Energy proportional to Amplitude squared?
In summary, the energy of a wave is directly proportional to the square of its amplitude. This means that as the amplitude of a wave increases, so does its energy, and vice versa. This relationship is important in understanding the behavior of waves and their impact on various systems and phenomena.
SamRoss
36
Does anyone know a simple derivation that explains why the energy of a wave is proportional to the amplitude squared?
Does "simple" allow for calculus?
A wave is a collection of simple harmonic oscillators. The energy of a SHO equals the potential energy at maximum displacement. The PE at maximum displacement is the work done by an external force in pushing the oscillator out from the equilibrium position to maximum displacement. The external force acts against the oscillator's internal force which obeys Hooke's Law F = -kx.
[tex]\int_0^A {F(x)dx} = \int_0^A {kx dx} = \frac{1}{2} kA^2[/tex]
Why doesn't this work for EM waves ?
Why should it? What constant would you introduce in place of k, bearing in mind that it must have the same unit, and there isn't a spring constant for an EM wave.
Thanks for the quick reply. I was actually thinking of an EM wave, though. Do you know a derivation for that as well?
In general, not just in EM waves, the energy density of an electric field E is proportional to E^2, and the energy density of a magnetic field B is proportional to B^2. Introductory textbooks usually derive these by considering the external work it takes to charge up a parallel-plate capacitor so that it has a field E between the plates:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capeng.html
or to increase the current flowing through a long solenoid (inductor) so it has a field B inside:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/indeng.html
cool, thanks
FAQ: Energy proportional to Amplitude squared?
What is "Energy proportional to Amplitude squared?"
"Energy proportional to Amplitude squared" is a scientific principle that states that the energy of a wave is directly proportional to the square of its amplitude. In other words, the greater the amplitude of a wave, the more energy it carries.
How is "Energy proportional to Amplitude squared" used in scientific research?
This principle is used in various fields of science, including physics, acoustics, and engineering. It is often used to calculate the energy output of different types of waves, such as sound waves and electromagnetic waves.
What is the mathematical formula for "Energy proportional to Amplitude squared"?
The mathematical formula for this principle is E∝A², where E represents energy and A represents amplitude. This means that energy is directly proportional to the square of the amplitude of a wave.
What is the significance of "Energy proportional to Amplitude squared"?
This principle is significant because it helps scientists understand the relationship between the energy and amplitude of a wave. It also allows for the calculation of energy levels in various wave phenomena, which is crucial in many fields of research.
Are there any limitations to "Energy proportional to Amplitude squared"?
While this principle is widely accepted and used in scientific research, it does have some limitations. It assumes that the medium through which the wave is traveling is uniform, which is not always the case. Additionally, it may not accurately represent the energy of all types of waves, such as non-linear waves.
