Determining a centripetal force proportionality equation
In summary, a centripetal force proportionality equation is a mathematical relationship that describes the relationship between the centripetal force acting on an object and the variables that affect it. It can be determined using Newton's second law of motion and is affected by the object's mass, velocity, and radius. This equation can be used for all types of uniform circular motion and has various real-world applications in industries such as aerospace and automotive engineering.
ova5676
29
In a lab, we essentially used an apparatus similar to this:
In three experiments with several trials, we varied three things: centripetal force (the mass of the bottom), radius (of the circle by adjusting the alligator clip), and mass (rubber stopper). The trials were varied as well (increasing radius, increasing bottom mass, increasing rubber stopper mass). So, we ended up with 3 graphs for each experiment where each point was a trial. My question is:
1) How do I combine those proportionality into one equation in terms of Fc?
2) How can I find a proportionality constant
3) How can I find the percent error for k?
According to my graphs, the proportionality constants were T ∝ r, T ∝ 1/Fc and T ∝ m^2.
1) That means T = r, T = 1/Fc, and T = m^2, correct?
So r = 1/Fc = m^2. How would I get that to be Fc = etc. etc.?
2) Using whatever equation is produced from 1), I would put k after Fc. So, say Fc = m^2 * r / T, it would be Fc = km^2*r/T.
How would I find k though? What values do I substitute? I have three different experiments with several trials within each one that vary?
3) I don't know how to find % error for k? Would that be slope as the theoretical and the actual is the calculate one from 2)?
If the units don't match it cannot be correct. A time is not a distance, for example.
If a quantity is proportional to x and proportional to an independent y then it's proportional to the product of x and y:
T ∝ r m2/Fc
Assuming T is the revolution period your relations are wrong, however, the left side should always be T2 and in the last case T2 ∝ m
T2 ∝ r m/Fc
Introducing a proportionality constant c:
T2 = k r m/Fc
And solving for k:
k = T2 Fc / (r m)
You can calculate that value for every measurement and find k. Ideally you get very similar values for all individual data points. The spread of the measurements gives an idea how good the measurement is.
Likes topsquark
how do I find the value of t while it is not given?
in a case like this I have two missing values!
How are you defining t? Post #1 refers to T, which is presumably the rotation period and would have been measured as part of the experiment.
Likes topsquark
After a trial was over, you recorded the value of whichever of the three things you varied and the fixed values of the other two. Is that all you recorded? If you recorded the period, which is the dependent variable, note that you have three measured independent variables. I think what you are expected to do is combine all three into a single independent variable. You can do that if you find an expression for ##T^2## and put it on the left-hand side. The right-side can only have the three independent variables and constants like ##g## and ##\pi##. I will not tell you what the equation looks like because this is a homework thread and you have to find the equation on your own. A good start in that direction is provided by @mfb, however the expression contains Fc which is not one of the three independent variables.
The final equation will look like $$T^2=k~X$$where ##k## is the proportionality constant that (I think) you are seeking and ##X## is the particular combination of hanging mass ##m_h##, cork mass ##m_c## and radius ##R## that appears in your derived equation for ##T^2##.
Note that if you have taken ##n_1## data points varying ##m_h##, ##n_2## data points varying ##m_c## and ##n_3## data points varying ##R##, the total number of data points will be ##N=n_1\times n_2 \times n_3.## Plot all ##N## of them on a single graph of ##T^2## vs. ##X## and figure out the slope ##k##. Then see if it agrees within experimental error (error propagation is needed for that) with the constant value that is predicted by the equation that you derived for ##T^2.##
Likes topsquark
Post #1 is 11 years old. Post #3 is the current question.
  • Wow
Likes kuruman and topsquark
Right you are. I didn't think a mentor would reply to an eleven year old question so I didn't check the date of the original post. I shall have to be more careful.
Thank you for the promotion.
Likes berkeman
Considering all the pro bono work that mentors have to do, I am not sure it's a promotion - superpowers notwithstanding. Anyway, I was referring to the fairly recent post #2 by @mfb that started this ball rolling.
This was part of an effort to reduce the number of unanswered but popular threads (in search engines).
@nagham T would be measured in this experiment. If you have a question about a different experiment, please start your own thread.
Likes SammyS and kuruman
FAQ: Determining a centripetal force proportionality equation
What is a centripetal force proportionality equation?
A centripetal force proportionality equation is a mathematical relationship that describes the relationship between the centripetal force acting on an object and the variables that affect it, such as mass, velocity, and radius. It is often used to calculate the amount of centripetal force needed to keep an object moving in a circular path.
How do you determine the centripetal force proportionality equation?
The centripetal force proportionality equation can be determined using Newton's second law of motion, which states that the net force acting on an object is equal to its mass multiplied by its acceleration. In the case of circular motion, the acceleration is directed towards the center of the circle and is equal to the square of the object's velocity divided by the radius of the circle. By setting the net force equal to the centripetal force, and rearranging the equation, we can determine the proportionality between the force and the variables affecting it.
What are the variables that affect the centripetal force?
The variables that affect the centripetal force are mass, velocity, and radius. As the mass of an object increases, the amount of force needed to keep it moving in a circular path also increases. Similarly, as the velocity of an object increases, the amount of force needed to keep it in a circular path also increases. The radius of the circle also affects the force, with a smaller radius requiring a larger force to maintain circular motion.
Can the centripetal force proportionality equation be used for all types of circular motion?
Yes, the centripetal force proportionality equation can be used for all types of circular motion, as long as the motion is uniform (constant speed) and the force acting on the object is directed towards the center of the circle. This includes objects in circular orbits, as well as objects moving in a horizontal circle on a frictionless surface.
How is the centripetal force proportionality equation used in real-world applications?
The centripetal force proportionality equation is used in many real-world applications, such as designing roller coasters, determining the optimal speed for cars to navigate turns, and calculating the force needed to keep satellites in orbit around the Earth. It is also used in industries such as aerospace and automotive engineering to ensure the safety and stability of objects moving in circular paths.
