Why Does a 2x2 Matrix [x y; y z] in the PSD Cone Imply x>=0, z>=0, and xz>=y^2?
In summary, a positive semidefinite cone is a mathematical concept that represents a set of symmetric matrices with non-negative eigenvalues. It is commonly used in optimization and linear algebra to define the feasible region of a problem. It is also related to positive definite cones, with positive definite matrices being a subset of positive semidefinite matrices. The positive semidefinite cone has various applications in mathematics, engineering, and computer science, including optimization, control theory, signal processing, and machine learning. It also has uses in quantum mechanics for describing density matrices.
peterlam
Hi!
If we have a 2x2 matrix [x y;y z] belonging to a positive semidefinite cone. Why is it equivalent to say x>=0, z>=0, and xz>=y^2?
Thanks!
A matrix is PSD if and only if it's principal minors are nonnegative (see http://en.wikipedia.org/wiki/Positive-definite_matrix#Characterizations").
A 2x2 matrix has three principal minors - the diagonal elements, and the determinant. So x,z >= 0, and xz - y^2 >=0.
I'm sure there is a way to see this without having to use the principal minors characterization though.
FAQ: Why Does a 2x2 Matrix [x y; y z] in the PSD Cone Imply x>=0, z>=0, and xz>=y^2?
What is a positive semidefinite cone?
A positive semidefinite cone is a mathematical concept that describes a set of symmetric matrices with non-negative eigenvalues. It is a type of convex cone that is often used in optimization and linear algebra.
How is a positive semidefinite cone used in optimization?
In optimization, the positive semidefinite cone is used to represent the feasible region of a problem. This means that the solutions to the problem must lie within this cone in order to be considered valid. The cone also plays a crucial role in the formulation and solution of semidefinite programming problems.
What is the relationship between positive semidefinite cone and positive definite cone?
A positive definite cone is a subset of the positive semidefinite cone, meaning that it contains all the matrices with strictly positive eigenvalues. In other words, all positive definite matrices are also positive semidefinite, but the reverse is not necessarily true.
How is the positive semidefinite cone related to positive definite matrices?
Positive semidefinite matrices are a generalization of positive definite matrices. While positive definite matrices have all positive eigenvalues, positive semidefinite matrices may have zero eigenvalues. However, both types of matrices have similar properties and can be used in similar ways in mathematical applications.
What are some applications of the positive semidefinite cone?
The positive semidefinite cone has various applications in mathematics, engineering, and computer science. It is used in optimization problems, control theory, signal processing, and machine learning. It also has applications in quantum mechanics, where it is used to describe the set of possible density matrices.
