An exact expression for the fine structure constant
The discussion presents an exact expression for the fine structure constant, represented as α, which is defined as 1/137.03599911. The equation α^{-\frac{1}{2}} + α^{\frac{1}{2}}μ = e^{\pi^2/4 is introduced, where μ is Schwinger's first term of the electron's magnetic moment anomaly, calculated as 1 + α/(2π). Substituting the value of α into the equation yields a calculated value for π that closely approximates the known value, differing only in the 10th digit. This calculation results in a refined value for the fine structure constant of 1/137.03599952837, which falls within the measurement range.
  • Understanding of the fine structure constant (α)
  • Familiarity with quantum electrodynamics concepts
  • Knowledge of Schwinger's contributions to particle physics
  • Basic proficiency in mathematical expressions involving exponentiation and logarithms
  • Research the implications of the fine structure constant in quantum electrodynamics
  • Explore Schwinger's theory on the electron's magnetic moment anomaly
  • Study the mathematical derivation of π and its significance in physics
  • Investigate the experimental measurements of the fine structure constant
Physicists, mathematicians, and students interested in quantum mechanics, particularly those focusing on the fine structure constant and its applications in theoretical physics.
Hans de Vries
Just for the record:
[tex]\ \alpha^{-\frac{1}{2}}\ +\ \alpha^\frac{1}{2}\mu\ =\ e^{\pi^2/4}[/tex]
Where [itex]\alpha[/itex], the fine-structure constant = 1/137.03599911 (46)
and [itex]\mu=1+\frac{\alpha}{2\pi}[/itex] is Schwingers first term of the electrons
magnetic moment anomaly which is a function of [itex]\alpha[/itex] as well.
[itex]\alpha^\frac{1}{2}[/itex] is the probability for an electron to emit or absorb a photon.
Fill in 1/137.03599911 for [itex]\alpha[/itex] and you'll get for pi:
3.14159265263 which only differs in the 10th digit with the real value:
3.14159265358...
Using the exact value for pi results in a value for the fine structure
constant of: 1/137.03599952837 which is within the measurement range.
Does it mean anything? maybe, maybe not.
Regards, Hans
  • · Replies 80 ·
