Inverse relationship - neutron flux density with sunspot cycle
The discussion revolves around the inverse relationship between neutron flux density and the sunspot cycle, exploring the mechanisms behind this phenomenon. Participants examine the implications of solar magnetic activity on cosmic rays and their effects on electronic equipment reliability, as well as the nature of cosmic rays originating from both solar and galactic sources.
  • One participant notes that neutron counts measured at Oulu vary inversely with sunspot counts, suggesting a relationship influenced by solar magnetic activity.
  • Another participant proposes that during periods of high sunspot activity, the solar magnetic field expands, potentially shielding Earth from galactic cosmic rays (GCRs).
  • A later reply challenges the idea that the heliosphere can block galactic neutrons, clarifying that neutrons are neutral and do not interact with the heliosphere, while most cosmic particles are charged protons and alpha particles.
  • One participant references a document suggesting that increased sunspot activity may enhance electronic equipment reliability due to the protective effects of the solar magnetic field, contrasting with their initial belief that solar activity correlates with increased equipment failures.
  • Participants express confusion regarding the relationship between solar cosmic rays (SCRs) and GCRs during sunspot maxima, particularly concerning their energies and effects on neutron flux.
Participants do not reach a consensus on the mechanisms underlying the inverse relationship between neutron flux density and sunspot cycles. There are competing views regarding the effects of solar activity on cosmic rays and electronic equipment reliability.
Participants highlight uncertainties regarding the interactions between solar magnetic fields, cosmic rays, and neutron production, as well as the implications for electronic equipment reliability. The discussion reflects varying interpretations of the data and mechanisms involved.
lemonstar
Just over half-way down this page:-
http://www.embedded.com/columns/technicalinsights/220301380?cid=RSSfeed_embedded_news
it says:-
"These sunspot counts show variation on a cycle of roughly 11 years. By overlaying Oulu neutron measurements with sunspot count data since 1964, we see that the neutron count measured at Oulu varies inversely with the sunspot count (Figure 3 below)."
Can someone explain this? I can't get a satisfactory clear explanation from Googling - AFAIK the solar magnetic (which affects the Earth's magnetic field) changes over the 11 year cycle. There are 2 main sources of "cosmic rays" several specific galactic sources (GCR's) and the sun (SCR's) itself.
http://wattsupwiththat.com/2009/03/...uggest-we-may-not-have-hit-solar-minimum-yet/
is also helpful but I'm not clear about the mechanisms underlying this inverse relationship.
I don't know if I understand exactly what is happening during the the sunspot maxima. Does the solar magnetic field during the maxima offer more protection from the GCR's? What happens to the SCR's during the maxima? (I thought they increased - originating from the solar flares). This article does say:-
"Most solar cosmic ray events correlate relatively well with solar flares. However, they tend to be at much lower energies than their galactic cousins."
I assume the correlation is positive (not negative) but it seems to say that SCR's also increase but because they are less energetic does this mean that overall, taking into account the more important factor(?) that because there is an increase in protection from the GCR's(due to influence of solar magnetic fiel), there is a minima in the neutron flux at sea level? Shouldn't this correlate with a decrease in the number of failures in electronic equipment using FPGA's during periods of high sunspot activity? I thought the relationship was the other way around, i.e. more failures during high sunspot activity. As you can tell - I'm slightly confused.
cheers
Neil
Astronomy news on Phys.org
twofish-quant said:
What seems to happen is that when sunspots are active, the magnetic bubble that the sun is in gets bigger, and that keeps galactic neutrons from getting to earth. Cool...
The magnetic bubble (the heliosphere) cannot keep galactic neutrons from getting to the Earth. Neutrons are neutral and don't interact with the heliosphere. Fortunately, there aren't very many galactic neutrons. The vast majority of cosmic particles are protons, and almost all the rest are alpha particles (helium nuclei). A zoo of particles, including neutrons, is generated when these charged particles hit the Earth's upper atmosphere. The vast majority of the neutrons observed by the detectors mentioned in the original post are secondary radiation products resulting from charged cosmic particles hitting the atmosphere. What the heliosphere does do is to keep those charged cosmic particles from getting into the solar system.
I read this:-
www.actel.com/documents/FPGA_Reliability_WP.pdf
It looks like increased sunspot activity is a "good thing" for electronic equipment reliability because of the shielding effect that the increased solar magnetic field has - I had originally thought that the mass ejections from the sunspots was linked to an increase in electronic failures but it doesn't seem that that is the case. Can someone confirm that? Apart from the link above has anyone seen a document anywhere linking the cause and effect i.e. sunspot activity to equipment failure?
9K
  • · Replies 21 ·
