Integrating infinitesimal conformal transformations
In summary, the conversation discusses the infinitesimal and finite versions of a special conformal transformation and how to integrate it. The speaker suggests finding a different set of variables to linearize the transformation and solving the equation for the transformation.
Rocky Raccoon
36
While it's pretty easy to derive the infinitesimal version of the special conformal transformation of the coordinates:
[tex]x'^{\mu}=x^{\mu}+c_{\nu}(x^{\mu} x^{\nu}-g^{\mu \nu} x^2)[/tex]
with c infinitesimal,
how does one integrate it to obtain the finite version transformation:
[tex]x'^{\mu}=\frac{x^{\mu}-x^2 c^{\mu}}{1-2 x^{\nu} c_{\nu} + x^2 c^2}[/tex]
with c finite?
I've never delt with nonlinear transformations that don't exponentiate trivially. Also, how does one integrate over a parameter that is Lorentz contracted with another vector?
Thanks for your help.
(First of all, I think you're missing a 2, it should be (2xμxν - gμνx2)).
In general, the way to exponentiate a transformation that acts nonlinearly is to find a different set of variables on which it is linear. In the present case, the conformal group can be generated by a) Lorentz transformations Λ, b) translations T, and c) inversion R. The inversion is R: xμ → xμ/xνxν. The transformation you're looking at is called a transversion, and can be written in terms of the generators as V = RTR-1. This gives you a clue that what you need to do to linearize V is to look at its effect on the inverted position vector, yμ ≡ xμ/xνxν. The action on yμ will be linear and easily exponentiated, and then you can go back and express the result in terms of x.
Yes, you're absolutely right, I'm missing a factor of 2.
So, you're saying that a simple change in variables will do the trick. I'll certainly try to do it that way. But, I was more thinking along the lines of solving the equation: [itex]dx^{\mu}=dc_{\nu}(2x^{\mu} x^{\nu} - g^{\mu \nu} x^2)[/itex]? Can it be integrated?
FAQ: Integrating infinitesimal conformal transformations
What are infinitesimal conformal transformations?
Infinitesimal conformal transformations are mathematical operations that preserve angles and shapes on a 2D surface. They are typically expressed as a set of differential equations and are used in the study of conformal field theory and other areas of mathematics and physics.
How are infinitesimal conformal transformations used in science?
Infinitesimal conformal transformations have numerous applications in science, including in the study of fluid dynamics, quantum mechanics, and general relativity. They are also used in image processing and computer graphics to manipulate and enhance images.
What is the difference between infinitesimal conformal transformations and other types of transformations?
Infinitesimal conformal transformations are unique in that they preserve angles and shapes on a 2D surface, while other types of transformations may change these properties. They are also different from finite conformal transformations, which involve a finite change in position or scale.
Can infinitesimal conformal transformations be applied to 3D surfaces?
No, infinitesimal conformal transformations are only applicable to 2D surfaces. In 3D spaces, conformal transformations become more complicated and involve both scaling and rotation.
What is the significance of integrating infinitesimal conformal transformations?
Integrating infinitesimal conformal transformations is an important tool in the study of conformal field theory and other areas of mathematics and physics. It allows researchers to study the properties and behavior of systems under infinitesimal changes, which can provide insights into their larger-scale behavior.
