Lifting vs Pulling: Chain Hoist vs Hand Winch
  • Thread starter Thread starter Gsu student
    Lifting
The discussion highlights the differences between chain hoists and hand winches (come-a-longs) in terms of strength and application. A chain hoist is typically more robust, designed to lift heavy loads directly against gravity, requiring significant force due to gravitational pull. In contrast, a hand winch can pull the same weight but relies on overcoming friction, which is generally much lower, allowing for lighter construction. The safe working load (SWL) of both devices can be the same, but chain hoists often have higher ratings due to their construction and intended use. Ultimately, while both can handle similar weights, the mechanisms and forces involved differ significantly.
Gsu student
Ok so I was at the store today and I notised that the hoist they sell seam to be a lot beefyer and stronger lookin them the come a longs ie hand winches and I was wondering why that was dose it take more force to lift 2 ton then it takes to pull the same, I was looking at a 1 ton chain hoist and it's all steel and thick chain looks real strong yet right next to it is a 4 ton puller made from thin steal and wire rope, now granted the puller dose use a pullie but that dosent change the fact that the force on the unit is still greater
if anyone can help please let me know. Would a chain hoist pull more that a similar rated hand winch?
Force required to lift has to overcome gravity
F = mass* gravity
Force required to pull has to overcome friction.
Friction Force = Force from gravity * Friction coefficient.
Friction fore is much smaller then gravitational force, as coefficients of friction are much less then 1 usually.
Yes it's a question of force.
If you lift a 1 ton object you need a force of 1000kg * 9.8m'/s^2 (ie g) = 9800N
To pull the same object would depend on the friction between the object and the surface, for steel wheels on a steel rail (such as a railway car) the friction would be about 0.1% so you only have to pull with a force of 9.8N, equal to lifting only a 1kg.
For very low friction like oil bearings it's possible to push huge masses, like a 100ton telescope, with almost a finger tip.
If the chain hoist and the come-a-long have the same SWL (safe working load) of 2 tons (or whatever), then they can pull or lift the same amount. The position is irrelevant. I can take a come-a-long (puller) rated for 2 tons (SWL) and use it vertically to lift 2 tons.
What you are probably noting is that most come-a-longs have typically lower SWL's than do chain hoist for the reasons stated above.
CS
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
10K
