- 2,425
- 408
ok racers, here is a subject I have been debating. our formula car uses two aluminum radiators, one on each side. I switched to the Ultra Side pods which are each 5 pounds lighter and 3 inches narrower than the original sets. Benefit is lighter weight and lower aero drag.
now the questions,
1. is it more beneficial to plumb the coolant thru the radiators in series or parallel.
2. Air enters the side pod and exits thru the radiator fins. Is is better to place insulation around the radiator core to smooth the air flow or
leave the radiator bare to help dissipate heat from the sides.
3. the red car photo ( as seen from the front of the car) shows a splitter that spits the incoming flow to the front portion and rear portion of the rad core. I am told that is is not needed on 90 percent of the installations. Note the insulation packed around the rad core.
your keen observations and comments are valued
i will respond as required and as beer permits.
thank you
now the questions,
thank you
