Architecture Student Seeks Advice on Wind-Catcher Design
The discussion centers on the effectiveness of a proposed architectural design that incorporates wind-catcher techniques. The air movement in the design is qualitatively correct, but determining the strength of the air current requires complex calculations. Generally, air movement is expected to decrease at night due to a lower temperature gradient, although this can vary based on regional climate factors. The design's highest point may function as both a solar chimney during the day and a wind-catcher at night, with hot air rising and cool air entering. However, the presence of water for evaporation could reduce system efficiency. The air is lighter when heated, and it continues to rise, potentially forming clouds, even at night, though the movement rate will be lower than during the day.
shoayb
hi
am an architecture student , i used some techniques in my project which it will work same as the wind-catcher , but am not sure how it will work , so can anyone tell me if the air movement is correct in my drawing or its wrong ?
and is there any difference in the air movement between day and night in such case ?
this is the drawing , somehow like a mountain or a tent ( section cutting the building in 2 parts ) :
http://i810.photobucket.com/albums/zz30/Shoayb/day.jpg
i hope its clear
Looks good. To find out exactly how effective it is (how strong the air current is) would be a fairly difficult calculation, but qualitatively it is correct. During night you would (generally) expect the air current to decrease, as the temperature gradient is lower (but that depends on some details of the region, climate, etc).
Your colors are reversed. The night difference is the airflow stops.
thanks you for your help :)
i didnt get it , i think you mean the direction maybe wrong not the colors
what i know that the cool air is lighter than the hot air that's why the air is becoming hotter when it goes up until it get outside the building , and then the hot air from outside will be cooled when it reach the water because of the evaporation , and the cycle will go on
but am not sure if the highest part will work as solar chimney or as wind-catcher , i mean is the hot air leaving from the highest point or entering from it ? because someone told me that it will work as solar chimney in the day and as wind-catcher in the night , and i don't know if this right or not
btw the proposal site is in turkey , where is the temperature is about 30 C in summer , and the highest point in the building is about 40 meters
again , thank you very much for your help
Sorry, my comments were completely separate from each other and should have been bulleted.
what i know that the cool air is lighter than the hot air that's why the air is becoming hotter when it goes up until it get outside the building...
No, hot air is lighter than cool air and air cools as it rises. That's how thunderstorms form.
...and then the hot air from outside will be cooled when it reach the water because of the evaporation...
Yes, evaporation of water will cool the air, but all that does is kill the efficiency of your system.
Here's an article on the concept: http://www.drroyspencer.com/2009/08/my-favorite-renewable-energy-concept-the-solar-updraft-tower/
Note: the article mentions a company said to be commercializing the idea. While I'm pretty sure the company is a scam, so I'm not going to link their website here, the concept is theoretically sound.
shoayb said:
hi
i hope its clear
I see no reason why the air should all of a sudden sink once it escapes from the structure. It is far more likely to continue to rise and form some of those cumulus clouds that you show. Air will continue to rise inside the structure during the night hours due to vaporization and the fact that humid air is less dense than dry air. The rate of movement should decrease compared to the daylight convection. Other than that, there is little that can be said without much more information.
M 7.6 - 73 km ENE of Misawa, Japan https://earthquake.usgs.gov/earthquakes/eventpage/us6000rtdt/executive 2025-12-08 14:15:11 (UTC) 40.960°N 142.185°E 53.1 km depth It was however fairly deep (53.1 km depth) as compared to the Great Tohoku earthquake in which the sea floor was displaced. I don't believe a tsunami would be significant. https://earthquake.usgs.gov/earthquakes/eventpage/us6000rtdt/region-info
  • · Replies 26 ·
  • · Replies 27 ·
