What is the formula for magnetic field when v is close to c?
The discussion revolves around the formula for the magnetic field produced by a moving charge, particularly when the velocity of the charge approaches the speed of light (c). Participants explore the limitations of classical formulas and seek alternatives applicable in relativistic contexts.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests using the formula B = \frac{\mu}{4\pi} \frac{q[vr]}{r^3} for cases where v is much less than c, but questions its validity as v approaches c.
  • Another participant seeks clarification on whether the discussion pertains to the magnetic field generated by a single moving charge.
  • A reference to a specific equation from a lecture on electromagnetic theory is provided, indicating a potential alternative approach for relativistic speeds.
Participants do not reach a consensus on the appropriate formula for the magnetic field when v is close to c, and multiple viewpoints regarding the applicability of different equations remain present.
The discussion highlights the need for a formula that accounts for relativistic effects, but does not resolve the specific mathematical steps or assumptions required for such a formula.
IPhO' 2008
We can use B = [tex]\frac{\mu}{4\pi}[/tex] [tex]\frac{q[vr]}{r<sup>3</sup>}[/tex]
when v << c (c is a speed of light) but if v is nearly to c we can't use this formula.
What is a formula when v is nearly to c.
r3[/SUP ] is r3
Thank you.
  • · Replies 16 ·
