Fields Confusion (Electro/Gravit etc)
  • Context: Graduate
  • Thread starter Thread starter Livethefire
    Confusion Fields
The discussion revolves around the nature of forces in electromagnetic and gravitational fields, specifically questioning the source of potential energy that causes attraction or repulsion between particles. Participants explore the implications of these forces and their definitions, touching on philosophical aspects of energy and potential.
  • One participant expresses confusion about where the energy for attraction or repulsion in fields originates, suggesting it may be a philosophical question.
  • Another participant states that gravitational and electromagnetic forces are fundamental properties of the universe, but their origins remain ambiguous.
  • A participant defines energy as the ability to do work, implying that if something can do work, it possesses energy.
  • One participant proposes that electromagnetic fields have energy and that oppositely charged particles are attracted as their fields interact, although this view is challenged by others.
  • Another participant argues that the energy density of the electric field increases as charged particles approach, contradicting the idea that their fields cancel and reduce energy.
  • Some participants discuss the behavior of fields over space, noting that fields can add or cancel in different regions, affecting overall energy density.
  • A later reply introduces a speculative idea from Philip Morrison regarding the mathematical nature of gravitational fields, suggesting they could be imaginary.
  • One participant reflects on the philosophical nature of their thoughts and attempts to clarify their understanding of energy as an innate ability of particles to do work.
  • Another participant encourages the idea that multiple perspectives can be beneficial in discussions, emphasizing the value of diverse responses.
Participants express a range of views on the nature of energy and forces, with no consensus reached on the origins of potential energy or the implications of field interactions. Disagreements exist regarding the interpretation of electromagnetic field behavior and its relation to energy.
Some discussions touch on the philosophical implications of energy and potential, highlighting the complexity and ambiguity surrounding these concepts. There are also references to mathematical models that may not be fully resolved within the discussion.
Livethefire
This is most likely a complete failure of comprehension on my part (as ussual), but I've been thinking about this for the past while and have come to a unsatisfactory conclusion.
In reference to an electro-magnetic field or a gravitational field, where do the particles get the energy to be attracted or pushed away?
I know they have a POTENTIAL to do so, but where does that potential energy come from in the first place?
Refering to gravitational fields, is it just because of a particular spatial configuration? Thats obvious in the sense that- we have 2 masses and they attract, you can give one potential energy in respect to the other by applying a force etc.
However back to the original question where does that impeding attractive force come from to begin with?
I reckon there is something fundamentally wrong with my understanding or this is edging on philosophy. The concept of a potential field around say a static charged particle, a magnet or a large mass is a way of describing what is happening without saying where the energy came from.
I will be very grateful if anyone can clear this up, or shed more light on it.
Thanks.
LTF.
EDIT:
We don't really know WHAT energy is in an absolute sense apart from little definitions. So I guess my question is edging philsophical ground. And the concept of potiential is indeed useful. I just don't like not knowing :P.
The gravitational force, determined by Newton's law, and the EM force, determined by Coulomb's law.
These are fundamental forces of the universe. Where they come from...is ambiguous. They are properties of our Universe.
And the energy is just a definition, an ability to do work. So if it can do work it has energy (potential or otherwise).
Yeah, I guess I'm thinking about it too much.
Thanks for setting it straight.
For EM I think a bit more can be said. An EM field itself has energy. Two oppositely-charged particles are attracted to each other because as they get closer more of their fields cancel, reducing the amount of energy in the field. Two like-charged particles are repelled for the same reason.
DaleSpam said:
Two oppositely-charged particles are attracted to each other because as they get closer more of their fields cancel, reducing the amount of energy in the field. .
I think something's wrong here.
The energy density of the field is proportional to the square of the electric field, the electric field only gets stronger with the approach of oppositely charged particles.
I can think of a proton and electron separated by a distance, an from the frame of the proton, the field line directed to the electron does not pass to the other side, nd the electron's field itself is pushing it in from there.
The fields exist over all space, not just over the region between the two charges. In that region they add, in other regions they cancel, the net effect overall is a decrease in the field energy.
While it is true that in the very near field the proximity of opposite charges enhances the field, in general the field suffers. For example, the monopole has a field that falls off as 1/r^2, the dipole 1/r^3, the quadrupole 1/r^4, etc. So when r << 1, the field will appear enhanced but otherwise the fields become more and more short-ranged, decreasing the total energy in the fields when you integrate across the entire volume of space. In addition, the strength of the multipole increases with distance between the charges. So charges that are closer together only diminish their moment.
Good answer. The late Philip Morrison suggested many years ago that the only way this energy book keeping could also be accomplished in the case of gravitating (attracting, like-signed) masses would be if the gravitational field is mathematically imaginary. In that case the square of g would be NEGATIVE.
Thanks again, a lot of good responces.
I was thinking about it too far, philsophically; which sometimes is bad.
In short, the fundamental forces of nature in a sense are the innate ablity of particles/objects with particular properties (charge, movement, mass etc) to do work. This ablity we define as energy.
Would this be correct? I know that definition could be a lot more rigourous but just getting it straight in my head.
You've got it straight. Don't listen to the field energy argument, although it is true, it doesn't help. In those situations work is still being done and that is the key.
It helped me when I had the same thought.
I'll apologize for that comment, it was self-centered. I really should have said something more like 'don't feel alone if thinking of it that way doesn't help, it never helped me'. Again, apologies.
No problem, I wasn't offended or anything. I think that is one reason that it is good to have multiple (correct) responses to a single post.
I agree completely! But, again, that is why I apologized, I was a douche. :smile:
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 23 ·
