Merging NCG matter with Spinfoam LQG spacetime (new Pfaeffle-Stephan)
In summary, the paper discusses how elements of fermionic quantum field theory can emerge from a geometrical construction over a configuration space of connections.
marcus
Dearly Missed
24,775
792
This thread is in case discussion of the following paper is wished.
http://arxiv.org/abs/1102.0954
The Holst Action by the Spectral Action Principle
Frank Pfaeffle, Christoph A. Stephan
11 pages
(Submitted on 4 Feb 2011)
"We investigate the Holst action for closed Riemannian 4-manifolds with orthogonal connections. For connections whose torsion has zero Cartan type component we show that the Holst action can be recovered from the heat asymptotics for the natural Dirac operator acting on left-handed spinor fields."
(If anyone is coming in new to this, Holst action is the action used in Spinfoam LQG and Spectral Action Principle means they are talking Connes NC geometry realization of standard model matter. The title indicates they want to put Connes-style standard model matter together with LQG, which in fact is where they are going in the paper. They reference the standard LQG books Rovelli and Thiemann, and basic Connes and Chamseddine NCG papers about standard model matter. It seems to me that Pfaeffle and Stephan are trying to do something like what John Barrett was saying should be done in his January 2011 paper.)
In post #1410 of the QG bibliography I logged a paper by John Barrett, "Induced standard model and unification" which has now been given a new title:
http://arxiv.org/abs/1101.6078
State sum models, induced gravity and the spectral action
John W. Barrett
13 pages
(Submitted on 31 Jan 2011)
"A proposal that the bosonic action of the standard model is induced from the fermionic action is investigated. It is suggested that this might occur naturally in state sum models."
This paper puts Prof. Christian Bär on the map for me:
http://geometrie.math.uni-potsdam.de/index.php/de/mitarbeiter/prof-dr-christian-baer
Dr Pfaeffle and Dr Stephan are researchers at the Math Institiute at Uni Potsdam.
Prof. Bär is the senior geometry guy at the Math Institute. He has more papers and has been there longer. The two newer members have co-authored with him---now they are doing significant work on their own.
I will add all three to my list of people to watch out for.
Christoph Stephan lists his interests here:
http://geometrie.math.uni-potsdam.de/index.php/de/mitarbeiter/dr-christoph-stephan
  • Nichtkommutative Geometrie
  • Diracoperatoren in der Physik
  • Elementarteilchenphysik
http://geometrie.math.uni-potsdam.de/index.php/de/mitarbeiter/dr-christoph-stephan/profil
It is nice to see the German establishment gear up for QG research at the University level. Like establishing a LQG group at Erlangen headed by Thiemann, a year or so ago.
Before, like 2 or more years ago, the activity was concentrated at Hermann Nicolai's branch of Max Planck Institute---at a special MPI QG branch, not at teaching institutions.
Now Sahlmann is at Karlsruhe, Thiemann is at Erlangen with a whole new group of postdocs, and Nicolai is hosting another generation (Oriti, Dittrich...) at the MPI. Gradually things grow and change.
http://arxiv.org/abs/1105.0194
From Quantum Gravity to Quantum Field Theory via Noncommutative Geometry
Johannes Aastrup, Jesper M. Grimstrup
(Submitted on 1 May 2011)
"A link between canonical quantum gravity and fermionic quantum field theory is established in this paper. From a spectral triple construction which encodes the kinematics of quantum gravity semi-classical states are constructed which, in a semi-classical limit, give a system of interacting fermions in an ambient gravitational field. The interaction involves flux tubes of the gravitational field. In the additional limit where all gravitational degrees of freedom are turned off, a free fermionic quantum field theory emerges."
Nicoo, thanks for mentioning that paper.
You may have noticed that one of the authors, Jesper Grimstrup, is presenting their results this month at the Loops 2011 conference:
http://loops11.iem.csic.es/loops11/index.php?option=com_content&view=article&id=100%3Ajesper-grimstrup-coupling-matter-to-quantum-gravity-via-noncommutative-geometry&catid=36%3Aparallel-sesions&Itemid=73
Coupling Matter to Quantum Gravity via Noncommutative Geometry.
Jesper Grimstrup
CFMAC Room. Tuesday, May, 24th, 15:05 - 15:25.
Abstract:
In my talk I will show that elements of fermionic quantum field theory emerge from a geometrical construction over a configuration space of connections. The construction is a spectral triple - the key object in a noncommutative geometry - and it is built over an algebra of holonomy loops. The spectral triple encodes the kinematics of quantum gravity. It turns out that the spectral triple involves a natural class of semi-classical states which, in a semi-classical approximation, gives a system of interacting fermions. Furthermore, in the approximation where all gravitational degrees are "turned off" a free fermionic quantum field theory emerges. Thus, the spectral triple establishes a direct link between canonical quantum gravity and fermionic quantum field theory.
Thanks Marcus for the info. That conference definitively looks interesting :)
1. What is NCG matter and Spinfoam LQG spacetime?
NCG matter refers to non-commutative geometry matter, which is a theoretical framework in physics that describes the properties of space and matter using mathematical concepts from non-commutative geometry. Spinfoam LQG spacetime is a theory that combines the principles of loop quantum gravity (LQG) and spinfoam models to describe the discrete structure of spacetime.
2. How does the Pfaeffle-Stephan model merge NCG matter with Spinfoam LQG spacetime?
The Pfaeffle-Stephan model proposes a new approach to combining NCG matter and Spinfoam LQG spacetime by introducing a new set of mathematical equations that unify the two theories. This model suggests that the discrete structure of spacetime is built from non-commutative geometric objects, which can interact with matter through specific rules and interactions.
3. What are the potential implications of merging NCG matter with Spinfoam LQG spacetime?
If successful, the merging of these two theories could lead to a more comprehensive understanding of the fundamental properties of the universe. It could also provide new insights into the behavior and interactions of matter and energy at a quantum level, potentially leading to new technologies and applications.
4. How does the Pfaeffle-Stephan model differ from other attempts to merge NCG matter and Spinfoam LQG spacetime?
The Pfaeffle-Stephan model differs from other attempts in that it proposes a more comprehensive and unified approach to merging these two theories. It also introduces new equations and principles that have not been previously considered, potentially providing a more complete understanding of the relationship between matter and spacetime.
5. Are there any current experiments or observations that could support or refute the Pfaeffle-Stephan model?
At this time, there are no specific experiments or observations that can directly support or refute the Pfaeffle-Stephan model. However, ongoing research and experimentation in the fields of non-commutative geometry, loop quantum gravity, and spinfoam models may provide insights and evidence that could validate or disprove this theory in the future.
  • Beyond the Standard Models
