Struggling to Solve Equation: \sqrt{x} + 1 = 0
  • Context: High School
  • Thread starter Thread starter m00npirate
The discussion revolves around the equation \(\sqrt{x} + 1 = 0\), focusing on attempts to solve it and the implications of squaring both sides. Participants explore the nature of square roots, the validity of solutions, and the potential for complex solutions.
  • One participant attempts to solve the equation and arrives at \(x = \pm 1\), questioning the validity of this solution.
  • Another participant suggests that the inverse of a square root may provide insight into the problem.
  • Some participants note that squaring both sides of the equation leads to \(x = \pm 1\), but neither value satisfies the original equation.
  • There is a discussion about the implications of squaring both sides, with one participant emphasizing that \(x^2 = y^2\) does not imply \(x = y\).
  • Another participant points out that the square root function does not include negative outputs, leading to the conclusion that there is no solution in the reals.
  • Several participants agree that the principal square root is conventionally taken to be positive, reinforcing the idea that \(\sqrt{x} = -1\) has no real solution.
  • Some participants question the existence of complex solutions, discussing the limitations of the principal square root function in the complex plane.
  • One participant argues that if the principal square root were extended to complex numbers, it would complicate the determination of solutions.
  • Another participant suggests that the only potential complex solution could be \(x = 1\), but this is contingent on the conventions used in defining square roots.
Participants generally agree that there is no real solution to the equation, but there is disagreement regarding the existence and nature of complex solutions. The discussion remains unresolved regarding how to rigorously prove the absence of complex solutions.
Limitations include the dependence on the definition of the square root function and the conventions used in complex analysis. The discussion highlights the nuances in mathematical reasoning when dealing with square roots and their implications.
m00npirate
I have been trying for the past hour or so to figure out the solution to this equation:
[tex]\sqrt{x} + 1 = 0[/tex]
but to no avail! Here's what i tried...
[tex]\sqrt{x} = -1[/tex]
[tex]\sqrt{x} = i^4[/tex]
[tex]x = \pm i^8[/tex]
[tex]x = \pm 1[/tex]
But this is most obviously wrong. What did I do wrong and what is the real answer?
Mathematics news on Phys.org
I think you may be over thinking it, what is the inverse of a square root?
If I square both sides from the beginning I still get x = +/- 1, neither of which solve the equation.
You seem to have stated that -1=i4. Check again
Yea that was a typo, I've figured out what went wrong though. -1 just isn't in the range of the square root function. It has no solution.
more importantly, x^2=y^2 does not imply x=y.
[itex]x^2 = y^2 \Rightarrow x = \pm y[/itex]
isn't if and only if?
[tex]x^{2} = y^{2} \Rightarrow |x| = |y|[/tex]
Isn't this correct though?Also, MATLAB gave the error 'Warning: Explicit solution could not be found.' when trying to solve the equation.
And Microsoft Math gave x=1, which is clearly incorrect
I said 'x^2=y^2 does not imply x=y'. What you are saying is that x^2=y^2 implies x=+-y. There is no contradiction here.
in the original post, you had
sqrt(x)=-1
then you square both sides and got
x=1 (another mistake in your post was the x=+-1 part; where did the -1 come from??)
and from that you concluded that, if x=1, then
sqrt(x)=-1
which is false, because x^2=y^2 does not imply x=y.There was a post here a while ago, I can't find it, but it expressed a common misconception people make when solving equations. When you have something like x+4=8, and you subtract 4 from both sides to get x=4, you did not prove that
'if x=4 then x+4=8' (1)
you actually proved that
'if x+4=8 then x=4' (2)And (1) is true only if the operation you peformed was injective (i.e. one to one). subtraction is injective, squaring both sides isn't.
sqrt(x)= -1
Square both side
x=1.
Then
sqrt(1) = 1 or -1
since
1^2 = 1
AND
-1^2 = 1 (*)
Using (*)
sqrt (-1^2) = sqrt (1)
ie -1 = sqrt(1)
No. [itex]\sqrt{1} = 1[/itex]. By convention, the square root of a number is generally accepted to mean the principal, or positive square root.
So sqrt(x) = -1 has no solution in the reals. If you look at the graph of y = sqrt(x), you'll see that the domain is x >= 0.
Like Mark44 has said, only the principle root (i.e. the positive number) is taken. This means that there is no complex solution to this equation.
Mentallic said:
...This means that there is no complex solution to this equation.
I don't yet see why there can be no complex solution. Can this be proven rigorously?
The right hand side of the equation is not in the domain of the left hand side. If you intend on extending the principal square root function to complex numbers, the problem becomes choosing which complex root is the principal root, as there is no "positive" or "negative" in regards to the complex plane.
The only complex roots would be [itex]cis(2k\pi)[/itex] for all k integers, which in other words is 1. But since we've already defined by convention that the square root of a positive is only its positive root, then we cannot get the answer [itex]\sqrt{x}=-1[/itex]
If it weren't for this limitation (which some authors don't uphold for convenience in their specific topics of mathematics) then we would have the only possible complex solution x=1
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 22 ·
