Measuring components of circularly polarised light.
The discussion centers on the experimental setup for measuring the voltages of left-handed and right-handed circularly polarized light using a quarter waveplate and a linear polarizer. The setup involves linearly polarized laser light incident at 45 degrees to the fast/slow axes of the waveplate, which converts it to circularly polarized light. To accurately measure the circular components, it is essential to remove the linear polarizer to allow the circularly polarized light to reach the photodiode. The direction of the fast axis of the waveplate is crucial for determining the handedness of the circular polarization.
  • Understanding of quarter waveplates and their function in polarization
  • Knowledge of linear and circular polarization concepts
  • Familiarity with photodiodes and voltage measurement techniques
  • Experience with optical setups involving lasers and polarizers
  • Research the principles of circular polarization and its measurement techniques
  • Learn about the role of the fast axis in quarter waveplates
  • Explore methods for distinguishing between left-handed and right-handed circular polarization
  • Investigate alternative setups for measuring polarized light without a linear polarizer
Students and researchers in optics, experimental physicists, and anyone involved in the study of polarized light and its applications in laboratory settings.
quantumlolz
Hi there,
Having a bit of trouble working something out for a lab experiment at uni - not sure if this really counts as a 'homework' question - but if it does, moderators, feel free to move it there!
So we've got linearly polarised laser light hitting a quarter waveplate to create circularly polarised light, where the incident laser light is incident at 45 degrees to one of the fast/slow axes on the waveplate. Then this circular light is going through a linear polariser before hitting a photodiode, connected to what is basically a voltmeter.
A quick note about the linear polariser - we have that there to ensure the quarter waveplate is set up correctly - the linear polariser is crossed with the laser so that, on their own, nothing gets through to the photodiode.
To ensure the quarter waveplate was set up correctly to create circular light, we rotated the quarter waveplate until no light was being picked up by the diode, noting that angle, and then rotating it again through 90 degrees so that nothing was being picked up by the photodiode again (the scale on the waveplate is arbitrary as it'd been cleaned and the dial had just been put back in some random position), so that halfway between the two angles (on the scale) gave the 45 degrees needed to create circularly polarised light. (is this right??)
So, here's the problem: how do we use this set up to measure the voltages for the left handed and right handed circular components of the circular polarised light. The main problem here really is that we're not sure what's going on in between the linear polariser and the photodiode.
Sorry if this all sounds rreally confused - I definitely am!
Science news on Phys.org
Welcome to Physics Forums.
Your setup sounds correct for getting circularly polarized light, by rotating the waveplate to be 45 degrees from the two null-signal positions.
I'm not sure what your are asking here. The beam is circularly polarized after the waveplate -- it's either left or right handed circular, one or the other, not some combination of both. Are you asking whether it's left or right handed? To find that you would have to know the direction of the fast axis of the waveplate, as well as the direction of linear polarization before the waveplate.
At any rate, it sounds like you need to remove the linear polarizer in order to have circular polarization incident on the photodiode, if the goal is to measure what signal you get for the circularly polarized beam.
  • · Replies 22 ·
