Non-Symplectic Flows: Excluded Dynamics in Symplectic Mechanics
  • Context: Graduate
  • Thread starter Thread starter mma
    Flow
The discussion revolves around the nature of non-symplectic flows within the framework of symplectic mechanics, particularly focusing on whether certain flows on even-dimensional orientable manifolds can exist without any invariant symplectic form. Participants explore the implications of such flows and the types of dynamical phenomena that may be excluded from symplectic mechanics.
  • One participant questions the generality of symplectic mechanics and proposes that non-symplectic flows might still be represented by an invariant symplectic form on the manifold.
  • Another participant discusses the behavior of fixed points in relation to Lefschetz maps and suggests that Hamiltonian diffeomorphisms could provide insights into the invariants of such flows.
  • A participant seeks clarification on the concept of Lefschetz maps and their relevance to the discussion of flows.
  • It is explained that Lefschetz maps have only isolated fixed points and that there is a relationship between vector fields and diffeomorphisms on compact manifolds.
  • One participant suggests that non-symplectic flows could be exemplified by flows that violate the Arnold Conjecture, though they acknowledge the difficulty in providing specific examples.
  • Another participant proposes that a gradient flow with fixed points could serve as a simpler example of a non-symplectic flow, as it would not preserve volume.
Participants express differing views on the nature and examples of non-symplectic flows, indicating that multiple competing perspectives remain without a clear consensus on the topic.
Some assumptions about the definitions and properties of flows, symplectic forms, and Lefschetz maps are not fully explored, leaving certain mathematical relationships and implications unresolved.
mma
Symplectic mechanics deals with symplectic flows. I wonder, how general this description of the possible (or imaginable) dynamical phenomena is. If a given flow on a symplectic manifold turns to be non-symplectic, then perhaps we can find another symplectic form on the manifold that is invariant to the flow, that is, this flow can remain inside the relam of symplectic mechanics.
Are there flows on even dimensional orientable manifolds that don't have any invariant symplectic form? If yes, then what look they like? In other words what kind of dynamical phenomena are excluded from symplectic mchanics?
I guess the clearest delineation would be behavior of fixed points. A clear example (though perhaps not what you're looking for) is that if we look at a smooth Lefschetz map on S^2, there will be infinitely many periodic points. This is not the case if you weaken the condition to homeomorphism, or even a C^1 diffeomorphism (there is one with exactly two periodic points).
I guess this question falls under the umbrella of Hamiltonian diffeomorphisms. One looks for invariants for any Hamiltonian diffeomorphism, so that one can get away from a fixed symplectic form.
This sounds interesting, but I'm afraid that i don't really understand it. What is Lepschetz map? Is it that there is in the http://en.wikipedia.org/wiki/Lefschetz_manifold" artcle in Wikipedia?Then where is the flow we talk about?
A lefschetz map is a smooth map from a manifold to itself with only non-degenerate fixed points (i.e. the Jacobian does not have 1 as an eigenvalue). Any Lefschetz map has only isolated fixed points. A symplectomorphism would be such a map, but there are others.
The interplay between diffeomorphisms and flows of vector fields on a compact manifold is very straightforward. If we have a vector field, it generates a one-parameter group of diffeomorphisms. Going the other way, if we can represent a given diffeomorphism as the time-one (say) realization of the flow of a vector field, you'd say that the diffeomorphism is isotopic to the identity.
Precisely.
Wouldn’t it be easier to take a flow on S^2 that is not area-preserving? So is for example a gradient flow with 2 fixed points - source and sink. Then it cannot be a symplectic one, as any symplectic flow is volume-preserving.
(http://homepages.cwi.nl/~jason/Classes/numwisk/ch16.pdf)
  • · Replies 28 ·
  • · Replies 36 ·
  • · Replies 19 ·
11K
  • · Replies 24 ·
