Police car's acceleration physics problem
The problem involves a police car accelerating after being passed by a speeder. The police car's initial speed is 95 km/h, and it accelerates at 2.00 m/s² after a 1-second delay. The speeder maintains a constant speed of 140 km/h. The goal is to determine the time it takes for the police car to overtake the speeder.
  • Mixed
  • Participants discuss converting speeds from km/h to m/s and applying kinematic equations to find the time until the police car overtakes the speeder. There are attempts to set up equations based on distance traveled by both vehicles.
Multiple participants have shared their calculations and results, with some expressing confusion over their answers. There is an ongoing exploration of the correct setup for the equations, and some participants are questioning their unit conversions and the assumptions made in their calculations.
Participants note discrepancies in their results and the importance of correctly interpreting the timing of the police car's acceleration. There is also mention of the online homework system indicating incorrect submissions, prompting further discussion on the setup of the problem.
physicsss
A police car traveling a constant 95 km/h is passed by a speeder traveling 140 km/h. Precisely 1.00 s after the speeder passes, the policeman steps on the accelerator. If the police car's acceleration is 2.00 m/s2, how much time passes after the speeder passes before the police car overtakes the speeder (assumed moving at constant speed)?
I converted 95 km/h to 40 m/s, and 95 to 26 m/s, then I use the equation
x = x + v*t + 1/2 * a *t^2
40 m/s * t + 40 m = 0 + 26 m/s * t +1/2*2.0*t^2
t=15, but that's wrong...any ideas?
[tex]95t+\frac{1}{2}at^2=140(t+1)[/tex]
... where a is the acceleration with appropriate units, of course! :-)
I still get t=15 with that equation. :confused:
You did? I got 6.3 minutes if I did my arithmetic right - seems too long though! Check to see if you converted the units on your acceleration correctly.
well, since the final answer is in seconds, I converted 140 km/h and 95km/h to m/s. So
95km/h * 1h/60min * 1min/60s * 1000m/1km= 26.389 m/s and
140km/h * 1h/60min * 1min/60s * 1000m/1km= 38.889 m/s.
so 26.389*t+1/2*2.0*t^2=38.889(t+1)
and t=15 s.
:bugeye:
Oh! The t+1 in my original equation was incorrect. I was mixing seconds with hours. When I correct for that I get something closer to what you have (15.9s).
How do you know your answer is wrong?
The homework is online and when I entered 15s and submitted, it said it was incorrect.
You are getting distance, not acceleration, from that formula. The original formula Tide gave is correct. You need only solve for time. Keep trying.
Chronos, can you clarify what you said?
This isn't quite right for several reasons.
Measuring everything from the moment the speeder passes the police car (at t = 0):
Distance police car travels: [itex]x_p = v_p t + \frac{1}{2}a(t-1)^2[/itex], note that acceleration only begins at t = 1 second, [itex]v_p[/itex] is the initial speed of the police car in m/s.
Distance speeder travels: [itex]x_s = v_s t[/itex], [itex]v_s[/itex] is the speed of the speeder in m/s.
So, when the police car overtakes the speeder:
[tex]v_p t + \frac{1}{2}a(t-1)^2 = v_s t[/tex]
All times measured in seconds. Now plug in your values and solve for t.
Thanks, Al, I stand corrected!
I got 14.4 seconds, is that correct?
  • · Replies 25 ·
  • · Replies 18 ·
