Explosion in the sky caused by lightning
In summary, a thunderstorm on the city's Northeast Side caused an explosion of lightning, producing a dark circle in the sky that was later identified as a ring of smoke. This incident has prompted discussions about a possible detector for these types of rings.
Ivan Seeking
Staff Emeritus
1,761
"In addition to the usual fare that comes with a thunderstorm, many on the city’s Northeast Side witnessed an unusual dark circle in the sky, which turned out to be a ring of smoke that a weather official said emanated from an 'explosion caused by lightning'".
http://news.mysanantonio.com/story.cfm?xla=saen&xlb=180&xlc=1022772
Biology news on Phys.org
More
A follow up to the story:
http://www.woai.com/news/local/story.aspx?content_id=ABC2A860-778F-48BC-B92E-1B9C33EC7F51
FAQ: Explosion in the sky caused by lightning
What causes an explosion in the sky?
An explosion in the sky is typically caused by lightning. When a lightning bolt strikes the ground or any object, it causes a sudden release of energy in the form of light, heat, and sound. This explosion is what we see and hear as thunder and lightning.
Is an explosion in the sky dangerous?
An explosion in the sky can be dangerous, especially if it occurs close to a person or a structure. Lightning strikes can cause fires, damage buildings, and even injure or kill people. It is important to seek shelter during a thunderstorm to avoid any potential danger.
Can an explosion in the sky be predicted?
While scientists can predict when and where a thunderstorm might occur, it is not possible to predict when or where lightning will strike. This is because lightning is a random and chaotic event. However, with advanced technology, we can detect lightning strikes in real-time and issue warnings to those in the affected area.
How does lightning cause an explosion in the sky?
When a lightning bolt strikes an object, it causes a rapid expansion of air, which creates a shock wave. This shock wave travels through the air, causing vibrations that we hear as thunder. The heat from the lightning bolt also causes the air to expand, creating a bright flash of light that we see as lightning.
Can an explosion in the sky be harmful to airplanes?
While airplanes are designed to withstand lightning strikes, they can still be affected by an explosion in the sky. The electrical systems on airplanes can be disrupted by lightning, which can lead to temporary malfunctions. However, strict safety measures are in place to minimize the risk of lightning strikes on airplanes.
