Gravity and atomic fields - due to high relative motion?
In summary, space-time has an effect on the velocity of atoms and this affects the gravitational field.
DavidSF
38
Gravity or gravitational fields are not yet understood fully. All mass bodies including the atom itself has what is called a gravitational field.
Gravity is principly the partial alignment of the atomic electrical fields due to a common high velocity motion of the atoms through the universe, as the quantity of atomic mass increases the overall atomic group frequency resonant frequency changes, for this reason different orbital velocities are required for different masses.
All atomic matter is composed of electrical particles, which when traveling together through the universe they develop a magnetic field due to common current flow, like particles magnetically attract and unlike particles develop a magnetic repulsion. The magnetic values involved are directly related to our total universal velocity.
This developed magnetic repulsion is also the reason why the electron and proton do not readily fuse together (combine) and the reason that electrons can only orbit at fixed magnet harmonic wavelengths proportional to the fundamental wavelength.
An electron in orbit around the positive nucleus is repelled to a radius, which is controlled by the velocity of the atom through the universe, both the nucleus and the electron absorb energy from the space-time velocity component to maintain their orbiting magnetic fields.
As the velocity through the universe changes so does the atomic particle magnetic fields and orbiting radial wavelengths change.
It is the universal motion which provides the energy which stabilizes the atomic particle structure.
In this way an atom constantly reacts to its environment and the environment is influenced by the atom. Space time can change the velocity of atoms by exchanging electrical energy with the atoms. From this we deduce that space-time is electrically active and that gravity is electrical in nature.
I read somewhere that an electron orbits the proton in the ground state at about 240,000 - 250,000 m/s but it is interesting that our galactic velocity is greater than 600,000 m/sec. I'm sure that the physicist generally ignores the effect of this 600,000 m/s velocity when descibing the atomic structure..
There is nowhere in the universe where you are not influenced by space-time conditions and anyone in orbit is simply magnetically balanced so to speak.
David
This is not the forum for such speculation. This quite clearly is not true, i.e. way outside mainstream physics/theory.
For "velocity" to have a meaning one has to be able to give the position of a partilce as a fuction of time. This cannot be done for an electron in an atom.
Pete
So neutrons do not have a gravitational effect? Therefore neutron stars(pulsars) do not have a gravitational field?
Moving these last three posts to start a new thread in Theory Development.
I believe the neutron contains both a proton and electron, only you excluded the neutron from the equation, I did not.
An osterich buries his head in the sand and he believes he cannot be seen.
A Physicist sometimes puts the atom in a box and assumes it does not move or interact with its environment.
If I am wrong, then you must have the correct answer to correct me, so that you can pull my head out of the sand so to speak.
Keplers second law states that:
The planets move such that the line between the Sun and the Planet sweeps out the same area in the same area in the same time no matter where in the orbit.
For me, the Earth and sun, which are both traveling with the galaxy at a speed of 600,000 metres per second, sweep out a rectangular area of 600,000 x 150,000,000,000 metres per second, this area is equivalent to the speed of light (c) squared exactly. Why ...
E = mc^2 ... Why?
'Why' is the big question is it not..
David
FAQ: Gravity and atomic fields - due to high relative motion?
What is the relationship between gravity and atomic fields?
The relationship between gravity and atomic fields is complex and not yet fully understood. However, it is believed that gravity is a fundamental force that affects all objects with mass, including atomic particles. The interaction between gravity and atomic fields is described by Einstein's theory of general relativity.
How does high relative motion impact gravity and atomic fields?
High relative motion can have a significant impact on gravity and atomic fields. According to Einstein's theory of relativity, as an object's speed increases, its mass also increases, which in turn affects its gravitational pull. This means that high relative motion can cause changes in the strength of gravity and the behavior of atomic fields.
Can gravity and atomic fields be manipulated?
Currently, there is no known way to manipulate gravity and atomic fields. However, scientists are researching and experimenting with different theories, such as using electromagnetic fields or advanced technology, to potentially manipulate these forces in the future.
How do gravity and atomic fields influence the behavior of matter?
Gravity and atomic fields play a crucial role in the behavior of matter. Gravity is responsible for keeping objects in orbit around each other, while atomic fields dictate how atoms interact and form molecules. These forces also determine the properties and behavior of matter at a microscopic level.
What are the practical applications of understanding gravity and atomic fields?
Understanding gravity and atomic fields has many practical applications, such as in space exploration, where knowledge of these forces is essential for spacecraft navigation and understanding the behavior of celestial bodies. It also has implications in fields such as astrophysics, particle physics, and quantum mechanics, which help us better understand the universe and develop new technologies.
