How Does Neutron Population Remain Stable in a Critical Mass Scenario?
  • Context: Graduate
  • Thread starter Thread starter EinsteinII
    Critical mass Mass
The discussion focuses on the concept of critical mass in nuclear fission, particularly regarding the stability of neutron populations during a chain reaction involving Uranium-235. Participants explore the conditions necessary for sustaining a chain reaction, the implications of neutron behavior, and the effects of mass and shape on criticality.
  • Some participants explain that critical mass refers to an equilibrium state where the neutron population remains stable, with no increase or decrease in power or temperature.
  • Others argue that while each fission of Uranium-235 releases two or three neutrons, at least one neutron must be absorbed to sustain the chain reaction, highlighting the importance of maintaining a critical mass.
  • There is a discussion about the necessity of a certain mass of fuel to ensure that neutrons are captured effectively, as smaller masses may lead to neutrons escaping before causing further fissions.
  • Some participants note that the shape of the mass affects criticality, with spherical shapes requiring less mass compared to elongated shapes.
  • Concerns are raised about the handling of enriched uranium, with varying opinions on safety depending on whether the uranium is fresh or spent fuel.
  • Participants mention that the presence of neutron reflectors or emitters can significantly alter the critical mass requirements.
  • One participant points out that delayed neutrons released during fission contribute to the control of the fission process.
Participants express multiple competing views regarding the conditions necessary for sustaining a chain reaction and the implications of neutron behavior, indicating that the discussion remains unresolved on several points.
Limitations in the discussion include assumptions about neutron behavior, the dependence on definitions of critical mass, and the lack of consensus on the implications of mass and shape on criticality.
EinsteinII
The term critical refers to an equilibrium fission reaction (steady-state or continuous chain reaction); this is where there is no increase or decrease in power, temperature, or neutron population.(Ref: http://en.wikipedia.org/wiki/Critical_mass)
1. How can be the neutron population stable when every fission in Uranium 235 releases 2 neutrons?
Hi there,
By flying over the wikipedia article you make reference, I believe you did not truly understand the idea behind critical mass.
Let's start from the beginning, when a heavy nucleus (U-235) fissions, it releases many different particles: two new nuclei, two or three neutrons and energy (kinetic or photonic). You probably knew that right!
You probably also know that the neutrons freed from this fission can induce new reactions, in the idea of chain reactions. But the problem is that the growth is exponential.
Ok, but to keep these reactions going, you need a to have a nuclei of U-235 to catch the free neutrons. Otherwise, the reactions will stop. Therefore, you need a certain "critical mass" of U-235 to insure that at least one neutron per fission will be catch and produce a chain reaction.
Cheers
That was great explanation! Thanks a lot!
But then again, what is the need for a certain mass of fuel when any amount of fuel can trigger a chain reaction, i mean the longer the fuel lasts the more the energy?
Sorry that I did not go into more details.
Let's start where I left off, in my last post.
In a block of uranium, you will have desintegration that emits a few neutrons. These neutrons, of high energy, travel a certain distance before being caught by a nucleus. The neutrons emitted near the surface of the block will naturally drift out. Therefore, if you have too much of a small block, most of the neutrons will drift out, before being able to interact with another nucleus. The chain reaction can only be sustained with a block that is big enough to ensure neutron catching.
Hope this clarifies your problem?
Cheers
Thanks for that information!:smile:
Also note that the critical mass depends on the SHAPE of the body. For a spehere it is minimal, for a stick it is much much bigger.
Cheers
Does that mean enriched uranium should not be touched with bare hands? Sorry if that question is silly!
Hi there,
It depends!
I will call "enriched uranium" = nuclear fuel, since this is the fuel used in many of the NPP in this world.
If the fuel is new (never been inside a reactor core), you can touch it, put it in your pockets and walk around with it. The emission of this type of fuel is practically null. I would strongly suggest not to eat it, but that for other reasons than radioactivity. This is not true for MOX fuel, which is a mix of nuclear fuel containing plutonium.
If your are talking about spent fuel (has been inside a reactor, bombarded by neutrons), then I would turn the other way and run as fast as you can.
Is this clear in anyway?
Cheers
It does not. Natural radiation level of uranium is very low (on the order of 10 neutrons per kilogram per second, depending on isotopic composition). It is only through exponential multiplication that any significant amounts can be collected. You need to be exposed to 10^15 energetic neutrons in a short period of time to develop radiation sickness symptoms.
Plutonium-239 is thousands of times more radioactive than uranium, and you can be around plutonium relatively safely, as long as you don't consume or inhale plutonium dust (because dust can end up stuck in your lungs and seriously mess them up).
That is fairly nasty stuff, you can really get radiation burns from handling it. Not to mention that ingestion or inhalation of as little of 10 mg could be fatal. But its intensity declines rapidly over time. By the time it spent a couple of years out of the reactor, all the most radioactive elements have decayed, and its radiation level is down to perhaps 1% of the initial.
Not only from the Shape, also from the surroundings. If there in the surroundings there are neutron reflecters or other neutron emitters in change drastically.
In fact the system used to reach the very critical mass back in los-alamos was to surround the ball of plutoniom NEAR to the critical mass with Pb bricks, one by one.
Questions are never silly.
It better to does not, not for radioactivy (in fact Uranium is less radioactive then many of common-uses materials) but for the same reason is better to not touch lead with bare hands: hands get dirty with Uranium (or Pb) dust, that you will inhalate or eat. The heavy material then get on the lungs or generically in the body and is difficoult for the body to expel it. Then it inflames he cells nearby and increase the probability that these cells will react becoming cancer cells.
Anyway the Uranium the chance is lesser than with the lead because the Pb is softer.
On average, at least one of the two neutrons released must be absorbed and cause fission to continue the chain reaction. As soon as the average number falls below 1, the mass becomes subcritical. In actuality, either 2 or 3 neutrons are released during fission, and some fission products also release 'delayed' neutrons, and it is this piece of physics that enables us to more easily control the fission process.
In a nuclear explosion, the mass becomes prompt supercritical for a few microseconds.
9K
  • · Replies 46 ·
17K
