How do astronauts suits protect them from Solar Radiation?
In summary, astronauts are somewhat protected by the Earth's magnetic field when in orbit, but on the moon they are exposed to harmful radiation. Space suits are designed with layers and materials to block or absorb radiation, but they offer little protection against cosmic rays or solar storms. A moon base must have a thick layer of moon dirt or an underground "storm cellar" for protection. Mars missions face similar problems, as the planet does not have enough atmosphere or magnetic field to shield against radiation. The radiation doses on different space missions vary, with Mars missions receiving the highest doses. Ultimately, gamma radiation is the most dangerous and difficult to shield against.
Tokage
I assume, that when in orbit, astronauts are still somewhat protected by the Earths magnetic field? However, what about when they're on the moon? Does the Earths magnetic field extend that far? If not, how do they protect their bodies from harmful radiation?
I don't know the particulars, but maybe this will help.
http://en.wikipedia.org/wiki/Space_suit
The various liners and layers of the space suit incorporate materials designed to absorb or block radiation and other hazards in space.
Put bluntly, space-suits offer little protection from cosmic rays or a solar storm. Spacecraft such as ISS station must be designed with a 'storm cellar', an arrangement of equipment that will double as shielding when faced 'up-sun'...
IIRC, a massive solar flare occurred between the Apollo #16 & #17 missions which could have given an exposed crew a near-fatal radiation dose. It would certainly have made them very ill, perhaps incapable of flying the return leg of the mission...
This is why, although many artists' impressions of a moon-base show a cluster of pressurised modules, the real thing must add a thick topping of moon-dirt or have a 'storm-cellar' tunnelled several feet underground...
Similar problems apply to manned Mars missions, IIRC, as Mars does not have enough atmosphere or magnetic field to shield the surface...
But Mars is farther from the Sun, so it would receive less solar radiation--how much less, exactly?
According to Buckey's "Space Physiology", the relevant dose rates are:
8d Shuttle flight 0.0053 Sv
5mth on Mir 0.16 Sv
Dose on Mir from October 1989 solar event 0.15 Sv
Trip to Moon 0.011 Sv
Trip to Mars (flight) 0.5 Sv/yr
Surface of Mars 0.12 Sv/yr
For comparison, a chest x-ray delivers 0.0001 Sv, and the galactic cosmic radiation background (no shielding, solar minimum) is 0.5 Sv/yr
As mentioned, shielding is required for spaceflight- the suit will protect against alpha radiation, but little else. Spacecraft can also protect against beta radiation. In the end, it's the gamma radiation that causes problems.
FAQ: How do astronauts suits protect them from Solar Radiation?
1.
How do astronaut suits protect them from solar radiation?
Astronaut suits are designed to protect astronauts from the harmful effects of solar radiation while they are in space. These suits are made up of multiple layers of specialized materials that work together to provide a barrier against the dangerous radiation from the sun.
2.
What are the materials used in astronaut suits to protect against solar radiation?
The outer layer of the astronaut suit is typically made of a fabric called Dacron, which is a synthetic polymer that is highly resistant to radiation. Other materials used in the suit include layers of aluminum and Mylar, which reflect and absorb radiation, and layers of insulation and heat-resistant materials to protect against extreme temperatures.
3.
How do astronaut suits protect against different types of solar radiation?
Astronaut suits are designed to protect against both types of solar radiation: ionizing radiation and non-ionizing radiation. Ionizing radiation, such as X-rays and gamma rays, can damage DNA and cause cancer. The suit's layers of reflective and absorbent materials help to block these harmful rays. Non-ionizing radiation, such as ultraviolet light, can cause sunburn and damage to the skin. The outer layer of the suit is designed to block these types of radiation.
4.
Do astronaut suits provide 100% protection against solar radiation?
No, astronaut suits do not provide 100% protection against all types of solar radiation. However, they are designed to provide a significant level of protection, allowing astronauts to safely complete their missions. The amount of protection varies depending on the specific materials used in the suit and the length of exposure to radiation.
5.
How do astronauts protect themselves from solar radiation while on spacewalks?
In addition to the protective layers in their suits, astronauts also use other measures to protect themselves from solar radiation during spacewalks. They can limit the amount of time spent in direct sunlight and use special visors on their helmets to reduce the amount of ultraviolet light that reaches their face and eyes. They also receive regular radiation monitoring and follow protocols to minimize their exposure to radiation while in space.
