Self-adjoint/hermitean operator vs observables
In summary, in Quantum Mechanics, observables are represented by self-adjoint/hermitean operators with real eigenvalues. It is argued that all self-adjoint operators are observables as they correspond to physical results and can be easily diagonalized. The use of self-adjoint operators is preferred due to their simplicity and the ability to describe the wave-function of a system. The concept of spin was introduced as a conserved quantity and has provided an accurate description of the properties of atoms. Any additional operators would require a change in the fundamental properties of elementary particles and therefore, it is not necessary to discover new operators in order to fully describe a particle.
humanino
2,527
An observable in QM is to be represented by a self-adjoint/hermitean operator, so that the eigenvalues are real numbers.
I could not find the answer to : are all self-adjoint/hermitean operators actually observables ?
Thank you for any help !
yes ! Why else would we need them in QM ?
All info is in the observables
regards
marlon
What you are saying is :
if I can exhibit ANY self-adjoint operator, then you can provide an experiment to find its spectrum ?!
Can you elaborate please ?
I read in :
https://www.physicsforums.com/showthread.php?t=9164
that only normal operators are needed :[tex][A,A^\dagger] = 0[/tex].
And it is even argued that we use self-adjoint operators because they are easy to handle !
Poska said:
We chose hermitian obserwables because they are easy. And we have good math. tools to get their spectrum, but there is no specyfic rule it's only rutine.
Poska apparently posted only one message, and received no answer.
I am currently confused :rolleyes: :confused:
What I am saying is that we need hermitian operators for two reasons. First the eigenvalues are real, which corresponds to fysical results. So yes any such operator produces a spectrum which has to correspond to some kind of real fysical situation that is to be verified in experiments. Second : we need them because they can be diagonalized with the eigenvalus on the diagonal. This makes the math a lot easier. Besides this is what we are always looking for when working with tensors in GTR for example. The more symmetry, the easier the matrix representations of the opertors get. The more zero's the better ! that is the rule
regards
marlon
I should add that :
http://groups.google.com/groups?sel...0pravda.ucr.edu
helped me to understand that one needs a complete set of commuting operators, spanning the entire space, and that it was realized by normal operators.
Then one can argue that, whatever the basis, one can change it for another one. The position basis for instance. Or the momentum basis. And any result in any basis can be expressed in the preffered basis, thus being observable.
This is rather disappointing to me.
Hey Marlon by the way, I remember we are born almost the same week ! :smile: Thank you again for your help ! Please add any comment to my last post !
humanino said:
I read in :
Attention, though we have QM-operators for which the above commutation-relation does not count. Such operators have no mutual eigenvalues. This is not good, because when you measure the first one (i.e. project it out on some chosen basis) you automatically influence the eigenvalues (and thus the measurement-results) of the second one. When the commutator is zero the operators can be diagonalized at the same time and their quantumnumbers entirely describe the wave-function of a system. E.G. : l (s-p-d-f-... energylevel) and m (magnetic number like spin up or down) quantumnumbers of an atom.
oui je sais, ceux de janvier sont les meilleurs...(je suis belge, voilà la raison que je parle le français)
humanino said:
I should add that :
why ? you should be happy with that
Well, not quite. My concern is : if one discovers a new operator, not commuting with the usual ones, but having some relevance and exhibiting self-adjointness. One can claim it is an observable, but does it necessarilly have its own physical interpretation ?
This is what happened with the spin ! The angular momentum was not conserved without spin, so one concluded it is an observable and particles do have intrisic angular momentum.
Now we know there is not any hidden variable, so we can safely hope we did not forget anything to describe entirely a particle, and there is no new operator to discover. I'm not quite confident about this last argument.
The way spin was introduced is a very nice example of how QM and even more QFT work. WE are always looking for conserved quantities because they correspond to certain symmetries of the math (here i am again with symmetry). The concept with total spin as a conserved quantity of which the operator is a Casimir-operator gives a very accurate description of the properties of atoms and so on...
You can be certain that for all atomic energy-levels we have the exact amount of necessary quantum-numbers that label each level, corresponding to experiments. More energy-levels and thus more operators could only occur when we change the fundamental properties of the elementary particles, but then we would be changing tyhe basis of QFT. Why do that, keeping in mind it gives us the best model up till now when it comes to atomic-phenomena : i.e. the standard model
regards
marlon
I realize I might just as well question the validity of quantum mechanics ! Well, I hope every physicists needs doubts now and then. :rolleyes: :rolleyes: :zzz:
What are you working on Marlon ?
just finished university in Ghent, master in theoretical fysics ; MY THESIS WAS ON THE QFT AND QUARKCONFINEMENT. In september i start to study nanotechnology and photonics at the university of Brussels. I hear that Paris is very high leveled on these subjects right ?
They hope so, I can't really compare :wink:
Well, I went three month at McGill University last year to study photonics (Multi-tunable-wavelenghts pulsed laser, in fiber) They had pretty much the same level as back in France, but more money :wink:
sounds hot topic (to me at least) I understand we could hear each other. But be carefull : I'm an experimentalist. Please talk slowly :biggrin: :-p
Read the Polyakov's (father) "Gauge fields and strings" yet ?
I tried. :rolleyes: :surprise: :smile:
be happy, normally them experimentalists have a much bigger bank-account. I want to become one of them too, hence the reason for this nanotechnology thing. Oh, yes, i also find it interesting...
marlon the poor theory-guy
no, is it available on site ? I am interested...
It is one of the greatest book for you to read I guess. It is kind of his diary, out of which he wrote a book. He goes beyond established theorems to discuss his views on the future developpement. For instance, he speaks about the link classical statistics/QFT, and stresses the importance of the Wilson (loop) operator. Everything has gauge confinement as general background.
I apologize to the people who really understand Polyakov's book. :redface: :shy:
I WOULD LIKE TO HAVE THIS BOOK? WHERE CAN I GET IT?
Any physics library at the university or the lab I guess...
A.M. Polyakov, one of the world's foremost leaders on the subject of field theory, has created a book from his own scientific diary, synthesizing the most promising approaches and ideals in field theory today. Polyakov presents such subjects as statistical mechanics, quantum field theory and their interrelation, continuous global symmetry, non-Abelian gauge fields, instantons and the quantum theory of loops, and quantum strings and random surfaces. This book is ideally suited for postgraduate students studying field theory and statistical mechanics and for research workers in continuous global theory.
From backcover. Again, the "Faraday flux lines" is the center. I am reading Rovelli's last book (Quantum gravity). Looking backwards in time, I understand how some few physicist are picked among the others...
Marlon left me to run at the library :biggrin:
It's too late Marlon, even in Belgium :smile:
tOMORROW? PLEASE GO GET IT AND SEND IT TO ME;
It would mean a lot to me.
Offcourse, Amazon tells me i can always buy it...
Is there no university in Gent ! You must be kidding me. I know Belgium might be the best state to learn QFT in Europe (maybe it's Germany). You must be able to find it near you. But I understand your rush. It sounds like a miraculous book. It is. :approve: :biggrin: :smile:
I'll post a new thread to get funds for you :wink:
Thanks, i will need it.
The university of Ghent does not want to give it to me. This book mas to be very very important.
I will wait for the financial resources provided by YOU, thanks
I must already send chocolates to Tsunami :rolleyes: :redface: :zzz: :zzz:
FAQ: Self-adjoint/hermitean operator vs observables
What is a self-adjoint/Hermitean operator?
A self-adjoint/Hermitean operator is a linear operator in a Hilbert space that is equal to its own adjoint. In other words, the operator and its adjoint have the same eigenvalues. This type of operator is important in quantum mechanics because it represents physical observables, such as energy or momentum.
What is the difference between a self-adjoint/Hermitean operator and an observable?
A self-adjoint/Hermitean operator is a mathematical object that represents a physical observable in quantum mechanics. An observable, on the other hand, is a measurable quantity in a physical system. While self-adjoint/Hermitean operators are used to describe observables, not all observables can be represented by self-adjoint/Hermitean operators.
How do you determine if an operator is self-adjoint/Hermitean?
In order for an operator to be self-adjoint/Hermitean, it must satisfy the condition that the inner product of the operator and a vector is equal to the inner product of the vector and the adjoint of the operator. This condition can be checked by calculating the eigenvalues and eigenvectors of the operator, as the eigenvalues of a self-adjoint/Hermitean operator must be real.
What is the significance of self-adjoint/Hermitean operators in quantum mechanics?
Self-adjoint/Hermitean operators are important in quantum mechanics because they represent physical observables, such as energy and momentum, which are essential in determining the behavior of quantum systems. They also have real eigenvalues, which correspond to the possible outcomes of measurements in quantum systems.
Can all physical observables be described by self-adjoint/Hermitean operators?
No, not all physical observables can be represented by self-adjoint/Hermitean operators. Some observables, such as spin, cannot be represented by a self-adjoint/Hermitean operator and instead require a different type of mathematical object known as a Hermitian operator. However, all self-adjoint/Hermitean operators can be used to represent physical observables in quantum mechanics.
