Vector expressed in a basis noncoplanar, neither orthogonal nor of unit length
The discussion centers around the representation of a vector in a noncoplanar, nonorthogonal, and non-normalized basis. Participants explore the necessity and benefits of using reciprocal bases in tensor calculus, particularly in relation to projecting vectors onto axes defined by such bases.
  • One participant presents the expression of a vector in an orthonormal basis and seeks to generalize it to a nonorthogonal basis, questioning the need for reciprocal bases.
  • Another participant argues that projecting a vector onto a non-orthogonal basis using the initial equation is invalid, as it would yield additional terms due to the lack of orthogonality.
  • A different participant suggests that while the proposed method of using dot products is valid, it may be more complex than using reciprocal bases, which simplify the calculations.
  • One participant proposes an alternative projection formula that does not utilize reciprocal bases and asks for feedback on its validity compared to the reciprocal base approach.
Participants express differing views on the necessity of reciprocal bases, with some advocating for their use due to simplification of calculations, while others believe alternative methods could suffice. The discussion remains unresolved regarding the best approach.
Participants reference various mathematical expressions and concepts, including the projection of vectors and the definition of reciprocal bases, without reaching a consensus on their effectiveness or necessity in this context.
jonjacson
We have three orthonormal vectors [tex]\vec i_1 , \vec i_2, \vec i_3[/tex] , and we know which are the components of an arbitrary vector [tex]\vec A[/tex] in this base, explicitly:
[tex]\vec A = (\vec A \bullet \vec i_1) \vec i_1 + (\vec A \bullet \vec i_2) \vec i_2 + (\vec A \bullet \vec i_3) \vec i_3[/tex]
If now we want to generalize to a base that is orthogonal , but is NOT normalized, we can divide by the modulus, and we came back to the first case, so we have:
[tex]\vec i_1 = \frac{\vec e_1}{e_1} , \vec i_2 = \frac{\vec e_2}{e_2}, \vec i_3 = \frac{\vec e_3}{e_3}[/tex]
So now the expression of [tex]\vec A[/tex] is:
[tex]\vec A = \frac{\vec A \bullet \vec e_1}{e_1^2} \vec e_1 + \frac{\vec A \bullet \vec e_2}{e_2^2} \vec e_2 + \frac{\vec A \bullet \vec e_3}{e_3^2} \vec e_3[/tex] Equation 1
In the next case the base will be noncoplanar, not orthogonal and the vectors won't be normalized, I am following the book from Borisenko and Taraponov about tensor calculus, they introduce the reciprocal bases to solve this problem to arrive at this expression:
[tex]\vec A = (\vec A \bullet \vec e^1) \vec e_1 + (\vec A \bullet \vec e^2) \vec e_2 + (\vec A \bullet \vec e^3) \vec e_3[/tex]
Where the reciprocal base is defined as:
[tex]\vec e^1 = \frac{\vec e_2 \times \vec e_3}{\vec e_1 \bullet (\vec e_2 \times \vec e_3 )}[/tex]e^2, and e^3 have a similar definition in terms of e_1, e_2 and e_3.
Well the question is ¿why do we need to introduce the reciprocal base to solve this problem? ¿what is the benefit of using it?.
I don't know why you don't calculate the components of A using equation 1 . You can project A to the vector e_1, e_2 and e_3 using the dot product and you find the components of A ,in a similar way as you have done before with the other basis ¿is there something that impede you to make the calculation in this way?.
And you have another option, simply using this equality:
[tex]\vec A = \vec A[/tex]
First A expressed in the orthonormal base , and then expressed in the more general noncoplanar, nonorthogonal and not normalized :
[tex](\vec A \bullet \vec i_1) \vec i_1 + (\vec A \bullet \vec i_2) \vec i_2 + (\vec A \bullet \vec i_3) \vec i_3 = A^1 \vec e_1 + A^2 \vec e_2 + A^3 \vec e_3[/tex]
And you can find three equations to solve, so you wold not need introduce other base ¿is anything wrong in this last equation?
The book then introduce the concept of covariant and contravariant components of a vector, and I would like to understand why do you need the reciprocal base, and what it is.
¿no suggestions? ¿do you think that i made a stupid question?
I expend one hour to make the question in latex:frown:
Please tell me something, I have been waiting for a reply during three days:cry:
If you project A on a non-orthogonal basis, equation 1 is no longer valid. It's easy to see if you try it for A = e_1. If e_1 is not orthogonal to e_2, application of equation 1 picks up a term proportional to e_2.
Yes, you can do it the way you described too... but that requires you to solve a system of linear equations, in this case, a 3x3 system; isn't it easier just to take dot products with the reciprocal base?
First of all, hamster 143, thank you very much for replying, very appreciated.
Now I understand the problem, I have make an image with the digital pen to explain it, but I don't know how to attach the image, so i have uploaded it to an external server, if this is not permitted due to forum rules or if you can't see the image , please tell me. :smile:
http://i33.tinypic.com/20uwytf.jpgWhen you use the dot product, you project onto the axis using 90 degree, but if the vectors are not coplanars this is not true, ok, but you can still develop a formula to project correctly onto the axis without the introduction of the reciprocal base( if i am not wrong) :
[tex]\vec A = (\frac{\sin {\gamma} }{\sin{\beta} } A )\vec u +( \frac{\sin {\alpha}}{\sin {\beta}} A) \vec v[/tex]
¿do you see any mistakes? ¿could we do the calculations like this? . ¿why is better the reciprocal base?
  • · Replies 42 ·
  • · Replies 17 ·
