F = qvB in Relativity: A Charge in Magnetic Field
  • Context: Undergrad
  • Thread starter Thread starter IPhO' 2008
    Relativity
The discussion revolves around the application of the equation F = qvB in the context of relativity, particularly when a charge is moving at velocities close to the speed of light within a magnetic field. Participants explore the implications of the magnetic field's source velocity on the force experienced by the charge.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions whether F = qvB can be applied when the charge's velocity is nearly the speed of light.
  • Another participant simply affirms the use of the equation without further elaboration.
  • A different participant introduces the scenario where the source of the magnetic field has its own velocity (vs) and asks how this affects the force.
  • Another participant asserts that the force depends only on the magnetic field B and not on its source, indicating that force is related to the rate of change of momentum (dp/dt).
The discussion contains multiple competing views, particularly regarding the impact of the source velocity of the magnetic field on the force experienced by the charge. There is no consensus on how these factors interact.
Participants do not clarify the assumptions underlying their statements, nor do they resolve the implications of relativistic effects on the force equation.
IPhO' 2008
A charge q has a velocity v in the magnetic field B if v is nearly to velocity of light.
Can we use F = qvB.
Thank you.
Yes.
If the source of magnetic field has a velocity vs .
F = ? :confused:
F depends only on B, not where it came from. The F means dp/dt.
  • · Replies 28 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 24 ·
