What is the difference between these two probability problems?
  • Context: Undergrad
  • Thread starter Thread starter davedave
    Difference Probability
The discussion centers on the probability of achieving a sum of 20 when rolling five six-sided dice, either simultaneously or sequentially. Both scenarios yield the same probability due to the identical nature of the dice, which means the order of rolls does not affect the outcome. To solve these problems, one can utilize the event space represented as {1,2,...,6}^5 and determine the coefficient of x^20 in the polynomial expansion of (x + x^2 + x^3 + x^4 + x^5 + x^6)^5. Tools like Wolfram Alpha can simplify this calculation significantly.
  • Understanding of basic probability concepts
  • Familiarity with polynomial expansions
  • Knowledge of generating functions
  • Experience using computational tools like Wolfram Alpha
  • Learn how to calculate probabilities using generating functions
  • Explore combinatorial counting techniques for dice problems
  • Study the application of polynomial coefficients in probability
  • Practice solving similar probability problems with different sums and dice
Students, educators, and enthusiasts in mathematics, particularly those interested in probability theory and combinatorial analysis.
davedave
I happened to come across these two probability questions in a library book.
1) Suppose that you roll 5 six-sided dice at the same time. What is the probability of getting
a sum of 20?
2) Suppose that you roll a six-sided die 5 times. What is the probability of getting a sum of
20 on the 5 rolls?
What is the difference between these two problems?
What methods are used to solve them?
Good question. If the dice are identical then the final answer will be the same because the order of the dice rolls doesn't affect the outcome of the sum. The event space of dice rolls can be written as {1,2,...,6}^5 = {(1,1,1,1,1),(1,1,1,1,2),...,(6,6,6,6,6)} with all events equally probable, so you'll need to find a way of counting the number of events with sum 20.
An easy way (given modern technology) of counting the number of events that sum to 20 is to observe that it is the coefficient of x^20 in (x + x^2 + x^3 + x^4 + x^5 + x^6)^5.
Just type "expand (x + x^2 + x^3 + x^4 + x^5 + x^6)^5" into Wolfram Alpha and hit Enter.
You can also find the coefficient of x^20 by paper and pencil methods-- it's not that hard, just a little more work.
  • · Replies 16 ·
  • · Replies 41 ·
