward the Sun.)
Thanks for the very clear explanation Janus. I understand now.
Of course you can still get a decent gravity well boost from a solar "fry-by" and doing a perihelion burn. Even more of kick can be gotten from doing likewise around a white-dwarf, but naturely much closer than you can get to the Sun. And then there's the super-boost you can extract from a Dyson gravity machine - twin white-dwarfs in very close orbits, which can boost you to ~3,000 km/s or so.
FAQ: Gaining Orbital Energy from Sun's Gravity-Assist Flyby
How does a gravity-assist flyby work?
A gravity-assist flyby, also known as a gravitational slingshot, is a technique used by spacecraft to gain speed and change trajectory by using the gravity of a planet or other celestial body. The spacecraft approaches the body at a specific angle and speed, and the body's gravity pulls the spacecraft, accelerating it and changing its direction.
Why is the Sun's gravity used for a flyby?
The Sun's gravity is the most powerful force in our solar system, making it an ideal candidate for a gravity-assist flyby. The Sun's massive size and gravitational pull allow spacecraft to gain significant amounts of energy and speed, making it a cost-effective way to travel long distances in space.
How does a spacecraft gain orbital energy from a Sun's gravity-assist flyby?
During a gravity-assist flyby, a spacecraft's velocity increases as it approaches the Sun, and then decreases as it moves away. This change in velocity results in a change in the spacecraft's orbital energy, with the spacecraft gaining energy as it moves away from the Sun. This energy can be used to reach farther destinations or to enter a higher orbit around the Sun.
What are the advantages of using a Sun's gravity-assist flyby?
The main advantage of using a Sun's gravity-assist flyby is that it allows spacecraft to travel long distances in space using minimal amounts of fuel. This is especially beneficial for deep space missions, where the amount of fuel required for propulsion can be extremely costly. Additionally, a gravity-assist flyby allows for precise trajectory adjustments, making it a valuable tool for navigating through space.
Are there any risks involved with a Sun's gravity-assist flyby?
While a gravity-assist flyby is a common and well-understood technique, there are still some risks involved. If the spacecraft's angle and speed are not precisely calculated, it may not gain enough energy from the flyby or could even be flung off into space. Additionally, there is a risk of collision with debris or other objects in space during the flyby, so careful planning and monitoring are crucial for a successful mission.
