Wave function collapse and the statistical nature of quantum states
The discussion revolves around the interpretation of wave function collapse in quantum mechanics (QM) and the statistical nature of quantum states. Participants explore various interpretations of measurement outcomes, the implications of hidden variable theories, and the relevance of Bell's inequalities in distinguishing between competing models.
  • Some participants propose that if a system is in a single state, measurement merely identifies that state, suggesting that the distribution of results from multiple measurements could be explained by the presence of different single eigenstates in the sample population.
  • Others argue that this perspective is ruled out by Bell inequality violations, indicating that the statistical nature of measurement outcomes cannot be explained solely by pre-existing states without invoking non-locality or hidden variables.
  • There are mentions of newer theorems (GHZ, Hardy, Leggett, Cabello) that challenge "realistic" or "hidden variable" interpretations, emphasizing that particles do not possess classical attributes waiting to be revealed.
  • One participant questions how to interpret the Stern-Gerlach experiment in light of these discussions, particularly regarding the preparation of spin states.
  • Another participant introduces the concept of superdeterminism as a potential framework for local deterministic models, referencing 't Hooft's work.
  • Concerns are raised about the implications of deterministic models on the observer's ability to influence experimental settings and the nature of measurement in quantum mechanics.
  • There is a discussion about the validity of Bell's inequalities and the assumptions underlying their derivation, with some participants expressing a desire to explore these arguments further.
Participants express multiple competing views regarding the interpretation of wave function collapse and the implications of measurement in quantum mechanics. There is no consensus on the validity of hidden variable theories or the implications of Bell's inequalities, leading to an unresolved discussion.
Limitations in the discussion include the dependence on definitions of measurement and state preparation, as well as unresolved mathematical steps related to Bell's inequalities and their implications for deterministic models.
LAncienne
Sorry for a (maybe) dumb question, but... I understand that according to QM, the description of the situation for a particle or system is described by a linear superposition of the wave functions of all the possible states (eigenstates) of the system. When a measurement is made, the wave function, according to garden variety QM, "collapses" to the state measured. The probability of getting a particular result is proportional to the usual square (in the complex sense) of the wave function corresponding to the eigenvector for the state measured. All that being said, it seems to me that there are reasonable scenarios which do not require this composite wave function, nor its collapse. Let me lay out my thoughts for someone to attack...
If the system is simply in a single state, then the measurement identifies (measures) that state. If I make multiple measurements over a large sample of equivalent systems, I get a distribution of results. QM would say that is because of the nature of the composite wave function. An equally good, and much simpler explanation is that I am simply drawing results from systems already in different single eigenstates, and the distribution I get simply reflects the distribution of eigenstates in the sample population. For the situation I am describing, there is no way to tell the difference between these explanations. Maybe here, the composite wave function is simply an artifact of the QM formalism?
There actually is a way to tell the difference. The possibility you're describing is ruled out by Bell inequality violations. So you might want to look into that
There are many threads about it here, so you can try a search. There are some crackpot posts in some of them, so you should focus on the posts made by science advisors. There's a good derivation of a Bell inequality in Isham's book: 215, 216
As Fredrik says, that is ruled out by Bell. There are also a host of newer theorems (GHZ, Hardy, Leggett, Cabello, etc.) that also rule out the so-called "realistic" or "hidden variable" interpretations.
Now, there are some that are still on the table that have explicit non-local components (the Bohmian types). However, they too must demonstrate what is called contextuality - which is to say a form of observer dependence. The upshot is that particles do not have classical attributes that are simply waiting to be revealed. What you see is a function of what you look for.
To LAncienne: How would you interpret the Stern Gerlach experiment? Would you say that electrons enter the magnetic field already in either the spin-up or spin-down state, and the apparatus merely separates them accordingly? Because remember you can also prepare a spin-sideways beam of electrons. Is this a problem for your interpretation?
You should have a look at the lectures at
http://www.princeton.edu/WebMedia/lectures/
of Mermin and another by Conway (Kochen Specker theorem).
Basically the problem is that in there hidden variable theories, the particles need to know what is going to be measured in advance. Otherwise they couldn't keep a list of replies to all eventually possible measurement once they are apart.
But I'm also working on understanding this.
@Count Iblis:
I'm actually interested in this, but after the first reading I wasn't sure what he meant. Why isn't he using a specific celluar automaton that has local rules, but visibly violates Bell's inequality?
There is a problem here about definite states. You see the experiment can be arranged using continuous change in base for measurement. For example you can rotate polarizer by arbitrary angle but your system is in single eigenstate only for certain polarizer angles.
So you have to define what your system will do if your single state is not in perfect match with measurement.
He hasn't demonstrated precisely how Bell's inequalites will be violated. His point (also made in other papers), is that the derivation of Bell's inequalities is invalid, because it assumes that the observer could have made a counterfactual experimental setting while leaving the measured system unchanged. Precisely because the model is deterministic, this is impossible.
The observer is also deterministic. If you give the observer the freedom to chose its experimental setting, then you have to implement that by specifying a set of physically acceptable initial states of the universe, not by assuming that any local change in the current state is a physically acceptable state. It most likely is not, as evolving such a state back in time would most likely lead to the entropy increasing again.
I think I need to go through all of the Bell arguments myself.
Maybe the CHSH paper itself. Or which approach do you recommend, so that I can convince myself of the weaknesses?
Count Iblis said:
... is that the derivation of Bell's inequalities is invalid, because it assumes that the observer could have made a counterfactual experimental setting while leaving the measured system unchanged. Precisely because the model is deterministic, this is impossible.
Are you saying the theory could be local, but the types of measurement would be predetermined and have to be found self-consistently with the universe?
Also, the experimenter cannot change the experiment by hindsight, but still the state of the particle has to be prepared for all experimenter's questions? Otherwise at some point it will fail the laws of QM.
That is possible, but that's equivalent to failing the intended purpose of HV theories. They wanted to make QM more intuitive by the common local picture. A predetermined measurement theory is like MWI. It might relieve us from philosophical difficulties, but doesn't help the understanding.
Maybe I can outline the Bell argument and you tell me at which point I should search for a flaw:
  1. I will perform experiments label with index i on two particles x and y flying apart
  2. the particles with have states [itex]x_i[/itex] and [itex]y_i[/itex] in these experiments
  3. the detector will be set to states [itex]r_i[/itex] and [itex]s_i[/itex]
  4. the outcomes of the experiment are a physical law given by a function; therefore the outcomes are [itex]f(x_i,r_i)[/itex] and [itex]f(y_i,s_i)[/itex]
  5. if detectors are perfectly set to one of 3 states then we could name a particle by its outcome in all possible experiments [itex](f(x_i,1),f(x_i,2),f(x_i,3))\times(f(y_i,1),f(y_i,2),f(y_i,3))[/itex] which is all we need to know about the state.
  6. writing out a big table [itex](f(x_i,1),f(x_i,2),f(x_i,3))\times(f(y_i,1),f(y_i,2),f(y_i,3))[/itex] where [itex]f(\cdot,\cdot)=\pm 1[/itex], one can use set theory to write down a Bell inequality since probabilities in this table add. Each experiment will fall into one of these 64 cells.
  7. if we assume that some states have zero probability (like [itex]P([+++,-++])=0[/itex]), then experiments seem to violate the inequality (if the given example wasn't zero, then if we ever measure in detector setting 2 or 3, then we'd notice an inconsistency with the laws of QM)
It is the assumption that you can choose r_i and s_i without affecting x_i and y_i.
Are you saying that I will not be able to make a measurement inconsistent with QM or Bell, because the universe dictates what I'm going to measure anyway?
That may be true, but in such a case that also means that there is no intuitive model of QM?!
The state of particles is chosen at time t and the state of the detector also. Of course the actual result of the measurement depends on how the particles arrives at the detector, but that's all included in f(x,r)
Well, folks, this has wandered interestingly (sometimes) far from the original question! I was not particularly shilling for any interpretation, just wondering if there was a situation where I could not conclusively tell what the wave function was (had to have (might have) been?) from the results.
Let me lay out a really simple gedanken example. I have an ensemble of equivalent systems. all of which have three (the same three ;-{) ) eigenstates. I have a detecting apparatus that can determine which state the system (s) are each in. Using this apparatus, I measure a large number of the systems, and get a distribution of results, i.e., the number of measurements that yield each eigenstate. Seem reasonable? I do not worry about any composite states for the apparatus and ensemble, or as Heisenberg once said, where the "schnitter" (dividing line between quantum and macroscopic domains) lies. My point is that, with this situation, I can't tell the difference between the two interpretations. I am sure that there are valid reasons why the QM formalism would indicate that I had interpreted my results incorrectly, BUT, in this instance, there is ambiguity. What's wrong with this? (Remember, the ambiguity, NOT the interpretation!)
What is the cellular automata bit, coming from left field?
All of this has already been answered. It isn't possible to determine which state the system is in. The observables of a theory that says that this is possible satisfy Bell inequalities, and Bell inequalities do not hold in the real world, so the possibility you're describing has been ruled out by experiments.
Well, you can interpet the violation of Bell's inequality as ruling out the assumption that you could have made a counterfactual measurement without affecting the exact state of the measured system. That the choice of the setting of polarizer 2 will not affect the outcome measured at polarizer 1 is not necessarily true in a local deterministic theory.
This is either getting weird or we are not talking about the same thing, somehow. When I make an concrete observation about a thing in the quantum realm (system, particle or ?) I have determined at least one aspect of its state (else what is all this wave function collapse stuff about? collapses to what?... a measured observed state..) as a result of the observation. Think single photons from a very weak source, and three detectors in a row that absorb horizontal, then vertical, then circular polarization. If the first one absorbs the photon, I have actually determined the that the polarization of the photon was vertical and so on. Whether it was actually a mixture and the first absorber "forced" it in some sense, to be so detected, or whether it actually was vertically polarized, I have detected at least this aspect of its state, haven't I?
I think we are talking about the same thing, and yes, it's pretty weird.
You have only determined what the state is after the measurement. There's no measurement that can tell you what the state was before the measurement, if you didn't know it already as a result of a previous measurement. The only way to determine an unknown state is to do measurements on each member of a very large ensemble of identically prepared systems.
The "collapse" is the change that the wavefunction goes through when you measure an observable. The wavefunction is always changed by the measurement, unless it was already in an eigenstate of the observable you're measuring.
If the source prepares the photons in the same polarization state every time, then you can find out what state that is by doing polarization measurements on lots of photons. But a single measurement can't tell you what state the photon was in before the measurement. When "the first one absorbs the photon", the only conclusion you can make about the state before the absorption is that it wasn't such that the probability of absorption was zero. So all you know is that it wasn't a state of linear polarization in the vertical direction. It could still be any other state. (And if your detector isn't perfect, it could be that one too).
Isn't quantum mechanics fun? :smile:
I think several has tried to make this point already but...
The QM state vector/wave function, of a system defines "probabilistically" the possible result of a measurement. A system with a well define state is said to be pure.
Of course this formalism breaks down unless the QM state is not pure (which is of course an idealisation, just like you never have perfect information, it's simply not realistic), because if the state vector itself is uncertain, then you do not even know probabilistically the possible outputs.
The question is then howto save the QM formalism given this obvious issue?
Probably the simplset possible resolution of this, which is the standard formalism for dealing with impure states are the densitry matrix formalism,
http://en.wikipedia.org/wiki/Density_matrix
where you simply consider the simple idea that the quantum state is smeared by a classical probability distribution. So first the quantum state of the system is only known probabilistically, where each possbility (quantum state) defines probabilistically an outcome.
One may have objections to this resolution on philosophical grounds, but the main point that you can't know with certainty the state vector from only a finite amount of measurements should be intuitively clear I think?
/Fredrik
There aren't any, despite what the article implies.
About 3 or 4 times a year, someone puts out a "disproof" of Bell which purports to show a computer program or similar which is local realistic. These are always flawed, and fail to mimic QM predictions in all particulars. Usually the "secret" of the program is a) a dependence on exploiting fair sampling assumption by making the sample explicitly unfair but dependent on relative angle (which is circular); and/or proposing a mechanism which is contradicted by other experiments. It is tiresome to critic these, so don't expect all to be attacked in defense of Bell.
The only reason 't Hooft is given some leeway is because he has a Nobel. But I don't think his work is considered promising by established scientists in the field (they are silent as a courtesy).
LAncienne, there are states in which your desciptions seems to work fine. That was in fact the point of EPR in 1935. For many years after, it was an open question because no one had realized that there are states in which that description does NOT work. That is what Fredrik was trying to say. You must really understand Bell before you go further or you will be wasting your time.
You may benefit from this link, which walks you through the argument in the spirit of Bell and uses terms which are less arcane:
Bell's Theorem and Negative Probabilities
I can easily explain this if it will help. If you assume that a photon has definite state for its polarization at the angles of 0, 45 and 67.5 degrees (in violation of the HUP), then there are 8 possible permutations which must have probabilities >0. It turns out that 2 of the 8 cases have a combined negative probability when you test them experimentally. Therefore, the assumption is wrong.
Thanks Fredrik,for your comments. I think we are still talking somewhat at cross purposes. You said:
This is all I expected to be doing, getting the state after the measurement, I never meant to imply that I could get the state (composite or pure) before the measurement. (There are, of course, situations where I do know the state of a system (orbital electrons of a particular atom, etc). The point is that, unless my measuring (detecting) apparatus actually changes the state to one that is not part of the sort of "natural" set of eigenstates that might be expected (that are part of the composite wave function) , then my detector will detect one of the eigenstates and the system will be, even if ephemerally, in that state. The detector, in essence, is preparing a single state system.
This is what I was trying to indicate I was doing in any of my examples. Say I prepared some ensemble of systems in what is an admixture of two states, and then I measured a large number and the results of the measurement (putting each system after measurement either into state 1 or 2) got N1 in state 1 and N2 in state 2. All that can be reasonably done without violating anything, I hope. My only point is that, I DO NOT KNOW whether I am selecting from pure or mixed (composite) states, there is no way to tell.
I misunderstood what you were trying to say as well.
't Hooft's proposals are not similar to these attempts. It may be the case that the violation of Bell's inequalites rules out local determinsitc models, but so far this has not yet been rigorously proven. All proofs invoke counterfactual experimental settings in an improper way.
This is really a different topic unrelated to this thread.
Thanks, DrChinese for your reference and explanation. Good stuff. Have you seen Louisa Gilder's book,with a good history, but pretty accessible. Right at the beginning she gives a pretty good picture and explication of Mermin's apparatuslike explanation. Worth recommending to your non-physiker friends.
Cheers
  • · Replies 33 ·
  • · Replies 32 ·
  • · Replies 24 ·
