What's the strongest magnetic field safe for humans?
In summary: The strongest magnetic field that you are ever likely to encounter personally is about 10^4 Gauss if you have Magnetic Resonance Imaging (MRI) scan for medical diagnosis. Such fields pose no threat to your health, hardly affecting the atoms in your body. Fields in excess of 10^9 Gauss, however, would be instantly lethal. Such fields strongly distort atoms, compressing atomic electron clouds into cigar shapes, with the long axis aligned with the field, thus rendering the chemistry of life impossible. A magnetar within 1000 kilometers would thus kill you via pure static magnetism -- if it didn't already get you with X-rays, gamma rays, high energy particles, extreme gravity, bursts and flares...In summary
DeuteriumDude
35
Hi all!
I'm a neuroscience major and I'm planning my senior honors thesis right now. I'm interested in magnetoreception (ability to sense magnetic fields), and I'd like to do something involving the effect of a strong magnetic field on humans' or animals' navigational abilities and/or behavior. Basically, I'd love to use humans ... but I'm not sure if I can safely expose people to a >1 Tesla B field. I know that really strong magnetic fields can disrupt electrical firing in the brain ... or is that only magnetic pulses? Anyway, does anyone know how strong of a field I can use? Or if I need to already be an MD to do it?
Also, if I can't use humans, what would be a good animal to test? I can't find a comprehensive list of which animals have already been shown to have magnetoreception and which animals are yet to be tested. I'm thinking lower mammals would be great. Anybody have any suggestions for me? Thanks!
Biology news on Phys.org
I recall reading somewhere that someone has recently built an 11T human MRI.
Magnetic fields by themselves are not dangerous, but rapidly changing magnetic fields can be.
Right, rapidly changing magnetic fields would create flux. But wouldn't even an unchanging magnetic field move ions in the brain?
Not at any static field strengths you would be likely to achieve. (Unless you have an unlimited budget).
DeuteriumDude said:
Hi all!
Shall I assume you have already made a comprehensive search in your college library and the web of magnetoreception? If you have, you may notice that organisms that do respond to the Earth's magnetic field (assisting navigation) don't require very much magnetic field (30-60uT) to do so. What is your reasoning for choosing a strong magnetic field?
Well, birds and insects would respond to 30-60 micro-Teslas, but humans wouldn't. Basically, I'm guessing that humans have some capacity to sense magnetic fields, but it's so weak in us and probably in other mammals that you would need a field a few orders of magnitude stronger than Earth's.
It's easy to find general info on the web about magnetoreception, but hard to find anything very specific (e.g., a comprehensive list of organisms known to have it). Hadn't thought of the library though ...
I believe that the March 2006 Scientific American has short article on space traveler shielding mentioning that someone would see flashes and have an acid taste when they moved their head while next to an accelerator magnet.
Also see http://www.ru.nl/hfml/research/levitation/diamagnetic/
A chemist friend of mine claimed they could see colors by working with their head under the NMR magnet
Magnetic field shouldn't have much effect (harmfully) on a human. At least if what you're doing is what I am reading you are doing.
Wow! I would love to research that! Sounds like the sort of thing Jim1138 was talking about ... sadly, the Scientific American website won't let me view the whole article, so I couldn't read the part about magnetic field hallucinations. I did find some interesting stuff upon further googling, though. Jim1138, mgb_phys, do you think this is the sort of thing you're talking about?
http://www.assap.org/newsite/htmlfiles/MADS.html
http://en.wikipedia.org/wiki/Michael_Persinger
Thanks for bringing that to my attention!
Yes, I think below about 10 Tesla you can't do much harm. But at some point a static magnetic field will do damage:
http://solomon.as.utexas.edu/~duncan/magnetar.html
huh, that's interesting. i had no idea a static field could do that.
my one experience being in the same room as an NMRI machine left me feeling a little off-balance/weird. sure, static fields don't move ions and electrons. but that field is only static to the extent that you don't move within it. once you start rotating your body within the static field, it has the same effect as you sitting still while a multi-tesla field rotates across you. and as any engineer will tell you, a rotating magnetic field pushes current just fine. 'course, it's not actually that big a field just standing in the same room. you're just feeling the effects of the fringe field, which is much smaller than the field in the center of the machine.
I have seen a TV show about magnetic fields where a mouse was levitated inside a very strong magnet. The mouse show no signs of discomfort. So I suspect that your budget will be the limiting factor rather than the strength of the field humans can tolerate.
DeuteriumDude said:
Hi all!
You'll need to make sure you bounce all of your ideas off of whomever is assigned to deal with the projects. In the systems within which I do my work, to work with humans you need ethical approval - this can be time-consuming to obtain, especially when the work itself is original. (for instance, you may apply for ethical approval for some sort of brain imaging study, using commonly tested MRI. Here the ethics are about the data and care of patients more so than whether or not the technique will show results. Testing without expectation is difficult to justify.)
Yeah, I feel like this is a risky idea. :rolleyes: Not only is there the hassle of either getting approval to use humans or animals, but I really don't know if I'll see good results. I have a safer idea for an honors thesis that I also posted on the medical forum. I'd love to get some input on it, if some of you wouldn't mind reading it. Thanks!
I always think of the library as being for humanities people ... :frown:
I'm wondering if the distinction between static and oscillating magnetic fields doesn't become academic at some point regarding living systems. In terms of relative motion, the heart is beating, blood and lymph is flowing, and there are micro-currents everywhere. Obviously any motion in a "static" magnetic field creates electrical potentials.
FAQ: What's the strongest magnetic field safe for humans?
What is the strongest safe magnetic field for humans?
The general consensus among scientists is that a magnetic field of up to 2 Tesla (T) is considered safe for humans. However, this may vary depending on individual sensitivity and exposure time.
Can exposure to strong magnetic fields harm humans?
Yes, exposure to strong magnetic fields can have adverse effects on human health. These effects can range from nausea and dizziness to more serious conditions such as nerve and brain damage.
How are magnetic fields measured?
Magnetic fields are measured in units of Tesla (T) or Gauss (G). 1 T is equal to 10,000 G. Devices called magnetometers are used to measure magnetic fields.
What are the sources of strong magnetic fields in everyday life?
Some common sources of strong magnetic fields include MRI machines, electrical power lines, and industrial equipment such as generators and motors. Additionally, electronic devices such as laptops and cell phones also emit magnetic fields, although at much lower levels.
Can magnetic fields from everyday objects like laptops and cell phones be harmful?
The magnetic fields emitted by everyday objects are generally too weak to cause harm to humans. However, prolonged exposure to these low-level magnetic fields may still have some health effects, although more research is needed to fully understand their potential impact.
