Can All String Shapes Be Derived from a Figure 8 Configuration?
  • Context: Graduate
  • Thread starter Thread starter RingoKid
    Shapes String
All variations of string shapes can indeed be derived from sections of a figure 8 shaped string, as established in string theory. This theory posits that particles, including electrons and quarks, are represented as tiny loops of string that vibrate in various ways, leading to different particle types. The discussion also explores the concept of our universe as a bubble-shaped brane, suggesting that we could exist on either the inside or outside surface of this brane, depending on its embedding in higher dimensions.
  • Understanding of string theory fundamentals
  • Familiarity with particle physics concepts
  • Knowledge of brane cosmology
  • Basic grasp of higher-dimensional spaces
  • Research the implications of string vibrations on particle types in string theory
  • Explore the concept of branes in higher-dimensional physics
  • Study the relationship between brane theory and cosmological models
  • Investigate the mathematical frameworks used in string theory
Physicists, students of theoretical physics, and anyone interested in advanced concepts of string theory and cosmology will benefit from this discussion.
RingoKid
brane and string shapes ?
Hello, I am an uneducated savage so please bear with me and respond in laymans terms if possible so essentially I have 2 questions
I was wondering if all variations of string shapes could be made from sections of a figure 8 shaped string which co incidentally or not is an infinity symbol ?
closed loops, open loops, straight sections even X shapes can be made from a figure 8 shape
http://www.nubreaks.com/forum/uploads/post-7-1088662741.jpg
I'd like to imagine that each point in the above figure represents a dimension that the string vibrates across but it needs to pass thru the cross over point of time and 3 others to register as a physical object in our universe if not then it registers as an effect like gravity or light. Given that it can change shape it could disappear from our universe and back again by vibrating in and out of any number of points/dimensions.
secondly
If our universe is a bubble shaped brane are we on the inside surface or the outside surface ?
I would actuallly like to think we are in between the 2 surfaces of separate branes so for all intents and purposes it appears as though our universe is embedded in a bubble skin whose "leading edge/surface" is expanding at lightspeed faster than it's "trailing edge" giving the impression of inflation but all the while moving in a higher medium, only we can't tell as we are always looking from the inside out. So depending on which way we were looking things would be either moving towards us or away.
thanks in advance
RK
Hello RK,
No worries, I will try my best to explain in simpler terms. Brane and string theory are complex concepts in physics, so it's completely understandable to have questions and need clarification.
To answer your first question, yes, all variations of string shapes can be made from sections of a figure 8 shaped string. In string theory, particles (such as electrons and quarks) are not thought of as tiny dots, but rather as tiny loops of string. These strings can vibrate in different ways, giving rise to different types of particles. So, in a sense, you could think of the figure 8 shape as representing the possible vibrations of a string that can create different types of particles.
As for your second question, the idea of our universe being a bubble-shaped brane is just one possibility in string theory. It is still a topic of ongoing research and debate, so there is no definitive answer yet. However, if we were to consider this idea, we could be on either the inside or outside surface of the brane. It really depends on how the brane is embedded in higher dimensions. It's difficult to imagine or determine from our perspective which surface we are on, as we are limited to observing our universe from within. But your idea of being in between two surfaces is an interesting concept to consider.
I hope this helps to clarify some of your questions. Keep exploring and learning about these fascinating concepts!
  • · Replies 19 ·
  • · Replies 42 ·
