How valid of an assumption is using mg/kg for drug dosage?
  • Thread starter Thread starter Simfish
The discussion revolves around the validity of using mg/kg as a standard measure for drug dosage in relation to body mass. Participants explore the assumptions behind this metric, questioning whether the relationship between body mass and drug dosage is truly linear, and how factors such as blood volume and tissue composition may influence drug distribution and efficacy.
  • Some participants propose that while body mass generally correlates with drug dosage, the relationship may not be strictly linear due to variations in blood volume and distribution across different body types.
  • Questions are raised about the fixed nature of blood volume in major arteries and veins compared to peripheral blood vessels, suggesting that increases in body mass may not proportionately increase blood volume.
  • There is a discussion on whether fat tissue is more vascularized than other types of tissue, which could affect drug distribution.
  • Some participants argue that the size of the heart and arteries varies with body size, which may complicate the assumption of linearity in drug dosage based on mass.
  • Concerns are expressed about the assumption that drugs diffuse equally throughout the body, including capillaries, which may not hold true for all substances.
  • It is noted that while fluid spaces may scale linearly with body size, individual physiological variations could lead to non-linear relationships in drug dosage requirements.
  • Some drugs, particularly psychoactive ones, may not follow the mg/kg scaling, indicating that generalizations about drug dosage based on body mass can be misleading.
  • The concept of volume of distribution is introduced, highlighting how various factors such as solubility and tissue binding affect drug behavior in the body.
Participants express multiple competing views regarding the linearity of drug dosage scaling with body mass. The discussion remains unresolved, with no consensus on the validity of using mg/kg as a reliable measure across all drug types.
Limitations include the potential for physiological variation among individuals, the influence of body composition on blood volume and drug distribution, and the complexity of drug interactions with body systems that may not be captured by a simple mg/kg metric.
Simfish
Okay, basically, the more mass you have, the more drug that's needed to exert the same effect on you.
But is it really linearly proportional like that?
I mean, if you increase your body mass, you're not going to increase the amount of blood in your major arteries and veins. The amount of blood in them is fairly fixed (or is it?)
Rather, you'll increase the amount of blood in more peripheral blood vessels. How much does this amount of blood scale with increased mass? Is fat tissue more vascularized (on average) than other types of tissue? Or not? Furthermore, is it a valid assumption that a drug will diffuse "equally" throughout the body, including all of the body's capillaries?
Biology news on Phys.org
Well, let's start simple, does a baby have the same size heart as a full grown adult? Does a baby have the same size arteries as an adult? and so on.
Can you see my point here?
Yes, I definitely see your point there, although it wasn't the picture I was looking at.
What I was thinking about is more like this: Would a fully grown 150kg human adult have 3 times the blood volume of a fully grown human adult weighing 50kg?
Well all of the living cells in your body require a blood supply. If you have a larger amount of said cells, would you need more or less in the way of blood transportation and blood volume?
That's true. But you could divide blood volume by body mass for a set of humans. The real question is - is it a linear function? Or could it be more nonlinear than we realize? (if so, that could make the mg/kg metric less reliable than we think).
Well if you know the average blood supply to 1kg of body mass, then it is a pretty linear function.
You could take many samples of body mass at 1kg and check to ensure they all have roughly the same value.
That is the intuitive way to generate the hypothesis. But we would also need to compare this value between different people - because thin people owe a greater proportion of their blood volume to their major blood vessels - whose volume cannot increase with body mass. It's entirely possible that it's a nonlinear function of body weight among adult individuals of a given height. (it's also entirely possible that the function could be non-linear for increases in height too, although I think this is less likely).
Fluid spaces scale pretty dog-gone linearly with body size. There is a "standard" or "average" person for each group that calculations are done. For instance the "standard" male for age 17-34 is 70 Kg.
60% of the 70 Kg mass is fluid or 42 L. Of the 42 L, approximately 35-45% (40% avg) will be intracellular fluid (ICF) or 28 L.
Extracellular fluid (ECF)volume is 15-25% (20% avg) or approximately 14 L.
Of that (the ECF) approximately 5% is plasma (3.5 L) and approximately 15% is interstitial fluid (ISF) or 10.5 L.
For the given age group, these numbers make a very close approximation, so for the age group of 17-34 you can use these percents to calculate dosage when giving IV drugs or orals, etc. One must also consider things like the rate of clearance by the kidneys (weak acids and bases, like some drugs are (penicillin for example), are cleared rapidly by the kidneys unless given in excessive amounts).
Of course, there is variation in the population either through physiological variation or pathology, such as dehydration or edema etc. Which can alter the fluid spaces and must be something the prescribing physician takes into consideration.
MDs have these nice little charts and calculators for body size and drug prescribing, though most people fall within the bell curve and the averages can be use. Thankfully, this is something medical physiologists looked into :)
The size of vasculature and amount of whole blood volume in said vasculature also scales very well with body size.
Ah yes, thanks for this very nice reply! :)
That's not true for all drugs- some psychoactive ones, in particular, do not have a dose-response that scales with body mass.
Given the variety of drugs we have at our disposal, it's hard to generalize. Many drugs are water soluble, some are fat soluble, some cross the blood-brain barrier, some don't. Some are tissue bound, others protein bound, etc. A key concept is the volume of distribution which the relates the time integrated change in blood plasma levels from time [tex]t_{0}[/tex] in a theoretical volume following the administration of known doses by known routes. This is affected by all the above variables (and more) plus rates of excretion, deposition in fat and bone and the production of metabolites which may or may not be measured in the plasma depending on whether they are active metabolites or not. The link below is a fair summary to just give a sense of the issues involved.
The recommendations for dosage by unit/kg are based on adjustments for these pharmacokinetic parameters, but prescribers must also estimate the fat/lean body mass ratios, level of hydration, renal and liver function, and other special situations that may exist. Dosages in children are also subject special guidelines.
http://www.merckmanuals.com/professional/sec20/ch303/ch303d.html
Note: multiple pages
11K
9K
  • · Replies 29 ·
